FS: DEE ZEE 8537B
Discussion in 'Florida' started by TAC1, May 14, 2013.
  1. May 14, 2013 at 3:28 PM
    TAC1
    TAC1 [OP] Well-Known Member
    Petros "Peter" AGE: 43
    Miami, Florida
    DCSB 4.0 Auto PreRunn
    FRONT: OEM PreRunner coils, 5100's @ .85, MaxTrac Spindles, 1/4" Taco lean spacer. ground to fender base: LF & RF: 40"'s hub to fender base::::: LF & RF: 25"'s REAR: 2012 OEM 3/1 leafs, Wheelers 3 leaf AAL, 2" Tapered steel block. Bilstein F4-BE5-B110-T5 ground to fender base: LR & RR: 41"'s hub to fender base::::: LR & RR: 26"'s All mud flaps trimmed 4"'s shorter.
    Hello Forum,
    I am selling my Dee Zee 8537B tool chest. I am buying a hard tonneau. If not for that I would keep it. Look at the pics for more info & so you can have an idea as to how I installed it. I paid $300 last November, I believe. I am asking for $200. You pay shipping or maybe we can meet halfway. Let me know if you have any questions. Here are the specs:
    Color : Black-Tread
    Part # : DZ 8537B
    Volume : 6.4 Cubic Feet
    Length : 37.125"
    Width 1 : 19",
    Width 2 : 2.4"
    Height 1 : 15.9",
    Height 2 : 13.1"
    Here are the pics:
    This pic shows how it is bolted down on the inside:
    I installed these washers on the handles because the bolts are round but the slots are rectangular so I wanted to eliminate the risk of water going in.
    I removed the plastic DEE ZEE sign so I installed these nuts/bolts so that the holes don't let water in.
    After doing all of this I noticed a flaw in this corner so I had to silicone a tiny hole there. It was too late for me to return it since I already did everything else.
    For added security against water I also drilled one small hole in each corner.
    BTW, The tool tray is included also & it is flawless since I never used it.
    Thanks
    :D
