FS: Hifonics ZX8000 5-Channel Amp
Discussion in 'Buy / Sell / Trade' started by ENIGMA206, Dec 5, 2009.
  1. Dec 5, 2009 at 7:37 AM
    ENIGMA206
    ENIGMA206 [OP] Well-Known Member
    Palm Bay, FL
    07 4X4 Off-Road DC
    Tunes Tonneau On-board Air Firestone Air Bags
    I have a gently used Hifonics ZX8000 5-Channel amplifier for sale. It works perfectly. No issues with it at all. Cosmetically it looks good. No major scratches or anything like that. I'd like to get $75 for it and buyer pays actual shipping, probably around $25 to ship. I am throwing in power wiring and various parts of the install kit. You may not be able to use it, but I'd rather send it than throw it away. Here are the specs.
    2 ohms power output: 110 watts x 4 channels + 300 watts x 1 channel
    4 ohms power output: 55 watts x 4 channels + 200 watts x 1 channel
    New Hifonics Twentieth Anniversary Heat Sink Design
    Illuminated Hifonics Badge
    Illuminated Maxxsonics "M"
    Bass Remote not included
    Ultra-Fi Mosfet
    Zeus EVXP (Exponential Vari-Power Supply)
    SPC - Simpatico Coil Design
    HSMD - Hifonics Surface Mount Design
    Fully Adjustable Accu-Cross Crossovers
    PWM Mosfet Power Supply
    Line Output for Amplifier Daisy Chaining
    Variable Bass Equalization
    Sub-Sonic Filter
    4 Gauge Power Connectors
    Additional High Speed Mosfet Output Devices
    Class AB Operation
    Maxi-Fuse
    Power From The Gods Included
  2. Dec 6, 2009 at 7:01 AM
    ENIGMA206
    Palm Bay, FL
    07 4X4 Off-Road DC
    Bump, bump.
  3. Dec 7, 2009 at 4:54 AM
    ENIGMA206
    Palm Bay, FL
    07 4X4 Off-Road DC
    Offers welcome? Bump.
  4. Dec 7, 2009 at 6:05 AM
    hendooman
    hendooman The Stroker Ace
    Jeff
    KC
    2009 Tacoma OR (SOLD); 2015 TRD PRO 4Runner
    Where in your DC did you have this amp mounted? Was it under the seat or in the back on a rack?
    Also is the 4 gauge power supply long enough to get to the battery from the cab?
  5. Dec 7, 2009 at 6:46 AM
    ENIGMA206
    Palm Bay, FL
    07 4X4 Off-Road DC
    It was mounted behind the left, rear seat. I can send pics of the original install. Yes, the power cord was long enough, but barely.
  6. Dec 7, 2009 at 6:48 AM
    hendooman
    Jeff
    KC
    Was there any chance it would fit under the pass seat?
  7. Dec 7, 2009 at 8:28 AM
    ENIGMA206
    Palm Bay, FL
    07 4X4 Off-Road DC
    I would say no unless you removed the plastic duct. When I was doing my install, I did slide it under the seat and it did fit height-wise. The thing I didn't like was that it sat on the floor duct and passengers in the back would be kicking connections.
    Here is where I ended up putting it:
  8. Dec 7, 2009 at 10:33 AM
    hendooman
    Jeff
    KC
    OK, I appreciate you looking that up for me. I am going to have to pass as I am going to need for it to sit under the passanger seat. The Alpine PDX 5 is about the only option, but they are $$$. Have to wait, thanks again.
  9. Dec 7, 2009 at 11:34 AM
    07TacoRidah
    07TacoRidah SHHHH, this is interesting
    2007 Base Model Access Cab
    Engine bay: aFe Pro Dry filter Secondary air filter deleted Sokie Tech hood damper kit Xscorpion dual 0g wire ring terminal (3) Big 3 upgrade (0g wiring) HID kit (headlights, H1 - 8k) HID kit (fog light 3k) Sylvania Zevo LED turn signals w/hyper flash resistors Rear back up light GY6 bulb Bullz Audio 0g wire Exterior: Dynamik Retro Projector style headlight housing Depo Euro Black Altezza LED tails Front grille swap (to chrome, painted w/bedliner paint) XR front bumper valance (dipped red) Aftermarket fog light kit w/OEM switch Rear bumper swap (to chrome, painted w/bedliner paint) 99 Cents Store tailgate lock Suspension: DJM 3/4" drop kit 1" spindle spacer kit 4x4 leaf pack swap (middle leaf removed) Air Lift rear helper springs Rims: 18x10 Work VS-KF front w/5" lip 18x11 Work VS-KF rear w/6" lip 225/40/18 tires all around Neochrome lock nuts Pepboys valve stem caps Interior: Wink Mirror rear view Center console lid fabric Metra Dash kit Kenwood bluetooth headunit Hifonics Zeus ZXi 6410 PB 6 1/2" component speakers up front 10" JBL GTO 1014 (2) 4 ohm svc in dual ported box JDM Fuchsia shift knob (Crown Royal shift boot)
    damn, I could use this in my Blazer.
  10. Dec 7, 2009 at 11:38 AM
    ENIGMA206
    Palm Bay, FL
    07 4X4 Off-Road DC
    Sho me da moneeeeyyyyyy!!!!!
  11. Dec 8, 2009 at 4:58 AM
    ENIGMA206
    Palm Bay, FL
    07 4X4 Off-Road DC
  12. Dec 9, 2009 at 3:05 PM
    ENIGMA206
    Palm Bay, FL
    07 4X4 Off-Road DC
    $90 shipped within U.S.
