FS Automatic Locking Rear Differential Powertax No-Slip (Lock-Right) by Richmond Gear
Discussion in 'Buy / Sell / Trade' started by drew02a, Jun 11, 2009.
  1. Jun 11, 2009 at 10:12 AM
    drew02a
    drew02a [OP] Rocking your mom's world Since 1997
    San Antonio, TX
    2006 Regular Cab 2.7L 4x4
    SOLD
    This Automatic locking differential was installed in my truck for ~ 2K mi. It is in great shape.
    I'm asking $375 obo, since it has so little use and has no wearable parts.
    FREE SHIPPING to continental US will ship elsewhere for small fee.
    Very easy to install as it takes the place of your existing spider gears:
    Fits inside of standard open carrier case only! (not Posi Case!)
    Fully automatic locking operation.
    Rearend: Toyota Tacoma, Tundra, T100, Sequoia rear dropouts.
    Spline Count: 30
    Part # 92-2080-3002
    The POWERTRAX® TRACTION SYSTEMS are the latest design in traction adding differential technology. It combines the smooth operation of a limited-slip differential, with the traction performance of a locking differential.
    A precise synchronization mechanism eliminates the ratcheting sounds typical of other locking differentials. Special gear and spring design reduce the backlash and therefore driveline windup. Only ultra strength material is used which is 67% stronger than titanium.
    Installation is simple because no ring and pinion set-up is required. In addition, no special tools or oils are needed. Step by step model specific instructions are provided with every kit.
    The POWERTRAX® TRACTION SYSTEMS are the ideal solution for just about any light truck, sport utility, and muscle car on the road today. Whether you need the safety of added traction for daily commuting, recreation, work, or just so your muscle car puts power to the pavement instead of burning one wheel up, the POWERTRAX® TRACTION SYSTEMS are your answer.
  2. Jun 11, 2009 at 10:14 AM
    drew02a
    San Antonio, TX
    I'm sure I'll get questions about why I'm selling this item if its "so great". The answer:
    I'm re-gearing to 4.56 front and rear and installing an ARB air locker in the front. I figured I should go ahead and upgrade to ARB in the rear too.
  3. Jun 11, 2009 at 10:41 AM
    johnecon2001
    johnecon2001 Well-Known Member
    Phoenix, AZ
    2005 TRD Sport 4x4 Access Cab
    Downey front skid, Trail Gear U-Bolt flip, Toytec AAL, Total Chaos UCA's, Bilstein 5100's x4 + Eibach adjustable coils, Doug Thorley Long Tube Headers, Custom Rear bumper, TRD OffRoad front tow hook, TRD Trail Team wheels, Federal Couragia M/T 265's, ARB rear locker + on board air (CKMA12), TRD shift knob, Alpine W205, TRD seat covers, Tom Woods 1 Piece drive shaft, Powermaster D2700, Stubbs HD-SKO Sliders.
    OakleyTRD has been wanting one of these. I sent him a text, hopefully he can get it from you.
  4. Jun 11, 2009 at 10:42 AM
    drew02a
    San Antonio, TX
    Thanks man I appreciate the promo.
  5. Jun 11, 2009 at 10:45 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    Me too but we both have the TRD SPort, wont work with our LSD
  6. Jun 11, 2009 at 10:49 AM
    drew02a
    San Antonio, TX
    I tell you what, I'll throw in my open carrier for FREE. It's just got some marks on it where I had to grind off a bolt head. I can include a picture if you'd like.
    You'll have to make sure that your ring gear would fit the new carrier and probably have the backlash re-setup.
  7. Jun 11, 2009 at 11:17 AM
    drew02a
    San Antonio, TX
    Here are some pics of the carrier I'll throw in for FREE, if you've got an LSD rear. I'll probably need to charge about $10 for shipping, because this thing is heavy. Comes with shims and bearing covers. The grinding marks should not significantly affect the strength of the carrier.
    The shadows make the grinding look deeper in the overhead shots than it actually is.
  8. Jun 11, 2009 at 1:57 PM
    drew02a
    San Antonio, TX
    I installed it in March and took it out last night. I'm not sure the exact mileage, but it's around 2K mi. At the time I got it, I thought there was no way I could afford ARB. Things changed and now I can afford to do the setup I REALY wanted to do all along.
