FS: Projector retrofitted headlights?
Discussion in 'Northern California' started by sytfu510, Jan 14, 2013.
  1. Jan 14, 2013 at 12:39 AM
    sytfu510
    sytfu510 [OP] INSTAGRAM: sytfu510
    Alex
    Bay Area
    06 DBL Cab Long Bed TRD Sport
    Dirt Designs LT kit DMZ LT Kit TRD Supercharger SCS Wheels BAMF
    Don't want to ship lazy. Does need work.
    Taking out my projector converted black housing headlights. Any one interested in purchase? $200 picked up.
    The passenger side needs some TLC. Has a leak somewhere where moisture gets in. Also the projector on this side needs to be re-aimed.
    The headlights are aftermarket black housing
    Projector Retrofit kit + Hids
    Slim ballast 35w HID Kit. 4300K. With Halo ( although if you don't like it you can just not wire it up) Overall the lights look great and has a pretty good cutoff.
    The Eyelids are NOT included.
    Here's the driver side:
    Pic of the Psgr Side lit up:
    Another:
  2. Jan 16, 2013 at 12:08 PM
    09FriscoTaco
    09FriscoTaco Well-Known Member
    Tarcilo
    San Francisco,Ca
    09 4x4 Tacoma
    6" Pro Comp Lift Kit,AFE Throttle Body Spacer,AFE Intake,MagnaFlow Exhaust.
    I'm considerring getting these from u.the only thing is that I don't know how to re-aime the projector or take care of the leak it has either.any Idea of where I can take it for that and ballpark cost of it?
  3. Jan 16, 2013 at 12:18 PM
    sytfu510
    Alex
    Bay Area
    You can probably have it done at a mod day. To reseal it you'll have to bake it and redo the sealant. I can include some if you like. OR you can just add sealant to the outside. The passenger side is slight tilted, but I just deal with it. To re aim it you will have to bake it and open it then mount it on the truck, turn it on and adjust the nut in the back to level the cut-off. Let me know if you have any more questions.
  4. Jan 17, 2013 at 8:45 AM
    Jbcm12
    Jbcm12 Well-Known Member
    Joshua
    Bay Area
    Alex what retro fit kit did you use?
  5. Jan 17, 2013 at 8:51 AM
    sytfu510
    Alex
    Bay Area
    It's a kit from ebay, it was posted in the deals section a long time ago.
