FS: Complete Stereo System w/alarm sub, dvd headunit, door speakers, amps, wiring
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by Shack, Mar 3, 2013.
  1. Mar 3, 2013 at 5:03 PM
    Shack
    Shack [OP] Well-Known Member
    Lane
    Chester, VA
    2010 TRD Off Road 4x4
    Bilstein 5100-Front (1.75"), Pop N' Lock Tailgate, Rear Leaf TSB MR. Marv custom box and amp rack, JL 13TW-5, Memphis Audio Amps and Door Speaker, JVC DVD DD HU, Wet Okole, Weathertech Mats, Bed Mat
    I recently traded in my Tacoma Double Cab and I have an entire truck stereo system and alarm for sale. This is an entire, great sounding setup for your Tacoma. I will list each item separately with a description, price, and at the bottom a price to buy the entire setup. Would prefer local pickup or delivery in central VA area but I will ship if buyer pays shipping. Certified Money order preferred but will accept paypal as well. Please PM will any questions or best offers. Low ball offers will be ignored. Thanks for looking.
    1) JL Audio 13TW5 mounted in a MrMarv custom box to fit behind the double cab. Speaker and box have been in use for since March of 2011. Sub and box can not be parted out. They are a package.IMG_1116.jpgIMG_1118.jpg
    $475 SOLD
    2) Memphis Audio 16-MCA2004
    • 4-Channel MClass Series Amplifier
    • Compact Aluminum Chassis with Custon Black Pearl Finish
    • Gold Plated RCA Connectors
    • RCA Outputs: 1 Pair
    • Full MOSFET Design
    • Fully Variable Crossover: HP/LP (40 Hz - 6 kHz)
    • 4-Way Protection Circuitry
    • Platinum Finish Wire Connections
    • Accepts 4 Gauge Power and Ground Wire
    • Optional Wired Remote Gain Control
    • RMS Power Ratings:
      • 50 watts x 4 chan. @ 4 ohms
      • 75 watts x 4 chan. @ 2 ohms
      • 150 watts x 2 chan. @ 4 ohms bridged
    • Adjustable Input Sensitivity: 250mV - 5V
    • Dimensions: 14.1875" L x 7.6" W x 2.4" H
    This amp is approximately 5 years old but was only in use for 2.5 years. This is for the high end 6.5" speakers that will be listed below.
    $100 SOLD
    3) Quantum QB1000D Amplifier
    • 2 ohm mono Amplifier with class "AB" circuitry, Rated at 14.4 volts , 1 x 500 watts @ 4 ohms, 1 x 1000 w @ 2 ohms
    • QSINK heat management system, Buffered pre-amp input circuitry, Continuously variable 12dB low pass-x-over
    • Variable input level control, DC-DC PWM power supply, DC short circuit protection, Bass remote capability, Fuse type ATC 2 x 30 amp
    • Continuously variable subsonic filter( 15-55Hz) (Mono Amps), Direct-connect integrated speaker and power wire terminalsdaisy chain configuration
    • Full range RCA line outputs for easy
    This amp is for low end and really pushed the JL Audio 13TW5 sub nicely. Been installed since March 2011.
    $100 SOLD
    The amps are currently mounted on a MrMarv custom amp rack as seen in the picture.
    MrMarv custom amp rack by itself $60 SOLD
    4) Memphis Audio 6.5" with directional tweeters and crossovers. Immediate and noticeable upgrade when paired with the Memphis amp listed above. Speaker baffle adapters will be included.
    $75 for all 4. SOLD
    5) JVC KW-AVX830 Double Din Headunit
    I am also including the ipod video adapter cables. This unit is new as of March 2011. I am also including the scosche silver adapter with the headunit.
    http://www.crutchfield.com/S-9omUaEU3qyx/p_105AVX830/JVC-KW-AVX830.html#details-tab
    $280 STILL AVAILABLE! Price drop $200
    6) CrimeStopper Security SP-301 2 way Alarm
    Installed since August 2011
    $50 STILL AVAILABLE!!!
    Price for everything seen here is $875 local pickup or buyer can pay shipping. Warning: The speakers and box are heavy so shipping will probably be close to $50 for that alone. Please PM with questions or best offers for part out or entire package.
