FS: Sway Away 2.0 (05+ Tacoma)
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by brigham, Oct 7, 2011.
  1. Oct 7, 2011 at 11:35 AM
    brigham
    brigham [OP] Member
    I'm done trying to make this work on my FJC... Here’s the spec:. Hasn’t been valve, Shock has been tested & recharged w/ nitrogen @ Burnetts Sand Blaster. Long story short, Original spring for SAW are 13" 650 lbs, which = front end swag on the FJC???? Measuring my OEM shock length vs the Tacoma SAW, from top to lower control arm eyelet are the same length, So I figure replacing the shocks w/ stiffer coils, Eibach 16" 650 lbs = 2 1/2 inch of preload compressed w/ span nut on top, would give me the add height needed, now I don’t have enough weight (tube bumper no winch) to compensate for the stiff spring. ( should of went with the 14" Coils) Anyways setup forsale are 05+ Tacoma sway away 2.0 mounted w/ the Eibach 16” coil.. will also included the original 13” SAW spring incase you want to swap back. Asking 350.00 Shipped. I'm in fresno, CA if your interested for pick up.
  2. Oct 7, 2011 at 4:18 PM
    hard2kill
    hard2kill Well-Known Member
    Rhinebeck NY
    06 4door trd sport white 6spd
    ...315's,2in bora wheel spacers,safari snorkel,wheel spacers,bruteforcefab rear bumper and sliders,afe filter,hi-lift jack,5100 with OME 886 & 1/2in spacer,allpro expo's,icon 10in rear shox,flip kit,ss brake lines,cobra cb,fog light mod,yellow fogs,weathertech mats,fullsize spare tire and extra sport rim,tinted windows,aeroturbine 2525 muffler dumped over axle...rear diff breather mod...removed factory spare...removed 2nd air filter...THULE roof rack and fairing....bud builts front to back,allpoo front bumper,BAMF lca skids,overland Offroad roof and bed racks,
    so the way they are right now would provide how much lift on a taco? how many miles are on these? they dont need a rebuild or anything?
    you wrote "hasnt been valve" ? what are you trying to say here?
    im interested
  3. Oct 7, 2011 at 4:19 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Probably 4" lift. You could swap the other springs in for a better lift height.
  4. Oct 7, 2011 at 4:26 PM
    hard2kill
    Rhinebeck NY
    thanx chris...yeah would deff need the other springs put in then...im just nervous about valving and charging etc....i know nothing about coilovers or tuning them
  5. Oct 7, 2011 at 4:26 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Not a big deal. DSM can take care of you.
  6. Oct 7, 2011 at 4:40 PM
    hard2kill
    Rhinebeck NY
    sent dsm a pm.....
    OP- consider me first in line if you dont mind....pm me if you like
  7. Oct 7, 2011 at 4:44 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    Prob a good idea to revalve them, but that's a great deal!
  8. Oct 7, 2011 at 4:45 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yeah...At that price, DSM can rebuild them, and give a warranty, and he'd still be ahead of the game.
  9. Oct 7, 2011 at 4:46 PM
    hard2kill
    Rhinebeck NY
    i like being ahead of games....lol
    i need new rear springs like now though...lol...not coilovers...hahahahaha but maybeeee :)
  10. Oct 7, 2011 at 5:00 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    Those should be good to go with the 16" coils on there, it will be at about 2.5-3"" lift with the collar all the way at the top. Since they were made for a Taco the valving should be correct already.
    I've got the same spring on my SAWs, but in a 14" length, and I've got 2" of threads showing abover the collar, and my truck is up +2.5".
    Of course getting them rebuilt isn't a bad idea, you should be able to bolt on and run. Get a swaybar relocate, or if you want to reap the full improvement, ditch the swaybar completely.
  11. Oct 7, 2011 at 5:14 PM
    hard2kill
    Rhinebeck NY
    my sway bars has been gone for months now :)
    the 2.o dont need new uca's correct? i plan on getting them of course but i have other things i need asap
  12. Oct 7, 2011 at 6:48 PM
    brigham
    brigham [OP] Member
    My previous setup was OME 884 = 2-2.5 of lift; measuring from the ground up to the bottom of the fender flare i had a total height of 38", vs 39” w/ the sway away. These are measurement off my FJC.
    The coilovers have 50k on them, i had Burnetts test & recharge the shocks before mounting the new coils, no leaks. took them off after my hunting trip the following weekend & threw back my old setup. Valving is for Tacoma, never tamper with.
  13. Oct 7, 2011 at 9:18 PM
    hard2kill
    Rhinebeck NY
    Will be in touch soon
  14. Oct 10, 2011 at 12:16 AM
    Sky
    Sky Taco Member
    Brandon
    Redlands/Yucaipa
    05 V6 4x4 TRD Off-Road
    First of I painted my truck Satin flat black, it has a Volat Cold air Intake, 5100s up front and J66's as well as billy 5150s in the rear, 285/ 75/16 Falcon wild peak A/T, Axis regulators painted satin black, with a gold rings! brush bar with 4 LightForce 170 strikers, Custom rear Bumper, Straight Pipe. HID 6000k Hi/Low, and HID 6000k fog lights, Tinted rear tail lights! Flat Black Interior! 2 12" subs with custom box made by me and a 1300 watt amp!
    Subbed
  15. Oct 10, 2011 at 6:54 PM
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    LS Swap 500 hp......
    Paid for and sold:D
    To me
  16. Oct 10, 2011 at 8:52 PM
    snorola
    snorola Well-Known Member
    Brett
    Canmore Alberta
    06 4x4 Dbl Cab
    SAW 2.0 Coilovers Eibach 14" 650lb springs Camburg UCA's All pro expo springs OME rear shocks All pro front bumper All pro IFS skid All pro sliders SCS f5 matt black rims Lightforce blitz 240's
    nice man
    I have the same ones on my truck, I just had them rebuilt and they are like new again.
    If you ever need these rebuilt I know a good place in alberta
  17. Oct 10, 2011 at 9:03 PM
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    Where at I might be just getting them redone to be safe
  18. Oct 11, 2011 at 6:55 AM
    brigham
    brigham [OP] Member
    Sold to Bulhas
  19. Oct 11, 2011 at 7:05 AM
    brigham
    brigham [OP] Member
    If your looking forward to having them rebuild to be on the safe side i can have it done at a local shop before shipping @ your cost: I use Burnett's Sand Center, Fresno CA.. My brother did his FOX shocks or about 200.00 a pair. You can google them, they do a lot of custom dune buggies and off road stuff. LMK before shipping
  20. Oct 11, 2011 at 7:09 AM
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    I got a solid quote from a local shop but thanks
