FS: FX-R / Mini RETROFITS and BHLM (NO DOWN TIME!)
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by ambiguous, Nov 4, 2012.
  1. Apr 10, 2016 at 4:36 PM
    #2601
    jamiec
    jamiec Man who keep hands in pockets feel cocky all day
    Jamie
    Chillicothe, Ohio
    2017 Prius three touring. Sold the Taco
    1 trouble free year for me
    TRSJimmy likes this.
  2. Apr 10, 2016 at 5:12 PM
    #2602
    TRSJimmy
    TRSJimmy All I Do Is Nguyen
    Jimmy
    Gainesville, GA
    12' Mall Crawlin Peerunner
    There you go. Basically, their old halos were COB. Looks great but unreliable, because the resistors were built onto the board itself. Heat was the biggest enemy.
    Now, with their newest halos, the resistors are actually external and also uses micro SMDs. Much more reliable but doesn't look uniform (like led concept). So TRS mixed what they knew about the uniformity look of COBS and combined that into their xsb halos; a hybrid. This gave you the best of both worlds, reliability of SMDs and that uniform look of COBs.
    And if it goes bad, it's just as simple as replacing the resistor box.
    :D
    squint0241 likes this.
  3. Apr 10, 2016 at 5:33 PM
    #2603
    jamiec
    Jamie
    Chillicothe, Ohio
    I hope you didn't take it as I have problems now because I don't. Mine are still working like new
  4. Apr 10, 2016 at 6:00 PM
    #2604
    TRSJimmy
    Jimmy
    Gainesville, GA
    Oh no, I was stating that youre trouble free because you have the updated version vs the old ones!
  5. Apr 10, 2016 at 6:01 PM
    #2605
    jamiec
    Jamie
    Chillicothe, Ohio
    Oh ok. Just wanted to make sure
    TRSJimmy[QUOTED] likes this.
  6. Apr 13, 2016 at 4:56 AM
    #2606
    ThomasMore66
    Dallas/Fort Worth & Durango
    I struggled a bit with mounting the ballasts, etc. some of you suggested zip ties and 3M tape, but I wanted something screwed/bolted in. I beat down a path of making brackets and ultimately I didn't like what I had. Stole an idea from another member on this thread and ended up with this. Seems clean to me.
  7. Apr 13, 2016 at 6:24 AM
    #2607
    TRSJimmy
    Jimmy
    Gainesville, GA
    Looks good to me!
  8. Apr 13, 2016 at 7:18 AM
    #2608
    RECHELON
    RECHELON RETROFIT HEADLIGHTS
    RECHELON AESTHETICS
    SoCal to Portland
    DCX2
    A great solution for mounting. Thanks for sharing!
  9. Apr 17, 2016 at 3:42 PM
    #2609
    mrbedgood
    mrbedgood Isaiah 6:8
    North Carolina
    '11 MGM DCSB TRD Off Road 4x4
    Total Chaos +2" Long Travel Kit; King/TC 2.5 LT C/O w/ 16"x600; TC/CVJ Extended Axles; TC Spindle Gussets; King 2.5 RR shocks; All-Pro Expendition Leaf Pack; Pelfreybilt Sliders; Anti-Dark LED Hood Light mod; LED map and dome light mod; Bed lights; TRD Cold Air Intake; KB Voodoo Tailgate cap system; HomerTaco Thin Lip "Raptor" grille; sPod SE System w/ LCD Touchscreen; Baja Design OnX6 40"; Baja Design S2; Rigid Industries LED Rock Lights; Front Runner Slimline II Roof Rack; A.R.E. Z Series Camper Shell Projector BHLM Headlights (with custom wiring); Method Racing NVs 17"x 8.5; and Nitto Terra Grappers 265/60/17
    @fafafahey I have not had any moisture issues what so ever. I have not had one issue since mounting it there. It was totally worth the time and effort it too mount it the way I did. Got everything out of the way and makes it look more stock. I do wish I had mounted it just a little bit lower but I can always mount something below it, maybe a ARB compressor.
  10. Apr 30, 2016 at 9:17 AM
    #2610
    MattB77
    MattB77 Well-Known Member
    OR
    2013 AC TRD Sport
  11. Aug 2, 2016 at 7:47 AM
    #2611
    1bad2k
    1bad2k Well-Known Member
    Lone Star State
    2017 Tacoma TRD PRO
    Anyone heard out of these guys in a while?
  12. Aug 2, 2016 at 8:37 AM
    #2612
    TacomaArto
    TacomaArto Well-Known Member
    Wisconsin
    2015 White DCSB SR5
    Who? @RAD ?
  13. Aug 2, 2016 at 9:01 AM
    #2613
    1bad2k
    Lone Star State
    2017 Tacoma TRD PRO
    Yeah I shot him an email this morning. I've had a set on headlights that don't function properly from the first day I recieved them about 4 months ago. I'd like to finish this deal up and enjoy my lights that's I've got $1700 into.
  14. Aug 5, 2016 at 12:08 PM
    #2614
    RAD
    RAD Well-Known Member Vendor
    Rad
    LAX & LOGAN
    ^ Sam,
    I am working with Burt to figure out why your high beams are not working properly. He is the one who build them and I know you've been trying to figure that feature out. We tested it twice prior to shipment and trying to figure out why that could be an issue. Sorry I've been gone handling family business in Las Vegas and have been lacking in communication. I am back up in Portland now handling work and getting things in order.
    Kind regards
    Rad
  15. Aug 5, 2016 at 1:56 PM
    #2615
    ChemDawg
    ChemDawg Well-Known Member
    Maine
    2005 sr5 4x4
    $1700 ?!! :eek::puke:
    1bad2k[QUOTED] likes this.
  16. Aug 6, 2016 at 9:04 AM
    #2616
    1bad2k
    Lone Star State
    2017 Tacoma TRD PRO
    Thanks for the reply Rad. I shot you an email a week or so ago, whenever you get a chance to check it out. I haven't heard from Burt.
  17. Aug 6, 2016 at 9:05 AM
    #2617
    1bad2k
    Lone Star State
    2017 Tacoma TRD PRO
    Yes unfortunately, but you gotta pay to play. It's not the typical budget retrofit as I took every upgrade he offered and used a set of brand new OEM trd pro headlight housings.
  18. Aug 9, 2016 at 12:07 PM
    #2618
    RAD
    Rad
    LAX & LOGAN
    The set is an amazing and beautiful build as Sam knows. When you're working with higher genuine oem parts and not the cheaper aftermarket parts, the price does reflect that. I'll be working with Burt to figure a solution out for that high beam issue. The bright side of that is, the OEM projectors should be bright enough in the mean time. ;)
    Why do some guys spend $500 on suspension while others spend 3k. It's all preference and when you compare the difference in projector outputs, its night and day in performance.
    TRSJimmy, Island Cruiser and 1bad2k like this.
  19. Aug 10, 2016 at 4:36 AM
    #2619
    ChemDawg
    Maine
    2005 sr5 4x4
    Yes. & I'm sure the diy retrofit headlights pale in comparison to your headlights.
    I was just surprised at the cost.
  20. Aug 13, 2016 at 11:23 AM
    #2620
    brightshizzle
    brightshizzle Well-Known Member
    Nashville, TN
    2012 Tacoma, TRD, DCSB, 4WD
    Interested PM sent
