FS: Morimoto LED AMBER Fog Lights **PREORDER GB**
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by kustom54lighting, Aug 31, 2018.
  1. Dec 26, 2018 at 12:05 PM
    #281
    diabetiktaco
    diabetiktaco Instalander
    Eric
    New Jersey
    2022 GX460
    Maybe hard to see in the daytime but they seem to match my rigid LED perfect.
    o0oSHADOWo0o and Bridge4[QUOTED] like this.
  2. Dec 26, 2018 at 1:15 PM
    #282
    Bridge4
    Bridge4 Well-Known Member
    MA
    2003 DCSB Imperial Jade
    Looks good, I remember the light from mine being a little lighter in shade, but it was over a year since I've seen them and could be wrong!
    diabetiktaco[QUOTED] likes this.
  3. Dec 27, 2018 at 5:34 AM
    #283
    Chris_The_Red
    Chris_The_Red Well-Known Member
    Brooklyn, NY
    2018 Cement Tacoma TRD OR
    Ordered! Along with my TRD Pro grill and amber raptor style lights! Christmas was good!
    Also, my first post on the forums!
  4. Dec 27, 2018 at 1:52 PM
    #284
    The1youluv2hate
    The1youluv2hate Well-Known Member
    Peps
    SAnta Paula CA
    18 TRD sPort 4x4 (11mgmsport)
    oem pro grill 17” pro rep wheels Fox dsc shocks
    Right on , purchased the same stuff
    Chris_The_Red[QUOTED] likes this.
  5. Dec 27, 2018 at 7:36 PM
    #285
    o0oSHADOWo0o
    o0oSHADOWo0o Just lurking in the darkness
    Shadow
    Va Beach
    2012 Double Cab Short Bed 4x4 TRD Sport
    Just a few LEDs...
    Welcome to Tacoma World! The site that is sure to put a dent in your wallet.
    :spending:
  6. Dec 28, 2018 at 7:39 AM
    #286
    ITR_J
    ITR_J Well-Known Member
    Jay
    2018 Cement Tacoma TRD Off Road
    TRD pro grille 32” KO2’s
    Tech tip: 12v power was the green wire on my 2018. Connect the red wire from the fog light into the green wire on the oem harness.
  7. Dec 28, 2018 at 7:43 AM
    #287
    Chris_The_Red
    Brooklyn, NY
    I hear that. I was online lurking the day I got the truck.
    o0oSHADOWo0o[QUOTED] likes this.
  8. Dec 28, 2018 at 9:14 AM
    #288
    Chris_The_Red
    Brooklyn, NY
    Confused? Aren’t these simply plug and play, right into the factory fog harness?
  9. Dec 28, 2018 at 9:27 AM
    #289
    ITR_J
    Jay
    They are but you have to insert the pins from the fog light into the supplied connector. If you don’t get the polarity right the light won’t turn on.
  10. Dec 28, 2018 at 9:29 AM
    #290
    baldbeardedtaco
    baldbeardedtaco Well-Known Member
    FL
    18 TRD Sport DCSB MGM
    Thanks for that,haven’t had time to install mine but have a 4 day weekend coming up in t minus 2-3 hrs
    Yes but you have to insert the fog light wires/leads into to provided plug because it’s capable with multiple vehicles (I heard) but the wires might be different between them all
  11. Dec 28, 2018 at 10:04 AM
    #291
    Chris_The_Red
    Brooklyn, NY
    Ohhhhhh ok. Got it. Thank you!
  12. Dec 28, 2018 at 10:47 AM
    #292
    MrWednesday
    MrWednesday Well-Known Member
    Colorado
    2018 DCSB TRD OR MGM
    Ordered mine on the 23rd! Can't wait to get them installed!
    Chris_The_Red likes this.
  13. Dec 28, 2018 at 2:01 PM
    #293
    THEWAKLER
    THEWAKLER Well-Known Member
    Jesse
    Wilmington, NC
    23 Tundra Limited OR
    Got mine installed finally! Pics to come once the Raptor lights are done
    Pro tip: make sure to come in from the top/grill than trying to bend back the fender liner. Muchhh easier and makes alignment after the fact a breeze.
    ITR_J likes this.
  14. Dec 28, 2018 at 2:24 PM
    #294
    Chris_The_Red
    Brooklyn, NY
    Honestly, I was hoping to do it from the top/grill, so that’s great to know. Any issues alignment wise? How hard would it be to align them from that angle? Can’t wait to see the pics.
  15. Dec 28, 2018 at 2:29 PM
    #295
    ITR_J
    Jay
    I did it from the top without removing anything. The lights themselves fit just like oem, however the adjusting screw is pointing down while it points up on the oem fog lights. If you need to adjust the beam you have to do it from the bottom.
    dead.fm13 likes this.
  16. Dec 28, 2018 at 2:32 PM
    #296
    Catfish21
    Catfish21 Well-Known Member
    Stockton, Ca.
    Trd off road 4th Gen
  17. Dec 28, 2018 at 7:14 PM
    #297
    THEWAKLER
    Jesse
    Wilmington, NC
    No alignment issues, they are straight and level, just like OEM.
    Note that there are slots the tabs on the lights tuck into. Only 1 screw is used, although there are 4 screw holes. No need to try and create additional holes like I did. THAT will mess up your alignment (toed in).
  18. Dec 28, 2018 at 8:04 PM
    #298
    absolutgt
    absolutgt You know...here, there, and guardrails
    Georgia
    2016 MGM Double Cab
    I went from the top down as well, total time to remove factory and install these was maybe 15 mins. Mine were pointed way to low out of the box, and I was still able to put my arm all the way down from top and use a stubby screw driver to adjust, it’s still a touch too low but they are a dark amber output not like the normal “yellow” many are use to, I like them and I was worried they were not going to be enough but paired with my 5500k hid low’s they work just fine in fog/rain conditions. Glad I held out for these instead of picking up the white Morimoto fogs
    ITR_J likes this.
  19. Dec 28, 2018 at 9:53 PM
    #299
    Taco_Coma
    Taco_Coma That's a lovely accent you have. New Jersey?
    South NJ
    2018 DCSB SR5
    Same on the sr5, don’t put the wrong pins in, i did at first and blew a fuse ¯\_(ツ)_/¯
  20. Dec 29, 2018 at 2:17 AM
    #300
    Bridge4
    MA
    You DO NOT need to do it from the bottom. You can fit a stubby screwdriver in from the top, and use it upside down. Then adjust from there, super easy once you get the screwdriver into it's slot.
    They only give you one screw but I used two. I used the new ones they give you, plus the one from my old ones, seems super sturdy. I used the screw holes on the outside of the fog housing for both.
    SevenXL likes this.
