FS: Clean 2006 Silver 4x4 4.0L with mild mods $19k San Diego
Discussion in 'Buy / Sell / Trade - Other' started by erklep, Mar 22, 2017.
  1. Mar 22, 2017 at 5:37 PM
    erklep
    erklep [OP] Well-Known Member
    Erik
    San Diego, CA
    2015 Access cab, 07 Dcsb(Sold), 06 4R(Sold)
    *SOLD*
    First I'll start by saying that I am looking to downsize to a smaller vehicle. I simply do not require a truck any longer and I miss "spirited" driving.
    I am offering up my lightly modified 4th gen to the local T4R and TW family. Located in Southern California- San Diego. My ask is $19k as she sits. It is a 2006 Sport 4x4, 111k miles with the highly sought after black cloth. Sunroof, Power windows/locks/seat, rear power window, steering wheel controls, Downhill assist feature, abs, cruise control, heat and a/c work great. You can see my "build" thread which covers all the history of the vehicle during my ownership. I was a Nissan technician for 8 years and continued to run my own auto repair shop for the last 6 years. I have always gone above and beyond with my personal vehicle maintenance and care. I should also note that I purchased this truck from a very good friend and neighbor for whom I performed all repairs and maintenance so I knew this truck was taken care of and I did not hesitate to make him and offer when he was considering selling it. Clean and clear title, zero accidents, Cali smog tested and problem free. Always maintained mechanically as well as bi-annual professional details...I knew someone :)
    Mods include:
    -Daystar lift kit (F-2.5/R-1.5) Which gave me just over 3 inches over stock height all around.
    -Brand new FJ Off-Road edition Bilstein springs, struts and shocks which came from a showroom take-off vehicle. These provided about an additional 1 in of lift at all four corners.
    -sway bar relocation kit
    -differential drop
    -new tires Feb 2017-255/80/17(33s) BFGoodrich KM2(less than 400 miles on them as of today 3/22)
    -removed secondary filter
    -washable cabin filter
    -husky liners front, rear and cargo area
    -1.5in wheel spacers
    -matte black grill
    -New OEM front bumper and paint
    -window rain guards
    -new black projector headlights
    -5000k hid headlights and 3000 fogs
    -powdercoated wheels satin black
    -fog light mod
    -power always on mod
    -map light/door open mod
    -blackhorse rear safari bar-black
    -reverse light mod- 886 bulb
    -new rear window seal
    -powdercoated step rails and add new hardware
    -Breathermods:
    --transfercase to t-case motor/actuator
    --transfercase/ trans ("T" on passengerside top near o2 sensor)
    --front diff and actuator (factory lines go to DS under hood)
    --rear diff breather line- replaced union and ran hose to fuel filler
    -LED reverse flood/ditch light mounted on frame near spare
    -LED flood light installed in liftgate
    -Nanny disable-vsc/trac mod-free
    -New Scion bluetooth touchscreen unit
    -UCAs Uniball w/ new DirtKing spacer and bushing kit
    -led bulbs in doors, license plate and all map lights
    -cargo storage net for roof
    Maintenance and repair history:
    full 90k maintenance-11/1/15 -95k
    -seafoam in tank
    -half a bottle into crankcase oil
    -half a bottle through vaccumm system
    -1/2 bottle trans tune before flush, 1/2 bottle after
    -transfer case-1.5qt api GL-5oil 75w-90 valvoline synthetic
    -front diff-1.5qt-75w-90(same as t-case)75w-90 valvoline synthetic
    -rear diff-3qts-75w-90 valvoline synthetic
    -pink coolant -flushed till clear and filled 50/50
    -new serpentine belt
    -5 qts synthetic engine oil-5w-30
    -Denso K11 plugs- gap 1.1mm
    -clean MAF sensor
    -clean TB
    -clean injectors ( Techron Concentrate Plus by Chevron)
    -trans-3qts atf--Valvoline max life full synt
    -brake fluid flush-dot 3
    -replace PCV valve
    -grease all driveshaft zerk fittings
    -pulled carpet,mats and seats and steamed and shampooed them
    -lightly sandblasted frame and suspension and applied truck bed liner to protect from rust
    -roof rails repainted
    -replace front pads and rotors with Powerstops(lifetime warranty)
    -new OEM lower control arms
    -new axle boots and grease up front
    -replaced both front calipers due to seizing
    -clean up rust and bedliner skid plates
    -new upstream DS, new downstream DS and PS o2 sensors
    -new DS abs sensor wire- $50
    -new trans selector wire
    -new OEM cam bolts and hardware for LCAs
    -Alignment at Toyota dealer
    -rear brake pads-3/1/17
    -lubed entire suspension
    -CURT front hitch receiver
    WELL... that about covers it! :tongue1:
    Here are some older photos but she has not changed at all except for the front brush guard being pulled off and some larger tires installed. I will get some new photos up in the next few days.(Added a few quick shots)
  2. Mar 24, 2017 at 1:07 AM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 GX550 Overtrail+
    Good looking 4runner! GLWS!
