FS: Fox Coils $50 OBO
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by D-Bag, Sep 14, 2021.
  1. Sep 14, 2021 at 9:17 AM
    D-Bag
    D-Bag [OP] Well-Known Member
    Derik
    2014 Tacoma Baja
    I have a few items up for grabs located in the PNW but I am taking a road trip to Southern Idaho in 1.5 weeks so I could bring the goods along with me if needed. I have posted this in both 3rd and 2nd Gen sections because of cross compatibility of some of the items. Please shoot me a message if you have any questions!
    • $SOLD: Bilstein 6112 front coil overs with 600lb springs. These have about 50k miles on them and have seen a fair amount of dirt roads. The springs had about 35k miles before I switched to 650lb springs...I kept the 650lb springs for my new suspension. Longer studs have been installed because I ran a 1/4" spacer on top to increase suspension droop.
    • $SOLD: Bilstein 5160 rear shocks with Tacoma frame mounts. These have about 50k miles on them and have seen a fair amount of dirt roads. Boots have been fitted to protect the shafts. The boots fit loose at the bottom so water and debris could fall out. Both shocks are "right side" versions. Left side shocks were not available when I was in the market for 5160's so I contacted Bilstein and they told me there was not a difference between left and right 5160's so I ordered 2 right side shocks.
    • $50: New Fox 13" 600lb coils springs. These springs came on my new 2.5 coil overs but do not need them. They have a few scuff marks.
    • $SOLD: NIB Pakrax aluminum tailgate panel for Gen2. I purchase this then decided to go with a composite panel instead.
    • $SOLD: "Taco Tabs" from Poly Performance. I purchase these from another TW member but decided to keep my cam adjusters. They have been installed by the other TW member and there is 1 washer missing which is easily replaced. Other than the missing washer they are complete.
    • $SOLD: NIB Firefly FL4 black CB Antenna. This antenna is 4' long.
    • $SOLD: SPC UCA's, these are about 5 years old and have at least one blown ball joint. The pivot bushings are still fine though. These will be available by the end of this week as they are still on my Taco. New UCA's are arriving this week.
    20210913_183512.jpg 20210913_182445.jpg 20210913_183958.jpg 20210913_184232.jpg 20210914_074305.jpg 20210914_074310.jpg
    buckmaster243 likes this.
  2. Sep 15, 2021 at 8:40 AM
    asl0621
    asl0621 Well-Known Member
    Anthony
    SE CT
    2018 SR5 DCLB Quicksand
    Sorry to hijack your thread, I've never seen anyone put boots on the rear billies before. Im getting ready to install mine and like the idea. Do you have a link for the boots?
  3. Sep 15, 2021 at 8:46 AM
    D-Bag
    Derik
    2014 Tacoma Baja
    No problem! I purchased the boots at 4wheelparts: https://www.4wheelparts.com/p/pro-comp-poly-vinyl-shock-boots-black-12127/_/R-DFCW-12127
    They have worked perfectly and have never trapped any crud. The shafts are super clean on the shocks.
  4. Sep 15, 2021 at 8:50 AM
    asl0621
    Anthony
    SE CT
    Thanks for the quick response! Do they sit flush when installed?
  5. Sep 15, 2021 at 8:53 AM
    D-Bag
    Derik
    2014 Tacoma Baja
    They do sit flush at the bottom of the shock when they are at ride height. The boots can be located at any height on the body of the shock so you can set any gap you want.
  6. Sep 22, 2021 at 8:39 AM
    D-Bag
    Derik
    2014 Tacoma Baja
    Bump. Still have the Fox Coils and Taco Tabs for sale. Make offer!
