FS: Custom skid plates for 2006 Toyota Tacoma $400 - SOLD
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by switch, Nov 5, 2022.
  1. Nov 5, 2022 at 2:30 PM
    switch
    switch [OP] Well-Known Member
    Norther California
    2022 Tacoma Access Cab
    These skid plates were made by Bent-Up in Sacramento. 14 years later the just have some scratches and surface rust. They just need a new coat of paint and will be as good as new.
    1: full length skid plate for under the engine and transmission (bolt on).
    2: gas tank skid (you will need to weld a mount to your frame for the back mounts)
    These pics were taken when I first got these. Just to give you more perspectives.
    San Francisco Bay Area
  2. Nov 5, 2022 at 2:55 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Will these fit 3rd Gen 2016+ Tacomas?
    codyjphoto likes this.
  3. Nov 5, 2022 at 4:23 PM
    switch
    Norther California
    I'm not sure. I don't think the frame changed much if at all.
  4. Nov 5, 2022 at 4:29 PM
    Daria
    Daria Can I pet your dog? Moderator
    Dodging tumbleweeds
    I’m going to move this to the second gen section since you don’t know if it will fit a third gen.
    HondaGM and LG888 like this.
  5. Nov 5, 2022 at 4:33 PM
    switch
    Norther California
    Oh duh - posted on the wrong board...
  6. Nov 5, 2022 at 4:41 PM
    Hercanstein
    Hercanstein Well-Known Member
    Bryan
    State of Jefferson
    1999 2.7 SR5 4x4 5MT XC, 2020 3.5 TRD Sport 4x4 6MT AC
    ('99) Offset Aluminium Wheels, 31" BFG All-Terrains, Bushwacker Fender Flares, Window and Hood Wind Deflectors ('20) Stock
    That looks like a BEEFY skid!
    GLWS!
  7. Dec 7, 2022 at 7:23 PM
    switch
    Norther California
    Bump
  8. Jan 30, 2023 at 9:45 PM
    switch
    Norther California
  9. Jan 31, 2023 at 1:58 PM
    TomHGZ
    TomHGZ Well-Known Member
    2014 TRD Frankensport 4x4 AC AT
    Partial list: Vagabond Drifter 3rd Gen OR rear axle 4.30 gears Bilstein 6112s and Tundra 5160s.
    What’s the weight of these? What gauge/thickness sheet metal?
  10. Jan 31, 2023 at 4:45 PM
    switch
    Norther California
    These are 5/32" plate with 1" square tube. The gas tank skid weighs 45lbs. The full length skid is about 125lbs.
  11. Mar 4, 2023 at 8:45 AM
    switch
    Norther California
  12. Apr 5, 2023 at 5:42 PM
    switch
    Norther California
  13. Apr 29, 2023 at 6:56 PM
    switch
    Norther California
  14. May 22, 2023 at 6:57 PM
    switch
    Norther California
    Bump. Make me an offer. Local pick up only. San Francisco Bay Area.
  15. Jun 23, 2023 at 2:41 PM
    switch
    Norther California
  16. Jun 23, 2023 at 2:43 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    bumptity bump
  17. Sep 13, 2023 at 5:37 PM
    switch
    Norther California
  18. Dec 31, 2023 at 2:14 PM
    switch
    Norther California
  19. Jul 10, 2024 at 10:05 PM
    switch
    Norther California
    Pick up in SF Bay Area
  20. Apr 10, 2025 at 8:01 AM
    switch
    Norther California
