FS: Extang Black Max soft tonneau cover
Discussion in '1st Gen Tacoma Parts Marketplace (1995-2004)' started by Backinblack03, Dec 4, 2012.
  1. Dec 4, 2012 at 5:21 PM
    Backinblack03
    Backinblack03 [OP] Well-Known Member
    Brian
    VT
    2003 Xtra cab 4x4 2.7/5spd
    ABS sucks.
    Fits 2003 Xtra cab. (And whatever years are the same) Comes with the 4 black aluminum rails, 6 hold down clamps, 3 bows and the cover. Works great in the summer, not so great in the winter. The snaps are reversible to adjust the tension, but up here in VT, it gets mighty cold... (Think Seinfeld "shrinkage") No drilling required. You will probably need new 1" wide x 1/8" thick weather stripping for between the frame and the bed. Local hardware stores will stock it. 2 velcro strips hold the rolled-up cover tight to the front of the bed. 3 bows are spring-loaded and remove for full access. Rear rail detaches above tailgate. Tailgate will open when cover is installed.
    This is the best photo in the daylight I have now, will take more detailed ones if requested.
    $150 shipped OBO from Vermont
    http://extang.com/docs/blackmax.html
