FS: INDASH IPAD MINI W FLOAT MOUNT
Discussion in 'Audio & Video' started by tacomonazul, Dec 15, 2014.
  1. Dec 15, 2014 at 9:11 PM
    tacomonazul
    tacomonazul [OP] Well-Known Member
    Luis
    SOCAL
    07 DCSB LT/4LINK
    http://www.tacomaworld.com/forum/2nd-gen-builds/227832-my-never-end-build.html
  2. Dec 16, 2014 at 8:49 AM
    tacomonazul
    Luis
    SOCAL
    07 DCSB LT/4LINK
    I'll include the black hazard light panel for 50 bucks more!
  3. Dec 16, 2014 at 9:37 AM
    little squirt
    little squirt 808 ALLDAY!!
    808 ALLDAY!!
    How does the audio control work, say if you use pandora? Would I just take the ipad in to At&t and get it setup on my phone account as a second device?
  4. Dec 16, 2014 at 9:40 AM
    B737
    B737 Throbbing Member
    Kevin
    Jersey Shore
    2015 Tundra Double Cab Limited
    stock
    the ipad will connect to a headunit buried someplace else, you can see his in his photo lower dash. if you have a cellular enabled ipad already, or buy one, you just add it to your line. (with VZW its $10 dollars a month to add the ipad onto your line)
  5. Dec 16, 2014 at 10:20 AM
    tacomonazul
    Luis
    SOCAL
    07 DCSB LT/4LINK
    Yup you cat get the cellular version or you can also share data from your phone (thats what I do), on the audio stream you can connect to a head unit if you have stock sound system or if you have aftermarket amplifiers you can just get an iStreamer or something similar so theres no need for a head unit just the iPad
  6. Dec 16, 2014 at 11:49 AM
    little squirt
    808 ALLDAY!!
    my ipad mini is wifi only, would I have to make my iphone a hot spot or something so it would pull from that?
    So are you selling the ipad with the mount or is this just for the surface mount itself?
  7. Dec 16, 2014 at 12:13 PM
    tacomonazul
    Luis
    SOCAL
    07 DCSB LT/4LINK
    Its just the iPad dash mount, I'll sell the iPad too as im getting the 4g version. Every iPhone has personal hot spot. So you just turn it on and connect it to the iPad
  8. Dec 16, 2014 at 12:42 PM
    little squirt
    808 ALLDAY!!
    thanks for the info, i also came across Shane's setup, I emailed him today. I'll let you know which direction i go.
    Can't wait to see your truck after the cage gets done! That thing is a monster!! :burnrubber:
