FS: ICON 2nd gen extended travel front coilovers
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by oshawa tacoma, Mar 11, 2013.
  1. Mar 11, 2013 at 1:55 PM
    oshawa tacoma
    oshawa tacoma [OP] Active Member
    Hello, looking to sell my icon front extended travel coilovers. They are just over a year old and with about 7800 miles on them. Comes with the spanner shown. But please note the one tab on the spanner is broken.
    Looking for $750 shipped or obo
    Located in whitby, ontario
  2. Mar 12, 2013 at 11:31 AM
    oshawa tacoma
  3. Mar 12, 2013 at 1:05 PM
    jobrien
    jobrien shit happens then you die
    Josh
    Ontario California
    2011 single cab base 4x4
    Bed mat, cleats, scangauge, new headlight bulbs, weather techs, more to come
    P.med
  4. Mar 12, 2013 at 2:15 PM
    oshawa tacoma
    Pm replied.
  5. Mar 12, 2013 at 2:59 PM
    max2
    max2 Well-Known Member
    Gary
    Ruidoso, NM
    Is there anything wrong with them - do they function fine?
    Do you know what the spring rate is on these?
    Are the threaded shock collars in good condition?
    Very interested in buying these.
    Thanks.
  6. Mar 12, 2013 at 11:29 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    Looks like he sprayed them with wd-40 before adjusting height??? But they come with 650lb spring rate. You'll also need new uca's for ext travel!
  7. Mar 12, 2013 at 11:44 PM
    superwhite
    superwhite Well-Known Member
    sean
    Western NC
    07 double cab 4x4
    Dana 60 rear Chevy 63's shackle flip mid travel gears lockers and 38's in progress
    good deal for our canadian friends, bump for the op.
  8. Mar 13, 2013 at 4:23 AM
    oshawa tacoma
    The stock spring rate is 650 like stated above. The threads are in good condition. I sprayed them regularly because of where I live to prevent corrosion as well as using anti seize on the threads. They are in good working order.
  9. Mar 13, 2013 at 4:36 AM
    jimbo808
    jimbo808 Well-Known Member
    Kapolei, Hawaii
    05 TRD Sport 4x4
    Debadged, Mbrp cat back turn down, Afe drop in filter, Icon extended travel, Light Racing ucas, Dakars, Icon 2.0 vs monotubes, 285/70r17 goodyear kevlar Mtrs, Morimoto Minis D2S' bhlm with blacked out bowls, Bamf Sliders, pelfrey single hoop front bumper, smittybilt X20 10k, pelfrey ifs skid, pelfrey trans skid, all pro rear with side plates, sway bar removed, front superbumps, Avec 20 inch light bar, rigid flood fogs
    sent you a pm
  10. Mar 13, 2013 at 8:09 AM
    max2
    Gary
    Ruidoso, NM
    PM sent. Hopefully you can ship to the lower 48 states.
  11. Mar 13, 2013 at 9:25 AM
    oshawa tacoma
