FS-3rd Gen Low Mount/No Drill License Plate Bracket $50 Shipped
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by ACEkraut, Feb 6, 2017.
  1. Jan 6, 2018 at 11:15 AM
    #121
    Cole man
    Cole man I like a clean taco....
    Paul
    Bluegrass state
    2017 tacoma SR 4x4 V6 MGM
    Stock so far
    Those should be standard equipment from toyota!!!! I already drilled mine or id bought one. Looks alot better than the factory crapper... good job!!!!
    ACEkraut[OP] likes this.
  2. Jan 6, 2018 at 11:32 AM
    #122
    ACEkraut
    ACEkraut [OP] Well-Known Member
    Aaron
    Durham, Maine
    2014 DCSB TRD Off Road
    Thanks! I am biased but I agree completely!
  3. Feb 7, 2018 at 4:41 PM
    #123
    Woodpecker28
    Woodpecker28 New Member
    I'm interested in a no-drill front plate bracket for my 2016 Tacoma.
  4. Feb 7, 2018 at 7:22 PM
    #124
    ACEkraut
    Aaron
    Durham, Maine
    Starting a conversation....
  5. Feb 9, 2018 at 3:56 AM
    #125
    cemented
    cemented Well-Known Member
    Cole
    Portland, OR
    2017 TRD PRO Cement AT Maggy 84mm OTT
  6. Feb 13, 2018 at 10:08 PM
    #126
    Kwee808
    Kwee808 Well-Known Member
    Kwee
    2016 White Tacoma TRD Sport 4x4
    Got me spending more money
  7. Feb 13, 2018 at 11:48 PM
    #127
    ACEkraut
    Aaron
    Durham, Maine
    Isn't that the TW way?
  8. Feb 14, 2018 at 7:03 AM
    #128
    Kwee808
    Kwee
    That is indeed true. Lol.
  9. Feb 15, 2018 at 7:55 PM
    #129
    seoulja99
    seoulja99 Well-Known Member
    E.J.
    Oahu
    2012 DCSB 4x4 V6 TX Baja (1GR-FE)
    all things mall rated
  10. Feb 17, 2018 at 9:55 PM
    #130
    sixlxvi
    sixlxvi "break stuff"
    I’d like to buy one.
  11. Feb 17, 2018 at 10:01 PM
    #131
    YOTA 4X4
    YOTA 4X4 Well-Known Member
    2017 Double Cab Off-Road
    OME HD Lift all around, SCS SR8 Rims, 255 85 R16 Cooper ST Maxx, Decked Drawers, 30" Rigid Pro Light bar above bumper on Rago Mounts, Rigid Dually Side Shooters on Rago ditch brackets, Hondo Garage Un-Holey Phone Mount X2, Hondo Radio Knobs AR Bolt Face, Garmin InReach SE GPS synch'ed to Iphone for GPS only mapping, Wet Okole Seat Covers, Husky Liner Contour floor mats, 63 QT ARB Fridge on Alu-Cab tilting slide. GoFastCamper (#41), ARB 2500 Awning with Full Room, Mobtown Off-road Sliders and Full Aluminum Skids.
    Sub'd
  12. Feb 18, 2018 at 12:26 PM
    #132
    ACEkraut
    Aaron
    Durham, Maine
  13. Feb 19, 2018 at 2:37 PM
    #133
    whiteTuRD
    whiteTuRD Member
    Houston
    2017 White Tacoma TRD 4x4
    I'm interested in a bracket ACEkraut
  14. Feb 19, 2018 at 7:16 PM
    #134
    ACEkraut
    Aaron
    Durham, Maine
  15. Feb 20, 2018 at 1:24 PM
    #135
    RupertPupkin
    RupertPupkin Active Member
    West Chester, PA
    2017 Tacoma TRD Sport
    Just want to say this thing is awesome! Got to me in a day or two, perfect fit and finish. I bought some rust oleum satin black primer/paint and sprayed it yesterday. Couldn't be happier. Highly recommend this bracket!
  16. Feb 20, 2018 at 8:50 PM
    #136
    ACEkraut
    Aaron
    Durham, Maine
    Thanks for the kind words and vote of approval! Glad you are pleased with the bracket! Please post a picture if you have one.
  17. Feb 21, 2018 at 7:56 AM
    #137
    ACEkraut
    Aaron
    Durham, Maine
    PM's replied!
  18. Mar 1, 2018 at 4:09 PM
    #138
    Norsemanvike
    Norsemanvike Well-Known Member
    Escondido, CA
    '18 Sport 4x4, DblCb, ShBd, BBP
    Question, could a Y mount be created so that you only had 1 bar coming up from underneath the bumper instead of 2? It would still be low profile, painted ( as suggested ) would blend in even more, and with the padding behind one of the images I saw would still protect the bumper plastic. I'm intrigued by this idea and might pursue it down the road.
    ACEkraut[QUOTED][OP] likes this.
  19. Mar 1, 2018 at 4:20 PM
    #139
    ACEkraut
    Aaron
    Durham, Maine
    While there are multiple bolts under the bumper area, including one that is dead center in the middle of the bumper, that bolt does not go into a backing piece of metal so it does not provide much strength. The two bolts that my design uses are both backed by a metal piece that sits behind the bumper cover, offering a VERY secure place to mount the bracket. I don't think a "Y" design would offer the stability to keep the bracket in place since a single bolt holding the bracket would allow it to pivot right and/or left. The current design ends up being a box with all four corners held together so it is very strong and will allow zero movement once it is mounted. Also, once the bracket is mounted with the plate on it does not show unless you duck down to look at it. Many customers have color matched the bracket to their bumper cover, increasing the amount the bracket blends into the existing bumper, making it almost invisible.
    Of course, my answer makes sense only if I am understanding clearly what you are suggesting, which I may not be understanding. Have a drawing?
    cemented and seoulja99 like this.
  20. Mar 1, 2018 at 4:43 PM
    #140
    Norsemanvike
    Escondido, CA
    Nope, you understood it perfectly. Probably too expensive to machine a single piece to do the same thing. Unless you used a horizontal brace behind the plate to utilize the manufacturer holes from the original plate? But the pivot left/right thing could be interesting if it was intentional to make it "wave." I can see the conversation now...
    Me: Problem officer?
    PD: You're front plate is moving. That's why I pulled you over.
    Me: CA code doesn't say that it can't be moving. It just has to be mounted on the front, which it is.
    PD: Uh huh.
    Me: Hi you're honor, I'd like to contest the ticket for my front lic plate please.
