FS: Bilstein 5125 extended travel shocks and 1" bolt on Add-A-Leafs ... Virtually new
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by mattgecko, Oct 27, 2013.
  1. Oct 27, 2013 at 8:01 AM
    mattgecko
    mattgecko [OP] The LED Lighting Guy. MattGeckoLEDs.com
    South San Jose, CA
    2011 DCSB O.R. 4wd TRD Super Charged
    Bilstein shocks, model 5125, part number #24-214667). Made for 3"-4" lift
    Asking $130 shipped lower 48 states
    Installed and removed, like new.
    Manufactures Specs:
    The Bilstein 24-214667 46mm 5125 Series Monotube Shock Absorber is designed to be used on custom vehicles in order to acheive the desired ride. The shocks are sold by lengths and damping rates rather than by application.
    • Series:5125 Series
    • Collapsed Length (IN):16.14
    • Collapsed Length (MM):410.0
    • Extended Length (IN):25.98
    • Extended Length (MM):659.9
    • Body Design:46mm ID smooth body (Non-coilover)
    • Boot Included:Black bellows
    • Finish:Zinc plated
    • Internal Design:Monotube
    • Lower Mount Type:5/8" Eye
    • Upper Mount Type:Stem
    • Reservoir:No
    • Compression@0.52m/s: 940
    • Rebound@0.52m/s: 1780
    Why am I selling them:
    I installed a new lift and the rear lift ended up being a bit higher than I wanted. Was shooting for level and ended up raked.
    I also have 1" add-a-leaf (blocks) for sale, these bolt directly to the leaf springs. Had them powder coated black. $30 shipped (lower 48 states)
    NOTE: Mounting pins NOT included, sorry.
    http://www.offroaddesign.com/catalog/Zero%20Rates.htm
  2. Oct 27, 2013 at 5:23 PM
    Boogyman
    Boogyman Well-Known Member
    Phoenix
    Corpus Christi, TX
    2022 Lunar Rock Trail Edition
  3. Oct 27, 2013 at 5:46 PM
    Bearcoatoffroad
    Bearcoatoffroad Well-Known Member
    Barry
    Rincon, GA
    '07 TRD Off Road 4x4 Double Cab
    2.5" spacer lift, Tundra wheels with spacers
  4. Oct 27, 2013 at 8:05 PM
    mattgecko
    South San Jose, CA
    Shocks are .... Sold
