FS: San Diego: Longrange Automotive 35gal (129L) replacement fuel tank for DCSB
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by paranoid56, Jun 14, 2017.
  1. Jun 21, 2017 at 10:00 AM
    #41
    paranoid56
    paranoid56 [OP] Well-Known Member
    San Diego
    14 double cab taco
    i do take credit cards lol
  2. Jun 21, 2017 at 10:25 AM
    #42
    TonyDobbs
    TonyDobbs Well-Known Member
    Tony
    Cotati, CA
    2012 LT TRD OR + 2007 TRD Sport
    Those don't have enough available credit right now, do you accept truck parts as payment? I have a nice camper shell for sale :)
  3. Jun 21, 2017 at 10:28 AM
    #43
    paranoid56
    San Diego
    14 double cab taco
    got a
    got a pic of the shell? wait, is it a shell or a camper setup? lol
  4. Jun 21, 2017 at 10:42 AM
    #44
    TonyDobbs
    Tony
    Cotati, CA
    I have some pics below:
    Boozng likes this.
  5. Jun 21, 2017 at 10:54 AM
    #45
    paranoid56
    San Diego
    14 double cab taco
    i just saw that you are kinda far lol. are you ever near San Diego?
  6. Jun 21, 2017 at 10:58 AM
    #46
    TonyDobbs
    Tony
    Cotati, CA
    Yea I was thinking about coming down the weekend of the 30th. If you are into the trade I could almost definitely make that happen.
  7. Jun 21, 2017 at 12:04 PM
    #47
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    No, DCSB and ACLB have the same frame
  8. Jun 21, 2017 at 1:42 PM
    #48
    paranoid56
    San Diego
    14 double cab taco
    i think the other issue is that bump you see, that goes right behind the cab of the double cab, where as on yours it might hit the bed? not totally sure
  9. Jun 22, 2017 at 5:18 AM
    #49
    Boozng
    Boozng I don't know what I'm doing here.
    Dave
    626, 661, 323, 310, 760
    MGM DCSB TRD Sport 4x4 Supercharged
    FOX 2.5/2.0, Camburg UCAs, 33" BFGs, Pelfreybilt Armor
    Damn! That's a nice shell! My color too!!!
  10. Jun 22, 2017 at 10:27 AM
    #50
    paranoid56
    San Diego
    14 double cab taco
    ok, here are some tips and things i ran into during my install.
    First, the directions that come with the tank suck. they suck so bad. its a wall of text with no pictures. they say things like
    but with out any pictures or even labels on the brackets it makes it hard.
    so with all that, the tank its self is very well made. and fits in the exact space with only a 1/4" of clearance. so they use every ounce of space.
    The directions say to unhook the driveshaft and move it out of the way. however, this doesnt work, you need to fully remove the driveshaft AND the exhaust. you can see why in the pic below. the tank kinda goes above the exhaust. if you remove these two things install of the tank will make you swear a lot less.
    the "front bracket" is a C shaped piece of steel with some holes in it. This gets placed INSIDE the front cross member and you put in two of the m8 bolts provide. (you can kinda see the holes in this pic) later on you will drill though this and bolt up the tank in this spot. (it would have been smarter for LRA to shift the holes over 1" so it lines up with those larger factory holes and move the tank bracket so you dont have to drill though your cross member)
    the big pain for me was this rear bracket, no matter what i did, none of their holes lined up for me except for the welded tab. below is the rear inside bracket
    I had to modify this bracket some to fit better. This was my first attempt. Notice i added in a second tab, welded on a nut and notched it. I will say that you can not add that second tab as if you do it will almost touch the tank(and if you have a bolt in it it will touch the tank for sure, so no go) i ended up cutting off that tab and just using the one tab.
    and here you can see it installed. i drilled and tapped the rear cross member for that bolt at the end. i may go in and change this to a welded in nut or a nut welded to a piece of metal so you can feed it into the tube as i am not sure how strong the tapped hole is. also, with that threaded nut, make sure you test fit it first as i had to cut that nut off and move it over a 1/4" for it to fit. this area is super hard to get to so thats why i welded on a nut. not sure how you could get your hand up there and hold a nut while you screwed it in.
    for the fuel and vent lines you will cut the factory connectors off the hardlines and reuse them for the new provided soft lines (funny, all the rubber lines were made in the USA LOL)
    vent line, uses the factory quick connection and the provided hose clamp
    large vent for charcoal filter, same thing, reuse the factory plug and provided hose clamp
    fuel lines, again, you will reuse the ends and us the provided hose clamps. make sure you label these as these are the fuel supply and return lines and you dont want them mixed up. On the one picture you can see how you install the factory fuel pump, on this tank you will want to rotate the pump so that the float points to the back of the truck. the stock fuel pump is held down by that ring and a Oring under the pump to seal it. ( I would have liked to see a few more bolts holding it in, but sure its fine)
    one other spot i had an issue with was the outside front hole. mine was off about a 1/4" so i had to open up the mounting hole on the tank in order to get the bolt started. this bolt is a PITA to do, as you do not have much room to work with.
    if you have any questions let me know.
