FS -- 2nd gen stock OEM fog light switch and relay
Discussion in 'Buy / Sell / Trade' started by maser, Jan 22, 2011.
  1. Jan 22, 2011 at 6:48 AM
    maser
    maser [OP] Hello, my name is Maser... and I'm an alcoholic
    Fort Worth, TX
    06 PreRunner Dbl Cab
    fog light mod,DTRL mod,alternating turn signal mod, BHLM, pioneer pt 3200dvd, fosgate speakers all 4 doors,AFE CAI, Magnaflow turndown exhaust, satoshi'd grill, Procomp 6 in lift, 2 Diamond audio 10's w/ 600w amp..........
    Long story short.....I bought a base model v6 that didn't have fogs but had the wiring. Looked everywhere for 'em, and could only find cheap imitation ones on ebay. Finally found 'em on ebay and bought them. That same week, I met a guy who had them on cl, with the lamps...........
    So now I have a switch and relay for sale for what I paid for $50.
    SOLD***
  2. Jan 22, 2011 at 9:36 AM
    Bmxcast00
    Bmxcast00 Well-Known Member
    Raymond
    Exeter Ca
    09 PreRunner Reg. cab.
    Black headlight mod, powdercoated stocks, leveling kit, debadged
    i'm in the same situation but i have a pre-runner with out any wires for them. did you end up going with one of the imitaion fog light kits? glws
  3. Jan 22, 2011 at 9:42 AM
    DanT
    DanT Old Member
    Dan
    Richland, WA
    4WD 2.7L SR5
  4. Jan 22, 2011 at 10:20 AM
    maser
    Fort Worth, TX
    No, the 6 cyl. for some reason are pre-wired but no lights/relay/switch. So all I had to do was find OEM bits, and it plugged right in. I had to find these OEM parts ( which was very hard to do ) and plug in to factory harness. If you have 6 cyl, you should have the harness tied in there.
  5. Jan 22, 2011 at 10:24 AM
    maser
    Fort Worth, TX
  6. Jan 22, 2011 at 10:29 AM
    DanT
    DanT Old Member
    Dan
    Richland, WA
    4WD 2.7L SR5
    Thanks. I don't have a clue about how to wire these. Is the plug that fits the lamp assembly standard, or do I need an OEM part?
  7. Jan 22, 2011 at 11:02 AM
    maser
    Fort Worth, TX
    Hmm, I really don't know how standard ( or difficult ) it would be to wire your truck all OEM without going through dealer. I'm sure some members on here have got part #'s and such to help you out. For me, it was plug n play.
    I know how hard it is to find these things locally, it drove me nuts seeing other tacos with their fogs!! GL in your search, and i'll try to help as much as I can.
  8. Jan 22, 2011 at 11:21 AM
    DanT
    DanT Old Member
    Dan
    Richland, WA
    4WD 2.7L SR5
    Thanks again. At least I've got the lamp assemblies in securely. Even if I don't get them wired :) they look much better than the blanks that were there. For $90 that alone is a good deal.
  9. Jan 27, 2011 at 8:15 AM
    maser
    Fort Worth, TX
    Bump
  10. Jan 27, 2011 at 8:26 AM
    Blackshirts
    Blackshirts Well-Known Member
    TX
    09 PreRunner-Totaled. 2016 SR5 Blue DC
    Stuff
    Where were you at a month ago..... GAHHHHH....
    I paid 128 for both...
    Good luck with sale.
    Bump
  11. Jan 27, 2011 at 8:39 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
  12. Jan 31, 2011 at 8:03 AM
    maser
    Fort Worth, TX
    free shipping bump.
  13. Feb 2, 2011 at 5:31 AM
    maser
    Fort Worth, TX
  14. Feb 2, 2011 at 7:49 PM
    DanT
    DanT Old Member
    Dan
    Richland, WA
    4WD 2.7L SR5
    Yes indeed. Despite my searching I could not find this at the time of purchase. Thanks to your post, I went ahead and purchased. Now I have an extra set of lamps in case of breakage.
    But what I really am likely to need is the advice and experience of those who have installed this kit. Directions come with it, but are a bit sketchy. The kit says it is for the 2006. Mine is 2010, Not sure if there are any differences.
    I'd appreciate any supplemental instructions anyone has.
    I'd prefer to wire them so they can be operated independently of the low beams, but any advice, especially photos, would be appreciated.
  15. Feb 3, 2011 at 4:15 AM
    maser
    Fort Worth, TX
    ^^^Check out fog light mod. Your fogs can be on independently of the headlights. Find this thread in cheap/free mods.
    Switch and relay still available.
