FS:FX-R Retro/Mini Retro
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by AsianAnts, Oct 1, 2011.
  1. Oct 2, 2012 at 6:15 AM
    #321
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I've been sifting through threads on HID planet and haven't found anything on it besides with the Blazers. When my projectors come, I'll see if they install with the return wire down from the factory. Someone made a comment on HID Planet:
    "As you can see, I have modified the base of the bulbs to allow the return wire to be DOWN, as with any legitimate HID projector, for best output."
    He was referring to modifying the bulb for the Blazers but sort of implys that you normally wouldn't have to make that modification on a 'legitimate' projector. Time will tell... If I find something definitive, I'll post back.
  2. Oct 9, 2012 at 12:40 PM
    #322
    AsianAnts
    AsianAnts [OP] just an AnT
    AnT
    Southern California (San Diego County)
    2011 PreRunner TRD Sport L/B Grey Metallic
    -Satoshi Grille Upper/Lower/Triangles -LED Map Lights, LED Dome Light, LED License Plate Lights -No front license -Wet Okole -Weather Techs (digi) -Running Boards -Bed Extender -AFE Cold Air Intake 2SI Dry Filter -Tailgate Hose-Clamp Mod, Tailgate washer Mod -Combi chain lock on bed extender -no chime w/ key in ignition & open door -Fog Light anytime -Slim Cubby's 3kHID fog -bumper plugs -keyhole plug -TRD license plate frame -combi-lock storage -rear TSB -window tint -camera mod -Painted radiator/engine covers -LS460 RetroFit -Bed Tie-Downs -LED Gauge Cluster, radio, clock and AC -Bed Mat -Extra DRings -Painted center console, radio unit, ac panel, overhead console.
    DUE TO TRAVELLING (mission trip to Cambodia) ALL ORDERS/SERVICES WILL RESUME NOVEMBER 1, 2012. ORDERS/SERVICES WILL BE A FIRST COME FIRST SERVE BASIS. THANK YOU
  3. Oct 26, 2012 at 8:28 AM
    #323
    AsianAnts
    AnT
    returned!
  4. Oct 26, 2012 at 8:33 AM
    #324
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    :spy: me and you need to speak in person soon
  5. Oct 26, 2012 at 8:39 AM
    #325
    AsianAnts
    AnT
    alright mister heh.. I should be up next weekend visiting during the day.
  6. Oct 26, 2012 at 8:52 AM
    #326
    Jerez
    Rod
    Ontario Ranch
    Estock
    gotta pay you...sounds good
  7. Nov 2, 2012 at 8:19 PM
    #327
    AsianAnts
    AnT
    postponed to next sat!
  8. Nov 2, 2012 at 9:04 PM
    #328
    Jerez
    Rod
    Ontario Ranch
    Estock
    :facepalm: alright sounds good :thumbsup:
  9. Nov 2, 2012 at 9:12 PM
    #329
    JustinL
    JustinL Well-Known Member
    Justin
    Berlin, CT
    2009 TRD OffRoad DCSB Pyrite Mica
    2012 Conversion
    Bump for a great guy who does some kick ass work
  10. Nov 3, 2012 at 8:39 AM
    #330
    waheed
    waheed Well-Known Member
    Waheed
    Vancouver
    2010 Tacoma TRD OFF-ROAD
    Banks power Exhaust, 4x4 LED mod, Duratracs, SNUGTOP, LED insideNout
    At $750 a pair, that's a tough cookie to swallow :notsure:
  11. Nov 3, 2012 at 8:51 AM
    #331
    95SLE
    95SLE Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
    As one who did his own retrofit $750 is a really decent price. Even if you do not factor in the cost of a set of donor headlights the cost for parts needed to do the job is close to $500. This includes paint if you want to black out the headlamps. Then there is a cost of any tools you would need to buy. If you hustled and everything went well it would take you close to 4 days to do the job. Most of that time is waiting for paint to dry.
    I do agree it is a tough cookie to swallow but swapping out a set of headlamps should only take a few hours.
  12. Nov 7, 2012 at 2:23 PM
    #332
    sk8rjess
    sk8rjess IG: @whoishack
    Cody
    Nashville, TN
    02 4x4 sr5
    some duct tape and zip ties
    holy crap $500 for fxr's? where the heck are you ordering from? you need new supplier, dude.