  3. Mar 24, 2017 at 11:00 AM
    erklep
    Erik
    San Diego, CA
    Thank you!
    I should also note that I have receipts for all parts and maintenance items I purchased for the truck.
    And if anyone cares to see some photos of my recent cross-country adventure and the truck out in some cool spots across the nation...
  4. Mar 26, 2017 at 7:44 PM
    Jeffas7
    Jeffas7 Monta what na???
    Missoula
    12quad6spd
    Sweet pics and good looking runner. Just out of curiosity, what kind of smaller sporty rig are you looking for?
  5. Mar 26, 2017 at 10:15 PM
    erklep
    Erik
    San Diego, CA
    Thanks for the compliments. I'm looking into 4 cylinder hatchbacks at the moment. Easier to park and better on gas but I'll still maintain some functional cargo space for camping and excursions. Really considering the new Mazda 3 hatchback. It got excellent reviews. I do really like the GTI too but I have a personal thing against German vehicles. I did want to love the WRX but the newer gens got some not so great reviews. I'm open for suggestions if you know the current market! Nothing brand new but something a few years old, reliable and good on gas while not sacrificing too much power so I can still climb some of the canyon roads and hills out here.
  6. Mar 27, 2017 at 11:29 AM
    Jeffas7
    Missoula
    12quad6spd
    I would love to borrow someone's GTI when I wanted and then give it back when it breaks. :rofl:
    Heard good things about Mazda.
    My wife has a 4 door 09 civic si which always makes daily trips fun. Trying now to decide if its still fitting our needs since we now have a 2 month old. Sounds like we are in the opposite situation you are:thumbsup:
  7. Mar 27, 2017 at 11:36 AM
    erklep
    Erik
    San Diego, CA
    EXACTLY!
    A 4 door civic was also in my considerations if I were to go with an older vehicle. Those little Hondas are tried and true 300-400k mile vehicles. What kind of condition is your Si in?
  8. Mar 27, 2017 at 1:28 PM
    Jeffas7
    Missoula
    12quad6spd
    Stock with exception of tinted windows. No accidents, one owner as we bought it new. 61k on the clock. Normal wear. I tend to keep my rigs pretty clean (maybe not quite as clean as yours), but this is hers so it will usually only get a really good stem to stern clean up couple times a year.
  9. Mar 27, 2017 at 7:16 PM
    erklep
    Erik
    San Diego, CA
    Sounds like an awesome little commuter. Shoot me a PM if you decide to sell it! :)
  10. Apr 11, 2017 at 4:53 PM
    erklep
    Erik
    San Diego, CA
    bump please
  11. May 3, 2017 at 6:14 PM
    erklep
    Erik
    San Diego, CA
    adding some photos from today showcasing the current condition inside and out.
  12. May 11, 2017 at 5:43 PM
    erklep
    Erik
    San Diego, CA
    bump please!
  13. May 19, 2017 at 3:24 PM
    erklep
    Erik
    San Diego, CA
    Bittersweet news to report but the truck has been sold. Thank you to everyone for the compliments and luck. This not the end of 4runners for me. Hopefuly in the near future I can find myself a 2nd or 3rd gen to build.
