FS Motorcycle Bed Rack
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by snowsk8air2, Sep 1, 2017.
  1. Sep 1, 2017 at 12:39 PM
    snowsk8air2
    snowsk8air2 [OP] how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Getting rid of this little motorcycle bed rack I made a while ago because I am installing real long travel and it is interfering with my shock hoops. It mounts using 4 bolts through the front of the bed. No more tying down bikes to the bed rails, plus you have 3 wheel chocks to secure the front tire.
    $40
  2. Sep 1, 2017 at 1:16 PM
    Charles135
    Charles135 Well-Known Member
    LA-Orange county
    19 cement trd
    Do you have issues with bars hitting? With full size bikes?
  3. Sep 1, 2017 at 1:24 PM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    With two 450's they are close, but I've done that plenty of times without issue. Just got to lean them out a touch. Can't put 3 in all at once. I just built it so you can run one in the middle or one or two on either side.
  4. Sep 1, 2017 at 8:38 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Huh... Might have to build myself something like that for my road bike, looks like it would work well for gas cylinders too without being obtrusive meaning I could leave it in the bed long term. Transporting my welding bottles right now is always a nerve wracking pain making sure they are all secure.
  5. Sep 6, 2017 at 12:13 PM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
  6. Sep 24, 2017 at 2:13 PM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
  7. Sep 24, 2017 at 2:20 PM
    Radarninja
    Radarninja Safety 3rd
    Northern California
    06 taco
    Chromed out radiator cap
    I have one like this, it makes strapping dirt bikes down way easier. I've run three bikes with mine Two forward on the sides and one backwards up the middle.
  8. Sep 24, 2017 at 2:22 PM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Yep I never ran 3 but built this one and frequently ran two. Just won't work with the bed cage anymore so it's gotta go.
  9. Sep 24, 2017 at 2:25 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Used to do that as well, and it works like a charm. Getting it up the ramp backwards is always fun though.
  10. Sep 24, 2017 at 2:38 PM
    Radarninja
    Northern California
    06 taco
    Same here, I'm making my cage so I'm gunna weld up something for the bike onto it.
    yeah no joke backwards is a little tricky
