FS: Morimoto LED AMBER Fog Lights **PREORDER GB**
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by kustom54lighting, Aug 31, 2018.
  1. Dec 31, 2018 at 3:24 PM
    #321
    Chris_The_Red
    Chris_The_Red Well-Known Member
    Brooklyn, NY
    2018 Cement Tacoma TRD OR
    Ok cool. I really should have waited until my pro grill and grill lights came and killed like, 3 birds with one stone. Appreciate the help.
  2. Dec 31, 2018 at 3:46 PM
    #322
    baldbeardedtaco
    baldbeardedtaco Well-Known Member
    FL
    18 TRD Sport DCSB MGM
    I have the dealer addon (I guess that was what it was) 2n1 led fog light and when I looked down at the harness/plug, it just seemed to have a lot going on versus simply unplug and plug.
    I have found the installation instructions to install these 2n1 led fogs to see exactly what was done. In fact it’s quite a bit… new harness ran from each fog location through the firewall to left side cubby and adding a switch and hiding the driver. I was thinking I could remove the extra wire harness from the (stock to me 2n1 ) but after seeing that I don’t think I’ll be doing that right now. I guess if I ever decided to sell the 2n1 stock “upgraded” fogs I’d have to go in and remove everything
    But after looking at the instructions I think it’s just a matter of unplugging the stock fog plug from the 2n1 harness plug and done. I’ll just have the 2n1 harness hanging there until I decide to remove it all including the dead switch I’ll have after
  3. Dec 31, 2018 at 3:47 PM
    #323
    absolutgt
    absolutgt You know...here, there, and guardrails
    Georgia
    2016 MGM Double Cab
    No problems! Nah, this the grill are easy enough to tackle in 10-15 mins.
    The hardest part of the pro grill is popping out your factory insert tabs for the original grill
    Chris_The_Red[QUOTED] likes this.
  4. Dec 31, 2018 at 4:53 PM
    #324
    The1youluv2hate
    The1youluv2hate Well-Known Member
    Peps
    SAnta Paula CA
    18 TRD sPort 4x4 (11mgmsport)
    oem pro grill 17” pro rep wheels Fox dsc shocks
    runin4tacos
  5. Dec 31, 2018 at 6:34 PM
    #325
    Dee1seven
    Dee1seven Well-Known Member
    RVA
    '17 DCSB TRD OR - Quicksand
    '15 TRD Pro Bilstein Suspension HS 3 leaf AAL TRD PRO Wheels 285/75r16 BFG KO2’s Truxedo Soft Roll Up cover
    Didn’t know there was a dealer add-on 2in1 fogs are they the same as the Rigid TRD Pro fogs? Or are they aftermarket and dealer installed them?
  6. Dec 31, 2018 at 8:51 PM
    #326
    baldbeardedtaco
    FL
    They are not like the pro rigid fogs. Im guessing the dealer did it as an extra “addon”. I think they tagged it at about $450 on the window sticker.
    it’s a projector 2 n 1 fog light- it has the fog function like normal and then a drl function that has leds around the outer edge which has its own oem switch in the left (of steering wheel) cubby to activate with the drl (in headlights) stalk switch. So there is extra wire harness to make it work.
    I’ll more than likely take the time to remove it completely eventually (and sell it) since I won’t be going back to these regardless and it leaves that now dead switch. Gives me a good reason to figure out my plans for the left cubby to get a custom @mesojdm panel :D
    Bridge4 likes this.
  7. Jan 1, 2019 at 10:31 AM
    #327
    Chris_The_Red
    Brooklyn, NY
    Those are pretty interesting. I have never seen them before. Do you not like the output?
  8. Jan 1, 2019 at 11:56 AM
    #328
    baldbeardedtaco
    FL
    No the output is fine, it’s just not amber :D
    Bridge4 likes this.
  9. Jan 1, 2019 at 12:00 PM
    #329
    Chris_The_Red
    Brooklyn, NY
  10. Jan 1, 2019 at 12:09 PM
    #330
    Markc1024
    Markc1024 Well-Known Member
    Just ordered a set - also found the following that has a pretty good view of what is required in the swap (wheel well approach):
    https://youtu.be/FiHVLDOiiW4
  11. Jan 1, 2019 at 12:45 PM
    #331
    baldbeardedtaco
    FL
    I’ve seen the yellow laminx before and honestly didn’t think to look if there was amber. But that wouldn’t be the route I’d of chosen anyway personally. Not looking for the amber look/style when they are off and then it also changes the leds
    0D2FD399-5554-4D35-8133-3FCAEFD8BB22.jpg B34AD087-6DA4-4358-8930-44C340A1E004.jpg
    It’s too light out to get an output shot unless I’m a couple feet away
    Bridge4 likes this.
  12. Jan 1, 2019 at 1:18 PM
    #332
    Chris_The_Red
    Brooklyn, NY
    Those are so nice man. I get that you want amber though. It would be sweet if they could have a white DRL and amber main fog or vise versa. Kind of like these:
  13. Jan 2, 2019 at 8:20 AM
    #333
    LTG4087
    LTG4087 Well-Known Member
    LT
    DFW
    2019 TRD Off Road
    Will these not fit a 2019 OR? All of the descriptions say 12-18 Tacomas.
  14. Jan 2, 2019 at 8:22 AM
    #334
    Chris_The_Red
    Brooklyn, NY
    Yeah, they will most likely fit.
  15. Jan 2, 2019 at 8:35 AM
    #335
    TRSAndrew
    TRSAndrew Instagram: @apissues Vendor
    ATL
    ‘22 4Runner, ‘14 F150, and I’ve had 4 Tacomas (‘12, ‘15, ‘16, ‘18), 2 FJs
    It's no different than a '16, so yes it'll fit a '19 as well.
    Chris_The_Red and Bridge4 like this.
  16. Jan 2, 2019 at 9:47 AM
    #336
    LTG4087
    LT
    DFW
    2019 TRD Off Road
    Thanks, that's what I thought but I hate surprises and since there's been plenty of time for the vendor to add 2019 in the description I wanted to be sure.
  17. Jan 2, 2019 at 9:54 AM
    #337
    Chris_The_Red
    Brooklyn, NY
    Noticed today there are some light scratches on the housing of mine. Not blaming the vendor as it may have been me while placing them. Anybody have any recommendations on how to polish them out? Also, are they UV protected?
  18. Jan 2, 2019 at 10:23 AM
    #338
    Dee1seven
    RVA
    @Chris_The_Red Prior to install I had to return one of the lights myself due to some light scratches on the outer lense. Not blaming the vendor either I think not enough cushion in the packaging from the factory may have been the culprit. @kustom54lighting is aware and will replace it, their customer service is great and they’re easy to deal with.
    Chris_The_Red likes this.
  19. Jan 2, 2019 at 10:52 AM
    #339
    Chris_The_Red
    Brooklyn, NY
    Do you think it is worth it for me to send just one light back? Is there any way I can just polish the scratches out?
  20. Jan 2, 2019 at 12:16 PM
    #340
    Dee1seven
    RVA
    @Chris_The_Red I would think you can polish the scratches away, assuming that they are already installed it would be hard to prove to the vendor that they came with imperfections. I noticed mine right out of the box before doing anything so I sent the one back.
