FS: FX-R / Mini RETROFITS and BHLM (NO DOWN TIME!)
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by ambiguous, Nov 4, 2012.
  1. Apr 9, 2016 at 8:39 AM
    #2581
    RAD
    RAD Well-Known Member Vendor
    Rad
    LAX & LOGAN
    If you're worried about the Laws, go with the amber and get it light to medium tint only. Make sure the Amber is still here but has that nice even flow with the MGM Paint. Nice job on that and can't wait to see it done! Get it done now!
    TRSJimmy[QUOTED] likes this.
  2. Apr 9, 2016 at 10:20 AM
    #2582
    TRSJimmy
    TRSJimmy All I Do Is Nguyen
    Jimmy
    Gainesville, GA
    12' Mall Crawlin Peerunner
    I may do that and get it from dk moulds. Is this the new/main rechelon page now?
    https://www.tacomaworld.com/threads...em-tacoma-retrofit-headlight-services.422025/
    squint0241 likes this.
  3. Apr 9, 2016 at 11:59 AM
    #2583
    1bad2k
    1bad2k Well-Known Member
    Lone Star State
    2017 Tacoma TRD PRO
    Awesome, thanks! Yeah I just sent it last night. Is the controller the gold little box on the full harness?
  4. Apr 9, 2016 at 12:00 PM
    #2584
    TRSJimmy
    Jimmy
    Gainesville, GA
    You are correct!
  5. Apr 9, 2016 at 7:04 PM
    #2585
    TacomaArto
    TacomaArto Well-Known Member
    Wisconsin
    2015 White DCSB SR5
    What is the difficulty level of wiring halo's to DTRL? Anyone know?
  6. Apr 9, 2016 at 7:40 PM
    #2586
    TRSJimmy
    Jimmy
    Gainesville, GA
    Super easy, but wiring the switchback function is a little different.
  7. Apr 9, 2016 at 7:42 PM
    #2587
    TacomaArto
    Wisconsin
    2015 White DCSB SR5
    "Switchback" being having a separate switch in cabin for the halos?
  8. Apr 9, 2016 at 7:46 PM
    #2588
    TRSJimmy
    Jimmy
    Gainesville, GA
    Well nowadays, TRS has their newest halos with the ability to go from full white and switch to amber and blink when you use your turn signals.
  9. Apr 10, 2016 at 3:29 AM
    #2589
    jamiec
    jamiec Man who keep hands in pockets feel cocky all day
    Jamie
    Chillicothe, Ohio
    2017 Prius three touring. Sold the Taco
    I have mine wired to switched ignition source. This way they are on as soon as I start my truck and I don't use my factory dtrl, I just use the halos for that purpose.
    TRSJimmy likes this.
  10. Apr 10, 2016 at 5:50 AM
    #2590
    TRSJimmy
    Jimmy
    Gainesville, GA
    Unforunately, 2012s-maybe 2013/14 don't have the option to switch it off. It's always on.
  11. Apr 10, 2016 at 6:06 AM
    #2591
    TacomaArto
    Wisconsin
    2015 White DCSB SR5
    2015's able to?
  12. Apr 10, 2016 at 8:05 AM
    #2592
    TRSJimmy
    Jimmy
    Gainesville, GA
    I believe you have the option to turn it off with your headlight stalk
  13. Apr 10, 2016 at 9:13 AM
    #2593
    jamiec
    Jamie
    Chillicothe, Ohio
    My 2015 has the option. It goes from off, dtrl, parking lights then headlights.
  14. Apr 10, 2016 at 9:51 AM
    #2594
    TacomaArto
    Wisconsin
    2015 White DCSB SR5
    Ahhh yes. I misinterpreted that maybe it was literally a design dif between 2015 and othwr years.
    When i get some of these i want to be able to not have my halos on 24/7. So i am trying to figure out best way. I was thinking a dedicated switch in the cabin, but now kinda feelin DTRL may be an OK option.
    Just wanna increase lifespan of halos is main goal...
  15. Apr 10, 2016 at 10:45 AM
    #2595
    TRSJimmy
    Jimmy
    Gainesville, GA
    Well their newest v2 halos are a lot better than their cob versions. More reliable. The resistors are external, vs internal so heat won't be the issue here.
    I still have their v1 and it's constantly on. Their v2 is even more reliable and brighter
  16. Apr 10, 2016 at 12:35 PM
    #2596
    ThomasMore66
    Dallas/Fort Worth & Durango
    My 2013 is the same.
  17. Apr 10, 2016 at 12:44 PM
    #2597
    squint0241
    squint0241 OVRLND
    Rick
    Tropics
    '14 DCSB/Off-Road 4X4
    Bone Stock
    I ran mine to a separate on/off switch. I like them on in any mode I prefer. I think they look good running without the DTRL's...or with..:D
  18. Apr 10, 2016 at 12:47 PM
    #2598
    squint0241
    squint0241 OVRLND
    Rick
    Tropics
    Bone Stock
  19. Apr 10, 2016 at 1:15 PM
    #2599
    TacomaArto
    Wisconsin
    2015 White DCSB SR5
    How long have u been running v1's?
  20. Apr 10, 2016 at 3:18 PM
    #2600
    TRSJimmy
    Jimmy
    Gainesville, GA
    since they released it :D
