FS: Alpine Halo 9 ilx-f509
Discussion in 'Northern California' started by thebaker, Jun 9, 2025.
  1. Jun 9, 2025 at 10:04 PM
    thebaker
    thebaker [OP] Well-Known Member
    Byron
    NorCal
    Upgraded to a 3rd gen
    Never ending......$$$
    Selling my gently used alpine halo 9 ilx-f509. Coming out of a 2015 tacoma non jbl.
    Will include the following:
    -Alpine ilx-f509
    -Metra dash kit, black
    -Idatalink Maestro RR interface module
    -Idatalink HRN-HRR TO1 vehicle specific harness
    -brake bypass harness
    This stereo worked flawlessly in my truck. Had it installed for about 1.5yrs.
    The maestro allows you to retain steering wheel controls and monitor truck levels such as speed, mpgs, oil temp, etc.
    To be totally transparent, I did break a small tab on the radio chassis when I was test fitting and adjusting the radio during the install. I gorilla glued the tab back on and everything worked as normal.
    Both the alpine and Idatalink harnesses will come wired for you so install will be plug and play.
    I will include a hdmi cable if you want it. I ran the hdmi cable to my glove box attached to a firestick so I could watch youtubetv, Netflix, etc...
    Please let me know if you have any questions.
    Im located in San Francisco but travel to Sacramento and Truckee area.
    If you were to buy this set up new, it would cost you over $1500.
    I'm asking $750. It's your responsibility to check if the Idatalink Maestro is compatible with your vehicle.
    Thanks for looking!!!!!
    rob1208 likes this.
  2. Jul 2, 2025 at 7:28 AM
    thebaker
    Byron
    NorCal
