FS: 1996 Toyota Tacoma 4wd - $2500
Discussion in '1st Gen Tacoma Parts Marketplace (1995-2004)' started by neontrail, Jun 4, 2012.
  1. Jun 4, 2012 at 9:48 AM
    neontrail
    neontrail [OP] ✈ ✈ ✈ ✈ ✈ ✈ ✈
    Idaho
    2004 NISSAN XTERRA XE/SE
    De-badged, Tint 20%, Blue 48 LED dome-light, .......
  2. Jun 4, 2012 at 4:25 PM
    e34croak
    e34croak Tacoma Susp. Confuses Me
    Dan
    Oregon
    2005 Toyota Land Cruiser
    Wow that seems like an awesome deal!
  3. Jun 7, 2012 at 1:54 PM
    snowboarder
    snowboarder Member
    Eagle, ID
    Black 2016 Tacoma TRD Sport DC
    I happened to see this posted and I jumped on it. The truck is very solid and runs like a champ. The interior is thrashed, but I am having it completely redone. Its currently at the upholstery shop.
    Here's my question and I will post this as a new thread: Where to start?
    To be a little more specific, its actually has 319,000 miles on it, but still runs great. The transmission doesn't seem to have any problems...everything seems to be working just fine. Usually I take the road of "if its not broken, don't fix it". But with 319,000 miles, I feel like I should be replacing something. Where should I start?
    Just so you know. My intention was to buy a High mileage 4x4 Manual Extended Cab and drop a brand new engine and tranny in. But since this one is still running, I feel like I should drive it till it dies, then put new stuff in. What do you guys think?
  4. Jun 7, 2012 at 1:56 PM
    f3nd3r
    f3nd3r Active Member
    I wish I could help with preventative maintenance, but I'm new.. either way, congrats on a nice find! :)
  5. Jun 7, 2012 at 1:57 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    drive it till it dies. save up your money for a nice engine/tranny/axles whatever you want while all the parts are still working, then put in the nice stuff later. check the frame and repair it or reinforce it if necessary. I bet it's taken a beating over that many miles
  6. Jun 7, 2012 at 2:01 PM
    garcm329
    garcm329 Well-Known Member
    mario
    rancho cucamonga
    06 T4R
    Stock! For now!!
    I would suggest start with the fluids... its basic and simple but do a flush of all fluids. (front diff, rear diff, transfer case, tranny, coolant, etc.) then I would suggest a tune up. from there check all electrical, make sure that all the cables and wires still look in good shape. Other than that, just enjoy it as much as u can haha
  7. Jun 7, 2012 at 2:19 PM
    snowboarder
    snowboarder Member
    Eagle, ID
    previous owner has had it since 80,000 miles. He said he religously changed all the fluids...but didn't have records. He said other than changing fluids, he hasnt done anything else. So after fluids comes what? Should I go for the clutch? Maybe timing belt? Plugs? Who knows...
    Oh, the frame is perfect. No rust anywhere.
  8. Jun 7, 2012 at 2:26 PM
    garcm329
    mario
    rancho cucamonga
    06 T4R
    Stock! For now!!
    if you dont feel the clutch slipping or smell it burning you should prob just leave it alone. But it wouldnt hurt to check the plugs, timing belt would prob be good too.
  9. Jun 7, 2012 at 4:03 PM
    neontrail
    Idaho
    you're welcome :)
  10. Jun 7, 2012 at 4:24 PM
    ds46000
    ds46000 Well-Known Member
    07 PreRunner TRD Sport
    if he hasn't done anything to it in the 240k miles that he's had it...i'd definitely at least check the brakes. It's probably time for new pads, rotors, calipers...maybe even brake lines. I'd check it all to be safe.
    Congrats on the new ride.
  11. Jun 7, 2012 at 4:51 PM
    Austintaco
    Austintaco Active Member
    Patrick
    Austin,TX
    03 DC TRD with some stuff
    Tundra coils, Tundra brakes, All pro rear leaves, Timbrens, ARB bumper, All Pro Sliders and Rear bumper, 4runner Limited wheels with 255/85/16 tires, soon to be added...Flippac
    If it's the 3.4, timing belt and water pump, if you can't verify when it was last done. What kind of mileage are you getting with it now? Awesome find.
  12. Jun 7, 2012 at 4:57 PM
    Hiatt1991
    Hiatt1991 Well-Known Member
    Hiatt
    Flagstaff, AZ/Walnut, CA
    2005 Tacoma Prerunner SR5 TRD offroad
    4" Bodylift 20" Offroad shock spacers Turbo Encabulator
    Replace fluid for both diffs, flush colant, CHANGE tranny fluid NOT FLUSH, change oil, check all belts for cracks and loosness, check the shocks for leaks, check the engines compression, check the exhahsr components for leaks and wear. Besides that, its ready to rock! You def came up on this deal!!!
  13. Jun 7, 2012 at 9:53 PM
    garcm329
    mario
    rancho cucamonga
    06 T4R
    Stock! For now!!
    Oh yea change that's what I ment haha good looking out on the correction