  11. Jun 26, 2017 at 8:59 AM
    #51
    paranoid56
    San Diego
    14 double cab taco
  12. Jul 5, 2017 at 9:48 AM
    #52
    Techoma
    Techoma This is the Wild, Wild, West!
    Alta Mesa, AZ
    Extreme Expo 05 PreRunner
    Dirty fives on Level 8s, 4.88 gears and Harrod Locker on rear. Cab Chop x2, MBRP Cat Back Dual Exhaust w Flowmaster 44 for punch, cut off at rear axle, Throttle Body spacer, Camburg UCA and Coil-Overs, Matrix Spindle lift up front ProComp extended travel on rear w\ Dakar leafs +, Panasonic HU w Front x2 and rear x1 camera, kicker 500 powering 2 JL Audio 10" subs, JL component speakers in front doors and JL audio coaxials in rear doors powered by alpine 600 amp. Cobra all in one CB, Easy Lift hood, and Easy Down Tailgate, Pop N Lock, Dual RGB Halo Projectors, Blacked out tails with HI intensity LED's, Scanguage II, AVID Custom sliders and Hybrid rear bumper, Pelfreybilt Hybrid front, Glock Steering Column Holster, 2 Hella's behind Satoshi on Avid light Bar, Decepticon Badges, 2x 24" LED ropes and 2X 4" HI LEDs to fire up Satoshi w Super Bright green Halo's. Under Hood lighting as well as RGB rock lights. PrinSu Cab/Shell Rack with FreeSpirit hard shell RTT, 28", 2x 20", and 50" LED Bars all controlled by SwitchPros and Weathertechs front and rear.
    Sooooo tempting. At 10 - 12.5 MPG average, every day, This really appeals to me. However, another project with all the current ones..... man.... just gotta chew on it some more!
  13. Jul 5, 2017 at 9:56 AM
    #53
    paranoid56
    San Diego
    14 double cab taco
    I will be in laughlin this saturday if that helps lol (i can bring it)
    Techoma[QUOTED] likes this.
  14. Jul 5, 2017 at 10:04 AM
    #54
    Techoma
    Alta Mesa, AZ
    Hmmmm.... 4 hours....
  15. Jul 13, 2017 at 11:52 AM
    #55
    paranoid56
    San Diego
    14 double cab taco
    bump
    Techoma likes this.
  16. Jul 20, 2017 at 6:41 PM
    #56
    paranoid56
    San Diego
    14 double cab taco
  17. Jul 20, 2017 at 7:38 PM
    #57
    Eff3ction
    Eff3ction Well-Known Member
    Troy
    '11 TRD OR DCSB
    wow this is still for sale?
    i talk about this to my coworkers a couple times a week. i was sure it had sold.
    seattle, though...
  18. Jul 21, 2017 at 7:32 PM
    #58
    LITACO
    LITACO Well-Known Member
    Rob
    Long Island
    2006 DCSB 325,000 Miles
    ARMOR- CBI Moab 2.0 front bumper, Bud Built Mid Skid, Bud Built Trans skid w/cross member, BAMF rear diff skid, Armortech gas tank skid, OEM front tin skid, Icon Lca skids, Demello off-road round tube sliders bolt on but tack welded for strength, Body Armor 4x4 rear bumper, CHASSIS AND SUSPENSION- New frame from Toyota September 2016, One piece rear driveshaft by supershafts of long island, BAMF cab mount chop plates, 5100 front shocks with toytec 3 inch lift coils w/top plates, All-Pro expo leafs, 1.5 inch blocks + 3 degree shims, Daystar rear bumpstops, 5100 extended travel rear shocks, spc light racing uca's, Toytec steel braid rear brake lines, synergy 1.5 wheel spacers, front sway bar relocation blocks, Minor front fender trim, hammer pinch weld mod. PERFORMANCE MODS- TRD Cat back exhaust with Thrush welded muffler, TRD CAI with Updated AFE filter, Air Flow Snorkel. WHEELS AND TIRES- M/T Sidebitter wheels 16X8 4.5 B/S with Falken wildpeak atw3. LIGHTING MODS- Black Bezel headlights brand X resealed before install, 6k LED headlights by Opt7 silicone glued into headlight, 3k hid foglight conversion, 4 inch Hella optilux 6k, 31inch led bar resealed before installation, Fog light bulb reverse light mod, LED interior lights. SOUND SYSTEM- Pioneer head unit with ipod interface (stock unit is junk), Rockford speakers all around, Pioneer 10 inch sub behind rear seat. ACCESSORIES- Armor Tech Hi-Lift Bed mount, OEM Bed mat, Weather Tech floor mats, Wet Okole front seat covers, Cobra 19 CB with Firestick, Home made bolt on antenna mount near tailgate, Ultra Gauge EM, Avital remote start for North East winters.
    Holy s**t this is nice! too bad its on the WestCoast. GLWS!
