FS: ICON Tacoma 2.5 VS RR Coilover Kit + Tacoma 0.15" Rear 2.5 VS RR CDCV PAIR
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by McDangle, Feb 21, 2022.
  1. Feb 21, 2022 at 9:50 PM
    McDangle
    McDangle [OP] Known Booper
    Mc Dangle
    33" 07 5 Lug
    All of Themz
    ASKING $800 FRONT
    ASKING $700 REARS
    05-UP Tacoma 2.5 VS RR Coilover Kit 0-3.5" LIFT
    https://www.iconvehicledynamics.com...cessories-05-up-tacoma-25-vs-rr-coilover-kit/
    • Adjustable ride height from 0" - 3.5"
    • Race shock piston with flutter stack compression valving
    • Kit Includes Sway bar relocation brackets
    • Kit also Includes Reservoir Mounting Brackets
    • Cad-plated threaded body / Extreme Weather Plating Option Available
    • Billet aluminum upper mount
    • 5/8" PTFE-lined spherical bearing
    • Completely re-buildable
    • Hose Length Optimized for Increased Fluid Transfer
    • Mounting Bracket Orients Reservoir for Optimum Tire Clearance
    • External Reservoir Ensures Maximum Cooling
    • Chrome-silicon spring
    • 250 PSI nitrogen-charged internal reservoir
    • Factory Wheels & Tires Fitment: Yes
    • Recommended Aftermarket Wheels: 8.5" wide wheel with 4.75" backspace
    • Recommended Aftermarket Tires: 33" x 11.50" (Larger Tires May Fit but Fender Trimming and Modifications will be Required)
    [​IMG] [​IMG]
    05-UP Tacoma 0.15" Rear 2.5 VS RR CDCV PAIR
    https://www.iconvehicledynamics.com...es-05-up-tacoma-0-15-rear-25-vs-rr-cdcv-pair/
    • 6061 aircraft grade aluminum CNC machined components
    • ICON's CDC Valve technology allows for 10 levels of high-resolution compression adjustability with the turn of a knob
    • Nitrogen charged monotube design with remote reservoir
    • Double-sealed Schrader caps reduce risk of damage
    • One-piece impact extruded aluminum cylinders offer excellent corrosion resistance and consistent finish
    • ICON’s internal “Bump Zone” increases damping by 20% to provide more control as the shock approaches full compression
    • One piece digressive piston design with vehicle specific valving for unsurpassed performance and ride quality on and off-road
    • 7/8” diameter induction hardened, chrome plated shock shaft
    • 100% Rebuildable
    • Remote reservoir design improves heat dissipation to reduce shock fade during prolonged use
    • PTFE lined spherical bearings and application specific mounting hardware
    • 100% Revalveable
    • Premium grade 5WT shock oil for consistent suspension damping along a wide temperature range
    Front Driver Shock has a small leak and needs to be rebuilt.
    Overall good condition with low miles, but some surface rust in small areas. I'm cleaning them up and will post an updated picture shortly.
    Make me an offer. Willing to separate.
  2. Feb 22, 2022 at 9:06 AM
    McDangle
    Mc Dangle
    33" 07 5 Lug
    All of Themz
    Quick washed - will clean up more after work
  3. Feb 22, 2022 at 10:07 AM
    N minus 1
    N minus 1 Ruff Road Designs
    San Diego, CA
    2014 TRD Off Road
    Just an FYI, you will need to list a price per the BST rules.
  4. Feb 22, 2022 at 10:27 AM
    orbot
    orbot Well-Known Member
    How much are you wanting for the rears?
  5. Feb 22, 2022 at 7:17 PM
    McDangle
    Mc Dangle
    33" 07 5 Lug
    All of Themz
    $700 + shipping
  6. Feb 22, 2022 at 7:25 PM
    orbot
    Can you get extended meassurement and how travel they have
  7. Feb 22, 2022 at 9:24 PM
    McDangle
    Mc Dangle
    33" 07 5 Lug
    All of Themz
    27 1/4" end to end extended - 18" collapsed = 9" travel
  8. Feb 24, 2022 at 9:40 AM
    McDangle
    Mc Dangle
    33" 07 5 Lug
    All of Themz
    SALE PENDING
  9. Feb 28, 2022 at 8:31 AM
    McDangle
    Mc Dangle
    33" 07 5 Lug
    All of Themz
    BUMP still for sale - willing to ship
  10. Feb 28, 2022 at 1:41 PM
    Taco4Jaco
    Taco4Jaco Well-Known Member
    Jacob
    Sacramento
    White 2005 TRD OR
    Still have fronts?
    McDangle[OP] likes this.
  11. Feb 28, 2022 at 1:54 PM
    McDangle
    Mc Dangle
    33" 07 5 Lug
    All of Themz
    I do
  12. Mar 9, 2022 at 10:50 PM
    McDangle
    Mc Dangle
    33" 07 5 Lug
    All of Themz
  13. Mar 11, 2022 at 8:23 AM
    Jonofthehills
    Jonofthehills Well-Known Member
    Arcata, CA
    15 trd 4x4
    Location for possible pickup?
  14. Mar 11, 2022 at 6:55 PM
    McDangle
    Mc Dangle
    33" 07 5 Lug
    All of Themz
    Concord CA
