SOLD: GMF/Arcticelf Bolt on Rear Shock Relocate for 2nd/3rd Gen
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by SUMOTNK, Apr 19, 2021.
  1. Apr 19, 2021 at 4:20 PM
    SUMOTNK
    SUMOTNK [OP] Pavement Pounder / Mall Crawler
    Eddie
    NorCal/South Bay Area
    Looks like a Gen2.5 TRD Sport, but really an '08 TRD OffRoad
    TRD Supercharged / OTT Tuned
    Brand new, never installed. GMF/@Arcticelf bolt on rear shock relocate kit for 2nd/3rd Gen Tacomas.
    Complete info on this product can be found in this thread.
    https://www.tacomaworld.com/threads...elocate-for-2nd-3rd-gen-ready-to-ship.691150/
    Kit was never installed nor mocked up and includes all hardware. Because I was being fickle, I went a different direction for the rear suspension.
    Ratty rattle can paint job was done by yours truly. Save $25 because of that.
    $300/shipped to the lower 48. AK/HI extra.
    20210419_160218.jpg 20210419_160317.jpg 20210419_160333.jpg 20210419_160416.jpg 20210419_160411.jpg 20210419_160342.jpg 20210419_160433.jpg
    WRDD Taco, Arcticelf and GhostTRD4x4 like this.
  2. Apr 19, 2021 at 4:43 PM
    GhostTRD4x4
    GhostTRD4x4 IG: @taco_mudmaster
    2019 TRD 4x4
    this is pretty cool, is this mod cater for a type of build like a prerunner type? Just a wondering.
    Arcticelf and SUMOTNK[OP] like this.
  3. Apr 19, 2021 at 5:22 PM
    SUMOTNK
    Eddie
    I think it was discussed in that original thread but these relocate products allows for the installation of shocks with more travel (+4‐5in ?) versus stock. That extra shock travel can be beneficial for all types of offroad activities (crawling, bombing, etc) afaik.
  4. Apr 19, 2021 at 5:29 PM
    GhostTRD4x4
    2019 TRD 4x4
    I’m really digging this, I’ll do more research about this mod. Thank you for the info.
  5. Apr 19, 2021 at 7:02 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    I really recommend these! @Arcticelf knows his stuff. Its a bolt on rear shock relocation. And a very good price OP!
  6. Apr 20, 2021 at 5:13 AM
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    Longer rear shocks let you get the most out of whatever spring pack you're running. Which spring pack you choose is based on what you're going to use the truck for and your driving style.
    ETA: There are two differences between this kit and the others on the market: 1) it's bolt on so you don't need a welder or a friend with a welder 2) the shock mounts about 2" higher so the bottom of the shock is in line with the axle to clear rocks better.
  7. Apr 21, 2021 at 7:56 AM
    GhostTRD4x4
    2019 TRD 4x4
    so the one that is posted is the bolt on one correct? Also I’ve done a lot of mods on the truck but nothing major yet on the side of the chassis. I just to be sure on my next step of upgrades. I really appreciate all the info tho. Thank you!
    SUMOTNK[OP] likes this.
  8. Apr 21, 2021 at 8:03 AM
    Arcticelf
    Gladiator
  9. Apr 21, 2021 at 8:57 AM
    WRDD Taco
    WRDD Taco Big Hobby Guy
    Jake
    Delco, PA
    ‘11 TRD Sport DCLB LT 1G3 Moto Express
    TC Mid Travel +2, TC SUA, king shocks, Swamp Donkey/Rigid lighting, Mechman alt, SOS/Boztek armor, ATH Fab tiedown, full active JL/Audiofrog sound system, NOICO sound deadening EVERYWHERE. Up next: roof/bed rack + dry storage, skids, bumpers, fiberglass, power wire upgrade + frame grounds, LTO battery swap, air compressor, on board pressurized water, powered cooler, suspension seats, frame reinforcement, solid motor/trans mounts.
    GhostTRD4x4 likes this.
  10. Apr 21, 2021 at 9:05 AM
    Brian422
    Brian422 I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
    yes he did, here's them on my truck. well build kit. Have put it through some rough stuff no problem.
  11. Apr 21, 2021 at 12:00 PM
    WRDD Taco
    Jake
    Delco, PA
    Nice! Those are great down travel numbers for SOA and with how the shock mounts are configured on the axle that thing has great rock clearance as well. Thanks for sharing pics!
  12. Apr 21, 2021 at 2:05 PM
    Arcticelf
    Gladiator
    I designed them around the "standard" aftermarket SOA leaf packs: dakar, AP, etc. Because you can adjust the axle tab placement getting the shock to clear the U-bolt plate and tire and frame is relatively easy, although if you have a cheap Amazon U-bolt flip plate it may need the corner trimmed off (ask me how I know:).
    They should work just fine with a SUA too, although I haven't tested that.
    If you're doing a 63" swap or other big changes to spring hanger geometry this setup may require a little bit of modification to work, but if you're taking on a project like that the shock hoop will be the easy part.
  13. Apr 26, 2021 at 12:44 PM
    SUMOTNK
    Eddie
    BUMPITTY
  14. May 5, 2021 at 11:27 AM
    SUMOTNK
    Eddie
    Bumpie
    fatfurious2 likes this.
  15. May 6, 2021 at 12:21 AM
    SUMOTNK
    Eddie
    SOLD
    Brian422 and Arcticelf like this.
