FS: Black Steel Wheels
Discussion in '1st Gen Tacoma Parts Marketplace (1995-2004)' started by Digiratus, Jan 25, 2012.
  1. Jan 25, 2012 at 2:03 PM
    Digiratus
    Digiratus [OP] Adventurer
    Roaming the PNW
    The RedHead
    These are off my buddy’s Tacoma which he bought with these wheels mounted on it. I am not certain of the brand but these look to be Cragar Soft 8s. They are stamped C T & W (Carlisle Tire & Wheel which is owned by Cragar).
    One wheel does have a small flattened area (see pic) but overall these are in pretty good shape. Only slight scuffing from normal handling.
    The wheels will mount on 1st Gen. Tacomas, but a small (1/4”) wheel spacer is required to clear the calipers. They are 15”x8” with a 6 on 5.5 bolt pattern with 4” of backspacing.
    SOLD
    Priced to sell at $90 for the set of 4 wheels.
    Prefer local pick up but have the ability to ship via freight truck on a pallet to a business destination. I am willing to meet up with an interested buyer in the Seattle metro (Tacoma-Bellevue-Everett) area.
  2. Jan 25, 2012 at 2:16 PM
    Anthony250
    Anthony250 Ex Fabricator
    Anthony
    Rialto CA
    99 Tacoma LT Prerunner
    LSK Race Kit, King Shocks, Methods, Glassworks, Baja Designs, Built by myself.
    Good deal!!!!!
  3. Jan 25, 2012 at 2:16 PM
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    won't fit my truck bump
  4. Jan 25, 2012 at 2:45 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Yeah, I wasn't sure on 2nd gens. Are you certain? Is it the caliper or is it because of the circumference of the brake disc?
  5. Jan 25, 2012 at 2:47 PM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    caliper i believe i only have about a 1/4" of space between the wheel and the caliper on mine
  6. Jan 25, 2012 at 2:50 PM
    Digiratus
    Roaming the PNW
    The RedHead
    So you think these should work on 2nd gens as long as wheel spacers are used?
  7. Jan 25, 2012 at 2:53 PM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    it's possible... only way to know it to try them out
  8. Jan 25, 2012 at 7:29 PM
    Iceman2448
    Iceman2448 Well-Known Member
    Ga
    5100 OME 3" front lift 1.5 rear All Injen cold air Intake N-Fab light bar Hella 500FF lights Alpine Heand unit Type R 10 sub r500.1 amp Alpine 6x8 comps up front Alpine 6x9 in rear
    I'd take them from you if that one wasnt flattened. Great deal tho!!!
  9. Jan 26, 2012 at 7:14 AM
    Digiratus
    Roaming the PNW
    The RedHead
    Thanks Guys!
  10. Jan 26, 2012 at 11:07 AM
    HammerHead
    HammerHead Well-Known Member
    Jake
    Georgia
    04 TRD OffRoad PreRunner SR5 DC
    Couldn't the flattened part be smacked out? Would that even impact the drive or the seal of the tire?
    Hellava deal!
  11. Jan 26, 2012 at 12:18 PM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    I've dented wheels like that before it does't change how they ride, seal or mount.
  12. Jan 26, 2012 at 7:44 PM
    Digiratus
    Roaming the PNW
    The RedHead
    There are places that will "straighten" wheels but on something this minor there's really no need.
    As Adam indicated, that flat area will have no impact on how the tire mounts or balances or rides or wears. If it wasn't pointed out, you wouldn't know its there.
  13. Jan 28, 2012 at 10:37 PM
    all.on.black
    all.on.black Well-Known Member
    Auburn, WA
    06 Double Cab Sport with a few mods
    They will not fit on a 2nd gen due to the caliper size. Unless you get a spacers that pushes the wheel past the caliper. The smallest wheel you can run on a 2nd gen is 16" and even then some wheels don't fit.
  14. Jan 28, 2012 at 10:37 PM
    Digiratus
    Roaming the PNW
    The RedHead
  15. Jan 30, 2012 at 10:09 AM
    gatorboyy13
    gatorboyy13 Well-Known Member
    Brian
    Corvallis, OR
    2016 TRD OR DCSB Black
    CustomCarGrilles Small Perf & "TOYOTA" Grille Insert CaliRaised 31" Light Bar w/ ApexFab Stealth Mounts Header Rail w/Bike Mount
    Bump for an awesome deal! Let me know if you want to sell 'em separately because I wouldn't mind one for a spare.
  16. Jan 30, 2012 at 11:52 AM
    Slodgetto
    Slodgetto Über Posre
    Silas
    As to the bent wheel, we use a "dog-bone" (kinda like a big, double-sided wrench) at Discount Tire to straighten out the lip of steel rims. That works very well and only takes a couple of seconds to do....
    I'm sure a local tire shop would straighten it out for you, for free.
  17. Jan 30, 2012 at 6:33 PM
    tacomacntry
    tacomacntry Joe's Auto Detail
    North East Florida
    Blacked out SR5 4x4
    K&N Cold air Cat back custom dual exhaust
    ship to florida?!?!
  18. Jan 30, 2012 at 8:24 PM
    Digiratus
    Roaming the PNW
    The RedHead
    PM sent
  19. Jan 30, 2012 at 8:26 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Right now I want to sell as a set. If that changes, you will be the first to know.
  20. Jan 30, 2012 at 10:03 PM
    Cvd2312
    Cvd2312 Well-Known Member
    Cory
    Oregon
    2013 DCSB TRD OR
    OME 885’s w/NitroCharger’s 3rd Gen Leaf Pack w/Icon Progressive AAL 265/70/17 Falken Wildpeak’s 17x9 Raceline Defender Wheels
    You go down to the Portland area ever?
