FS: CAMBURG BALL JOINT UCA (BNIB)
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by ambiguous, Mar 11, 2013.
  1. Mar 11, 2013 at 5:23 PM
    ambiguous
    ambiguous [OP] Master Retrofitter @RECHELON/AESTHETICS Vendor
    Burt
    Portland, OR to SoCal
    2012 DCLB TRD
    SOLD
    Toyota Tacoma Pre/4wd ’05-13
    Part Nbr = CAM-310039
    $old
    THESE ARE BRAND NEW. NEVER INSTALLED.
    Specs:
    - Tubular chromoly upper a-arms
    - Re-angled ball-joint to increase wheel travel over stock
    - Increase in positive caster geometry for better handling
    - Energy Suspension polyurethane bushings with thick inner sleeves
    - Uses factory ball-joints and hardware
    - Includes all necessary hardware
    - Stainless steel ABS line clamps
    - Powder coated gray finish
  2. Mar 11, 2013 at 6:57 PM
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    PM sent
    PK
  3. Mar 11, 2013 at 9:04 PM
    El Tano
    El Tano i am the one who knocks
    Pasadena. CA
    10 Tacoma TRD sport
    Corvette homelink FRONT: 5100 Blinstein set at 0 Procomp 3" leveling kit Allpro UCA’s. REAR: Icon Multi Rate RXT Leaf Pack 5100 Blinstein. 17x9 kMC wheels 0 BS 285/70 17 Wildpeak A/T4W C range Amp research steps. and a bunch of TSB's
    2nd in line
