FS:AFE Power Stage 2-SI CAI 12-15 with Ram Air Scoop
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by Tacomoto23, Nov 12, 2018.
  1. Dec 21, 2018 at 6:02 PM
    Jay619
    Jay619 Well-Known Member
    Jay
    San Diego/Las Vegas
    2016 4Runner Trail Premium
    How much is it gonna be without the scoop?
  2. Dec 21, 2018 at 6:07 PM
    Tacomoto23
    Tacomoto23 [OP] Well-Known Member
    Carey
    Torrance,CA
    21’ TRD 4x4
    PM’D
  3. Dec 23, 2018 at 7:15 PM
    SamuelJ
    SamuelJ Darkhorse
    Samuel
    33.9269893 -118.0185768
    2012 DCLB 4x4 Trd Sport
    Shortened flowmaster exhaust with a turn down pipe, under cowl intake, throttle body spacer, train horn, underhood led lights, hood struts, dual 27f yellow tops. Led ditch lights, led front roof light bar, led fogs and headlights, behind grill mounted piaa dual color driving lights. Aux fuse and relay panel. Pro comp skid plate, bilstein 5100 leveling shocks on a 2in. lift, b110 rear 5100, add a leaf, front superbumps, light racing jounce rear bumpstops, sway bar relocation, brake line bracket extension, driveline carrier bearing drop, front diff drop, on board air compressor, 10 gal pump driven fresh water tank, cb radio, pioneer 4200 hu, infinity reference component front and component rear speakers powered by rockford fosgate 4 channel, jl audio 10TW3-D4 sub powered by kx800.1 amplifier. Big three upgrade, capacitor. Full cab sound deadening and thermal insulation. Led interior including added footwell, courtesy, cupholder, center console, and glovebox lighting, rock lights, bed lights, ring gear armor, under bed ammo can storage, pistol safe, body armor sliders, roof rack, hilift, 285/70 17 nitto rodge grapplers on american racing teflon atx, tailgate strut, and tailgate lock, retrofit projector headlights(home built), rgb halos inside turbine shrouds, black out surround, black chrome reflector and shroud, white halo outside shroud, white led drl, rgb behind grill on rf control. Mods followed from a TW thread: Anytime fogs Anytime rear view camera Anytime 400w inverter Alternating blinker/running lights 110v center console outlet ABS kill switch Engine kill switch (magnetic) 12volt bed socket Rear diff breather relocation Led bed lights Cargo net anchors Grid it center console top Grid it sun visor Locking center console Instrument cluster led swap Map lights on with dome Cigarette lighter add (shifter position) Dtrl kill switch Hilux lighted 4wd selector switch. Vios hvac knobs Hood scoop led bar
    Is that legal for smog inspections? I live in so cal and was under the impression that an aftermarket cai of any brand would fail smog inspection. Sorry, not tryin to poop on your thread. If it will pass smog I'll buy both.
  4. Feb 2, 2019 at 4:44 PM
    Texastaco2010
    Texastaco2010 Well-Known Member
    2010 TRD Tacoma
    Scoop available still