  13. Nov 7, 2012 at 2:47 PM
    #333
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    TRS.
    The stage IV is $410. With CCFL and sealing compound add $35.
    http://www.theretrofitsource.com/product_info.php?products_id=205
    You can purchase through a group buy, if one one is currently running, or purchase a less expensive FXR setup.
    By the time you add in paint to black out the housing you are close to $500.
    Paint included an adhesion promotor, primer for plastic, and color matched BSP paint.
    There is also a cost for misc hardware to mount and seal the FXR to the reflector bowl.
  14. Nov 7, 2012 at 3:06 PM
    #334
    sk8rjess
    Cody
    Nashville, TN
    02 4x4 sr5
    yes the stage 4 is, but he's not selling the stage 4 so why advertise that price?
    that kit starts at $315. if someone REALLY wants the ccfl halos, that's $25. the glue i've never seen a need for, nor needed on the 20+ retros i've done for clients, but okay let's add $10 for that. $350 for parts. paint including adhesion promoter would be maybe $10-15 tops - you're not using a whole can per customer are you? no need to charge full price for that stuff then. hardware - i've never spent more than $20. all the hardware for my truck retro costed MAYBE $10 from Lowes. that's also all stainless steel stuff.
    so, estimating pretty high on paint and misc hardware you're at $370-$380.
    the whole reason to me even saying anything, is people don't want to pay so much for retros, so why over charge? especially when OEM products aren't being used.
    don't take this the wrong way, i'm not bashing anything or anyone here but i'm sure some people would love to hear why it's all so expensive.
  15. Nov 7, 2012 at 3:21 PM
    #335
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    I did not tkae it the wrong way. This was the cost to me to do mine on the Tacoma. If there is a TRS group buy going on you can save yourself $100 off the cost.
    I found the project pretty streight forward with some nervous moments during the project. Overall I would give the project a difficulty of 8 on a scale of 1 to 10. Not that it was hard but there are a few places wher you can really do damage to the donor headlamps.
    I will say that AA was very helpful and provided information freely.
  16. Nov 7, 2012 at 3:25 PM
    #336
    ambiguous
    ambiguous Master Retrofitter @RECHELON/AESTHETICS Vendor
    Burt
    Portland, OR to SoCal
    2012 DCLB TRD
    Buy/Sell/Trade rules [Revised 6/28/2012]
    DO NOT BASH for sale threads in what you think is a good price to sell an item. PM the OP and give them a suggestion.
    The seller can ask whatever price he wants. If someone want's to bargain, that's up to them but way to ruin the guy's thread.
  17. Nov 7, 2012 at 3:34 PM
    #337
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
    :thumbsup:
  18. Nov 7, 2012 at 3:49 PM
    #338
    sk8rjess
    Cody
    Nashville, TN
    02 4x4 sr5
    for the record i'll once again state that i WASN'T bashing.
    i was saying why explaining his pricing may be beneficial for his sales since $750 for headlights seems unjustifiable to some customers.
  19. Nov 7, 2012 at 4:40 PM
    #339
    AsianAnts
    AnT
    To all inquiring minds. The FX-R stage 3 kit is $315 plus your accessories, tax, ship and such it can run up to $370-$380 (jump on a group buy and its cheaper, 25% cheaper)
    A used OEM Tacoma headlight runs roughly $120 for a pretty good set.
    so far that is about $500.This service, though may be easy for some, takes time regardless. My fastest stills take a whole Saturday to work on a pair! That is if I'm lucky and I don't come across any complications (minor alignment issues, JB glue not dry, any other misc. modifications to the shroud/projector/light). I understand it can be a little bit hard to swallow. I paid about the same amount, if not more, when I first bought a set.
    For other people who are reading this, should you have any questions. Please feel free to PM me. "sk8rjess" I appreciate the PM and your concern for my pricing.
    For the record, though I've done many retrofits and have the experience/knowledge, it still takes a day or more to complete.
  20. Nov 10, 2012 at 2:22 PM
    #340
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    You expect him to work for free?
    Disassemble the housings, cut the reflectors, mount the projectors, dummy up the housings in an aiming jig, fire them up, get the projector position close enough so that the finished product can be aimed with the adjusters, etc....
    Ants isn't just buying and repackaging a bunch of shit.
