FS: Auburn Gear LSD for 2nd Gen Tacoma
Discussion in 'Buy / Sell / Trade' started by cmack, Jul 27, 2010.
  1. Jul 27, 2010 at 8:08 PM
    cmack
    cmack [OP] Impeach Chris4x4!
    Up for sale is a brand new Auburn Gear LSD (Pro Series) for the rear of a 2nd gen Tacoma. It's never been installed. More information can be found here on it. Asking $275 OBO plus shipping.
  2. Jul 27, 2010 at 8:12 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners.
    Oh baby.
  3. Jul 27, 2010 at 8:13 PM
    Chad
    Chad Rand Paul 2016
    Chad
    Raleigh, NC
    09 V6 Access Cab TRD Sport
    Pioneer AVIC-X920BT Headunit -- BHLM -- Pioneer TS-A1685R 4-way Coax Speakers in Front -- Suntek CXP 40 Front Tint -- Access Vanish Roll-up Tonneau -- Wet Okole Seat Covers -- Fog Lights on Anytime -- PnL Powered Tailgate Lock -- DTRL "Stealth Mode" -- LED Footwell and Cup Holder Lights -- Map Lights ON with Dome Light -- Shorty Antenna -- AC Line Extension Mod -- 09+ Access Cab Rear Headrest Removal
    How'd you get this Connor?
  4. Jul 27, 2010 at 8:30 PM
    yosh2000
    yosh2000 Well-Known Member
    Denver, CO
    '05 4runner SR5 v8
    i have been looking for a truetrac locker lately because it doesnt use clutch packs, but how is this alike/different?
  5. Jul 27, 2010 at 9:37 PM
    chris4x4
    chris4x4 With sufficient thrust, pigs fly just fine. Staff Member
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    The Detroit is very similar to a Torsen diff. and uses worm gears. When torque is applied, the gears are pushed out against the case, and power is delivered to the wheel that is slipping.
    Though they say the diff doesnt "waer out" like other LS diffs, as it only applies a little amout of pressure to the case, it uses the case as opposed to friction plates (clutch plates), so if/when it does wear out, you have to replace the entire unit, as opposed to replaceing the clutch disks.
    The Auburn LS Diff uses a Cone clutch, and wears directly to the case of the diff. The Cones and the case wear, and neither are replaceable.
  6. Jul 27, 2010 at 9:39 PM
    cmack
    Thank you for chiming in on that one ;)
  7. Jul 27, 2010 at 11:35 PM
    lepedog23
    lepedog23 Taco Rookie
    Frank
    Huntington Park
    2001 DC Tacoma. Stock. Salvage Title MOD.
    Salvage Title MOD.
    whats the difference between this lsd, stock lsd and a trd locker? plus does this fit my 2wd taco non trd? i think i have a 8.4"
  8. Jul 27, 2010 at 11:44 PM
    cmack
    This one is stronger than factory LSD. It locks up stronger from what I understand as well to perform better. It's cheaper than a locker. For a TRD locker, I think you need to pull a complete rear axle form a TRD Offroad packaged tacoma in order to get it. Plus since it's selectable, then you'd need the switch, wiring, etc. An LSD would benefit with traction both on and off the road as well, where as a locker would pretty much benefit offroad. This will fit the rear axle of a 2nd gen tacoma, so yes, it would fit your truck.
    The 2nd gens have an 8.0" and the 1st gens have an 8.4". If you want to confirm that, you can check the link I posted in the OP. It's linked to a PDF file directly from Auburn Gear that has the specs.
  9. Jul 27, 2010 at 11:50 PM
    lepedog23
    Frank
    Huntington Park
    Salvage Title MOD.
    so a lsd with the auburn gear lsd will work better than a trd elocker? cuz i found a rear axle with elocker for 500 locally....
  10. Jul 27, 2010 at 11:54 PM
    cmack
    Depends on your uses. It would be a cheaper route to go with the Auburn Gear LSD. SO really, depending on what you use your truck for, depends on which one would benefit you more. It'd be a lot more work to swap a rear axle compared to installing an aftermarket LSD too.
  11. Jul 27, 2010 at 11:56 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    add another $500+ to have that installed...not to mention all the electrical stuff to have it be a true e-locker...plus this is brand new (never installed and in the original box) :D
  12. Jul 28, 2010 at 12:09 AM
    lepedog23
    Frank
    Huntington Park
    Salvage Title MOD.
    im going to try and make my taco into a desert runner in the future...
  13. Jul 28, 2010 at 12:13 AM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    Than a Full Locker would best fit your application for that bud :)
  14. Jul 28, 2010 at 12:19 AM
    cmack
    In all honesty too, I'm not sure how a TRD rear axle would match up compared to the base model one. I just don't know that much about that kind of axle swap. Now if you were talking about a SAS, then I'd know all kinds of info for ya :D
  15. Jul 28, 2010 at 12:21 AM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
  16. Jul 28, 2010 at 5:02 AM
    98tacoma27
    98tacoma27 :POOPCORN: Staff Member
    Ben
    Beech Creek
    05 Tundra SR5, 88 SR5 PU, 98 TRD OR (CRUSHED)
    5100's all on fours
    :thinking:
  17. Jul 28, 2010 at 7:37 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    To clarify:
    This unit isnt any "stronger" then the OEM LS Diff. It will "lock up" stronger than the OEM LS Diff.
    Both the first and second genss use the same rear ring gear size, just the second gens are wider. Non TRD off road models use a "8.4" " housing.
  18. Jul 28, 2010 at 8:43 AM
    cmack
    Thanks for clarifying.
  19. Jul 28, 2010 at 8:43 AM
    thom
    thom I am so there
    Thom
    Lafayette, Indiana
    95' Tacoma
    I'll vouch for the brand new part. Connor hasn't had it long enough to install it in anything! And he is selling it at a good discount, compared to some, http://www.shelbysautostorm.com/servlet/the-Auburn-Gear-Differentials/Categories.
    BTW, who ever does buy it might have a slight advantage is we do another photo swap;)
  20. Jul 28, 2010 at 8:45 AM
    cmack
    Thanks Thom. The original plans for the diff changed slightly :eek: Will shoot you an email later today as a follow up to the last one. I've just been busy with work and whatnot.