    EDIT: All the amp wiring and speaker wiring is included. Should be everything you need to wire up the tacoma.
    EDIT 2: The system was installed and uninstalled by car audio professionals.
    EDIT 3: PRICE DROP ON REMAINING ITEMS!
  2. Mar 3, 2013 at 5:30 PM
    68Whiskey
    68Whiskey Well-Known Member
    Richie
    Ft.Bragg NC
    2008 4x4 DC TRD Off Road
    what kind of mounts are those for the speakers?
  3. Mar 3, 2013 at 5:34 PM
    Shack
    Lane
    Chester, VA
    The baffles for the 6.5"s? I dont see a name brand. They are some sort of sturdy plastic. The only thing on them is >PC/PET+GF10<
    They are whatever the installer used to mount them. Thanks for the question.
  4. Mar 3, 2013 at 6:53 PM
    TuFerLife
    TuFerLife 2 4 LIFE!!!
    Taylor
    Chattanooga, TN
    2011 Ford Raptor (I'm a traitor)
  5. Mar 3, 2013 at 7:49 PM
    Shack
    Lane
    Chester, VA
    All PMs received have been responded to.
  6. Mar 3, 2013 at 7:57 PM
    Shack
    Lane
    Chester, VA
    Found a couple of pictures of them box and amp rack installed behind the seat, but they aren't very good. You can see the passenger rear seat folded up and the driver seat fully in place. The amp rack is behind the driver side rear seat. Note: the storage system must be removed for these to be installed. There are tutorials on exact install process somewhere around here on tacomaworld. For some reason I cant find MrMarv's sub forum anymore.
  7. Mar 4, 2013 at 4:09 PM
    Shack
    Lane
    Chester, VA
    daily bump ttt
  8. Mar 13, 2013 at 5:10 PM
    Shack
    Lane
    Chester, VA
    BUMP: double din and alarm are still available. Price drop as well.
  9. Mar 13, 2013 at 6:03 PM
    SteelCityAirman7
    SteelCityAirman7 Decal Commander
    B
    OH-IO!
    05 Tacoma SR5 4x4 TRD
    OEM Roof Rack, pelfreybilt Bed Bar, satoshi grille, tinted headlights and taillights, LED Parking and Reverse, 6000k HIDs, 32" LED Lightbar behind bottom bumper grille(www.okledlightbars.com), TACOMA bed mat, 20% windows tinted all around, plasti dipped front valence/lip, flowmaster dual exhaust, Bedlined Sliders w/ Kickout from AnB Fab
    where the heck does the CD go in that thing?
  10. Mar 13, 2013 at 6:16 PM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    Behind the screen?
  11. Mar 13, 2013 at 6:44 PM
    TuFerLife
    Taylor
    Chattanooga, TN
    More importantly... WTF is a CD?!
  12. Mar 13, 2013 at 7:11 PM
    casrfr224
    casrfr224 Active Member
    joe
    columbia
    tacoma
    are you selling the wiring harness aswell?
  13. Mar 13, 2013 at 7:29 PM
    SteelCityAirman7
    B
    OH-IO!
    Y'all can hate, but I was jw. I saw that it said CD but didn't know the faceplate came off..
  14. Mar 15, 2013 at 10:51 AM
    Shack
    Lane
    Chester, VA
    Yeah the cd/dvd is behind the motorized faceplate. It folds down and detaches if you want it to.
    The wiring harness is included yes. The mounting unit does as well. It is scosche and silver. Matches the OEM damn near perfectly.
  15. Mar 15, 2013 at 1:54 PM
    casrfr224
    joe
    columbia
    tacoma
    Can rear cam added.?
  16. Mar 16, 2013 at 12:01 PM
    Shack
    Lane
    Chester, VA
    I believe it is possible but not 100% sure. I did not have this option installed.
  17. Mar 16, 2013 at 2:27 PM
    casrfr224
    joe
    columbia
    tacoma
    Can you do 150?
  18. Sep 25, 2013 at 11:26 PM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
    Is the head unit still available?