    This unit will not fit in an LSD case, but will I'll give you my open diff carrier case for free + $10 shipping charge. Before you buy it, you'll need to make certain that the open carrier case will fir in your 3rd and that your ring rear will fit on the case. They should fit, but you should make sure before buying.
  9. Jun 11, 2009 at 2:11 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    How well did it work when going around corners?
  10. Jun 11, 2009 at 3:22 PM
    drew02a
    San Antonio, TX
    That's cool man.
    FWI, there aren't any autolockers that will fit into an LSD case. No matter what kind of locker you get, you'll have to replace your carrier.
  11. Jun 11, 2009 at 3:29 PM
    t.hornstra
    t.hornstra Well-Known Member
    Ted
    NorCal
    White with 4 wheels
    Little this. Little that 4x4 Swap’d PreRunner
    kind of a newb question:
    I have a 2002 Non-trd prerunner, wil lit fit my diff?
    ive been wanting to get a whole new rearend with an e-locker. but i think this would be the same.. and alot cheaper right?
    how does it drive? any noticeable difference with cornering and whatnot? i recall people talking about the e-locker and how u cant go over a certain speed limit and fast cornering.
    im new with this stuff but i really want to get a locking diff in my truck becuase i want to start doing trails and small offroading.
    any help would be great
  12. Jun 11, 2009 at 4:05 PM
    drew02a
    San Antonio, TX
    It's not the exact same as an e-locker because you can't switch it on and off. If you've got an automatic transmission, you'll hardly notice it's there (except for the much improved traction). If you have a manual it's about 90% transparent.
    According to the Powertax application guide it will fit your truck.
  13. Jun 11, 2009 at 4:20 PM
    t.hornstra
    Ted
    NorCal
    White with 4 wheels
    did you have it in your daily driver? how does it perform on the street, like cornering and high speeds?
  14. Jun 11, 2009 at 4:24 PM
    drew02a
    San Antonio, TX
    I've used auto lockers in my last 2 daily drivers. At high speeds you definitely can't tell it's there. The only time it's noticable is when your taking sharp right turns and driving really slow. If you have an auto tranny you probably won't even notice it then.
  15. Jun 11, 2009 at 4:29 PM
    t.hornstra
    Ted
    NorCal
    White with 4 wheels
    well sweeet. how much you askin for it again? could you hold it for a day or two while i get the funds, gotta ask the parents to forward me money since i havent started my summer job yet. :D
  16. Jun 11, 2009 at 4:53 PM
    jarrodh77
    jarrodh77 Member
    Murfreesboro, TN
    03 DC 4x4 TRD V6
    I had a Powertrax in my 04 Ram 1500 quad cab as a daily driver. You won't know it's there at high speeds. Occasionally I could hear it engage/disengage when I put my foot on or off the gas, but you have to be listening for it. I noticed it most when turning sharply from a stop like from a stop sign it would chirp the inside tire, but you get used to it and learn how to drive with it. Overall, the extra traction is worth the very slight annoyance on road.
  17. Jun 11, 2009 at 9:14 PM
    afd23a
    The Dynamo of Dixie
    I'm interested in it too, just can't seem to find out what size ring gear I have. :confused:
  18. Jun 11, 2009 at 11:53 PM
    drew02a
    San Antonio, TX
    I'm not sure whether it will fit the carrier case for a 5 lugger. You could call richmond gear and ask them what part number is for your truck...
    Tech Support for Richmond Gear (the manufacturer):
    http://www.richmondgear.com/02form.html
  19. Jun 11, 2009 at 11:56 PM
    drew02a
    San Antonio, TX
    I'm selling for $375 with FREE shipping. You will only need to replace your carrier IF you have an LSD rear. If that is the case then I'll give you mine for a $10 shipping fee.
    I'll sell to the first person who I receive money from preferably PayPal :)
  20. Jun 12, 2009 at 12:00 AM
    MudontheTires
    MudontheTires Texan
    Texas
    2008 V6 PreRunner SR5
    Leather Seats, TRD Bilstein Shocks, 6000k Bi-xenon Hid Kit, Toyota Bed Mat, Suspension TSB, TRD Accessory Skid Plate
    hmm i'm kinda interested and you wouldn't even need to do shipping.. does it affect gas mileage any? how much does this usually cost brand new if you don't mind me askin
