FS: 2016-2023 RC62F Manual Transmission
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by BLtheP, Dec 30, 2024.
  1. Dec 30, 2024 at 9:24 AM
    BLtheP
    BLtheP [OP] Constantly Tinkering Member
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    $1,500 + any freight (comes in a factory Toyota transmission box)
    62K miles.
    Manual transmission assembly out of a 2021 Tacoma. Toyota part # 33030-04070. Fluids have been changed regularly. Will fit any ‘16-‘23 Tacoma V6, can also be used to upgrade the ‘05-‘15 Tacoma V6 with some custom swap work:
    2nd Gen RA60F to RC62F Swap
    For a 3rd Gen, you will need to reuse your own bellhousing, clutch parts, and the shifter piece (all easy parts to swap).
    Nothing wrong with it at all, I swapped to a different model and no longer need this.
    MonkeyChief likes this.
  2. Jan 20, 2025 at 6:46 PM
    BLtheP
    Plano, TX
    Bump.
