FS: OME 885's, TRD Bilsteins
Discussion in 'Buy / Sell / Trade' started by ZonKs, Mar 15, 2010.
  1. Mar 15, 2010 at 6:32 PM
    ZonKs
    ZonKs [OP] Can speak french in Russian.
    Glendale, CA
    =p
    I have a set of pretty much brand new OME 885 coil springs for sale. They were installed for about a day (literally 2 miles of driving) and immediately taken out. I didnt like the amount of lift they gave to the front end.
    These are a bulky item so I would prefer a FTF sale. <885's SOLD PENDING FUNDS>
    I also have a set of TRD Off Road Bilstein shocks for sale. They were on my truck for 31K miles. I swapped out to 5100's. Asking $75.00. Again I would prefer a FTF.
    sweet
  2. Mar 15, 2010 at 6:40 PM
    gtrotter
    gtrotter Well-Known Member
    Interlake, Indiana
    2009 Regular cab 4x4, ARB's, 4.88's, bumpers, 2017 DCSB SR5 stock
    locker,mud tires, lifted, toolbox
    Got any pictures of it lifted on the 885's? More or less lift than the 5100's?
  3. Mar 15, 2010 at 6:41 PM
    rvcahawaii808
    rvcahawaii808 Well-Known Member
    cameron
    beaverton
    04 limited T4R 4x4
    how much lift do the springs give with 5100s at each setting?
    or can you only go to .85" with different springs
  4. Mar 15, 2010 at 6:43 PM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    Bump for good coils. I ran these with OME shocks and loved the ride.
  5. Mar 15, 2010 at 6:43 PM
    ZonKs
    Glendale, CA
    =p
    I have my 5100's set at 1.75 with the rear TSB. The truck sits pretty much level now. With the 885's and 5100's set at "0" the truck looked like it was about to leave the runway on route from LAX to Honolulu.
    as it stands now:
  6. Mar 15, 2010 at 6:45 PM
    ZonKs
    Glendale, CA
    =p
    As i said with my 5100's set to "0" they gave a huge (for me) amount of lift. Im going to guess at least 3".
  7. Mar 15, 2010 at 6:47 PM
    rvcahawaii808
    cameron
    beaverton
    04 limited T4R 4x4
    ive got the wheelers 1.5" AAL no tsb and my 5100s are at 2.5" with the sport springs and i wanted to get more lift so i was thinking new springs and just leave the billies at 0".
    so these springs + 5100s @ 0 = 3" aprox?
    since its 3" do i need new UCAs?
  8. Mar 15, 2010 at 6:49 PM
    ZonKs
    Glendale, CA
    =p
    Im thinking yes, they would provide more lift that 2.5 5100's. Maby someone else could chime in on this. And yes i think its a pretty good idea to get UCA's if you are going with these springs.
  9. Mar 15, 2010 at 6:50 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    I think you have to set the billies to .85" to get ~3" total. And its best to get new uca's. Good performance and perfect alignment specs.
  10. Mar 15, 2010 at 6:52 PM
    rvcahawaii808
    cameron
    beaverton
    04 limited T4R 4x4
    sorry for the threadjack :(
    but i will get back to you on the coils. i'll most likely buy them.
  11. Mar 15, 2010 at 7:21 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    That will give you much more than 3" lift. Set at the 0" setting, they should give 3".
  12. Mar 15, 2010 at 7:23 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    yea on mine 885s i got just about 2.5s, did you get more height chris. My truck still has the factory rake almost
  13. Mar 15, 2010 at 7:25 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    :bowdown:
    But why do they say add top plate for full 3"? The top plate is 1/2" and gives 3/4" lift. So technically they would only give ~2.25"......? Then add the billies at .85" and you get 3.10"......?
    Thats just what I always thought. I think each person is different maybe. I was running mine without top plates and got a little less than 3".
  14. Mar 15, 2010 at 7:25 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Im still at 3" lift with mine. They only settled about 1/4" in the first month, and havent settled any since.
  15. Mar 15, 2010 at 7:25 PM
    rvcahawaii808
    cameron
    beaverton
    04 limited T4R 4x4
    would setting the 5100s any higher than 0" be a bad idea?
  16. Mar 15, 2010 at 7:27 PM
    YellowDog01
    YellowDog01 Well-Known Member
    04 4x4
    PM'd question
  17. Mar 15, 2010 at 7:27 PM
    ktmrider
    Junk
    well if you have UCAs and your a prerunner so you wont have any problems with cvs, but your angles will cause a lot of wear to your suspension components
  18. Mar 15, 2010 at 7:28 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Im not sure why they say that... I was told from an OME rep, the new springs give close to the full 3" lift. Thats what I got, and a few others I have installed them on. Im not useing the spacers either. It may very from a 4x4 to a prerunner though....
    I wouldnt go higher than the .85" setting, and then, only if you had an aftermarket UCA.
  19. Mar 15, 2010 at 7:30 PM
    ktmrider
    Junk
    I think this is the case, because my fender-wells to the ground are about 37.75 with 285s
  20. Mar 15, 2010 at 8:48 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    yes you will
    I'm running 885s w/ 1/2" spacer 5100 bilsteins at 0 up front, 5100 and toytec TSB AAL plus tsb aal out back
    oh i had to use the spacer to get the full 3" I was about 2.25-2.5" w/o... (I was lower than a bilstein w/ stock springs at 2.5) now I'm slightly over 3"...like 3.25" on passenger side, I bought mine from toytec and the label said 885x (i'm not sure if these are the updated that Chris4x4 is talking about)
