FS: 1997-2004 ARE Bed Cap $250
Discussion in '1st Gen Tacoma Parts Marketplace (1995-2004)' started by bluebr65, May 3, 2012.
  1. May 3, 2012 at 12:31 PM
    bluebr65
    bluebr65 [OP] Active Member
    Bear
    Pittsburgh, PA
    01' SR5 4x4 5Spd
    Selling my color matched (Radiant Red) ARE Cap that I took off of my Regular Cab 2001 Tacoma but will fit any 6' bed Tacoma (1997-2004 I believe) This may even fit other trucks? The Cap is in great shape, there is only a scuff or two from setting it down under the covered and concrete portion under my deck. I can provide matched touch up paint if you would like. Sorry I could not get better photos but can email more upon request. The first photo is the cap on my truck at the time of purchase, the second is a sourced image of the same cap but different color on a Double Cab. I have 3 keys for the locking cap, all the rubber sealant around the cap base is in very good shape, the side windows slide as well as the window that separates the cap from the truck cab rear window. The third brake light works as it should with included connectors to your truck beds electrical connectors. This cap will be a great way to cover and protect whatever you may have in your truck bed. Come take a look! Also included are the original aluminum clamps and hardware, all in great shape! I will help you lift it/install it too.
    Call me at anytime: 412-995-8755
    396008_352851368075892_100000530954962_1_81f66867938b62d0ef2a4d6ed948a07819f7b2db.jpg5N25G65Kb3Kf3F53H5c5341190c375ce91135_0ab4eeaee81e36e599c5705c905a2cc4ba228b52.jpg
  2. May 3, 2012 at 4:01 PM
    Madjik_Man
    Colorado Front Range
    The toppers in the two pics are not the same.... meaning the one on the regular cab is regular cab specific and the one on the ext cab is ext cab specific.
    Just FYI
  3. May 4, 2012 at 8:56 AM
    bluebr65
    Bear
    Pittsburgh, PA
    01' SR5 4x4 5Spd
    This is correct! I should have caught that. This is for the regular cab only all!
