FS: All Pro Standards
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by CayucosTacoma, Apr 1, 2013.
  1. Apr 1, 2013 at 4:16 PM
    CayucosTacoma
    CayucosTacoma [OP] Just think outside the Yota
    San Luis Obispo/San Jose
    2004 Double Cab 4x4
    Specs in the Build Thread
    Sold
  2. Apr 1, 2013 at 4:25 PM
    NickBill80
    NickBill80 Active Member
    Nick
    Fullerton CA
    07 PreRunner DC
    Any discount for a repeat customer? :D
  3. Apr 1, 2013 at 4:26 PM
    CayucosTacoma
    2004 Double Cab 4x4
    we can work something out:D
    maybe a bundle with some lights ;)
  4. Apr 1, 2013 at 4:50 PM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    I can commute em to SD if needed next weekend :) or anything else you sell if you have an SD buyer
  5. Apr 1, 2013 at 4:54 PM
    The Traveler
    The Traveler Desert Chief
    SoCal
    1991 Toyota Pickup 4x4 Prerunner
    :spy:
    Possibly down if you're passing OC
  6. Apr 1, 2013 at 4:58 PM
    CayucosTacoma
    2004 Double Cab 4x4
    i am but the catch is i need a 1.5-2" block before i can take them off.
    Reason is because i have a ubolt flip that i have to run b/c i welded on spring perches on the axle which get in the way of the stock hardware and spring plate.
    And i dont know if stock leafs fill out enough of the u bolt flip before it runs out of threads
  7. Apr 1, 2013 at 4:58 PM
    CayucosTacoma
    2004 Double Cab 4x4
    thanks man :cheers:
  8. Apr 2, 2013 at 2:42 PM
    CayucosTacoma
    2004 Double Cab 4x4
  9. Apr 3, 2013 at 9:47 AM
    CayucosTacoma
    2004 Double Cab 4x4
  10. Apr 3, 2013 at 11:42 AM
    VolcomTacoma
    Jeff
    NorCal
    Did you figure out the U-bolt situation? Can you bring these down on Friday?
  11. Apr 3, 2013 at 11:44 AM
    CayucosTacoma
    2004 Double Cab 4x4
    going to tap them like you said, and yes i can
  12. Apr 3, 2013 at 11:47 AM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    I've got a question, how do the fox shocks work with these leafs? I've got walker Evans shocks and the ride is retarded rough. Every bump is super painful to drive over. How do the fox's ride?
  13. Apr 3, 2013 at 11:51 AM
    CayucosTacoma
    2004 Double Cab 4x4
    They were on a buddies truck but ride was great in my opinion. Had the compression adjusters on the rears. Not a bad ride at all
  14. Apr 3, 2013 at 12:44 PM
    VolcomTacoma
    Jeff
    NorCal
    Ok so anyone in LA/OC/ or San Diego interested in buying these this weekend?
  15. Apr 4, 2013 at 11:56 AM
    CayucosTacoma
    2004 Double Cab 4x4
  16. Apr 5, 2013 at 5:52 PM
    CayucosTacoma
    2004 Double Cab 4x4
