FS: SWITCHES
Discussion in 'Buy / Sell / Trade - Other' started by Toynado, Sep 14, 2016.
  1. Sep 14, 2016 at 4:27 PM
    Toynado
    Toynado [OP] Well-Known Member
    SF Bay Area
    2016 TRD OR DCSB Quicksand
    EXTERIOR: Toytec Boss 2.0 Dakar CS047R Leaf Springs Tailpipe chopped Pelfreybilt Front full hoop front bumper w/ Pelfrey fairlead Pelfreybilt Rear standard bumper Pelfreybilt Aluminum IFS, Mid, Rear (exhaust reroute) & Gas tank skids Pelfreybilt Fuseplate w/ 12 circuit fuse block All-Pro Apex Sliders ProComp 7036 17"x9" -6 offset BFG 275/70R/17 KO2's Warn VR10000-S winch Baja Designs S8 light bar & Squadron sports amber pods in front bumper Baja Designs S2 flush pods in rear bumper Baja Designs Squadron Pro amber pods on Caliraised ditch light brackets @rrentrop reflective black tailgate inserts RSI LED's for regular & high beams Prinsu Cabrac Custom Tradesman Truck Top by Access Manufacturing w/ Powertank 8"propane tank mount & Yakima tracks on the roof INTERIOR: Warrior Products door sill protectors Husky Weather Beater floor mats front & rear Coverking arid multicam seat covers in the front Midland 75-822 CB w/ 4' Firestick antenna on C4 Fabrication tailgate mount Consolevault Hondo Garage iPhone mount
    Got these but then decided on different switches.
    $15.00 for both.... WHAT A DEAL!!
    12 Volt 3amp ON - OFF PUSH Switch
    Twin L.E.D Lights
    This Switch Suits the following models ONLY:
    Toyota FJ Cruiser 2007-ON
    Toyota Highlander 2001-2007
    Toyota Tacoma 2005-2017
    Toyota Tacoma 2012-ON Left Side ONLY
    Toyota Tundra 2005-2007 Center Console
    Toyota 4Runner 2003-2009
    Please check the hole size before purchase
    This 12 volt push switch from AOB is a single throw ON - OFF switch designed to operate your 12 volt accessories. it has a face surface size of 1.54" x 0.83" (39 mm x 21 mm) and uses the original mounting hole of the vehicle.
    These Switches are an aftermarket switch that locks into your existing panel super easy to install in less than 10 min's.
    • Single Pole Single Throw ON - OFF PUSH switch
    • Black hard surface rocker.
    • Laser etched Legend
    • Single upper L.E.D light.
    • Single lower L.E.D light.
    • Upper light is ON when the switch is pressed IN.
    • Lower light can be wired to separate dash light circuit.
    • Rated at 3Amp 12V.
    • Wiring diagram supplied with switch.
    All symbols are Laser etched directly onto the switch face using modern high Tech laser engraving equipment to ensure long image life.
    The switch is an electronic switch rated at 3amp's. Therefore in ALL cases the accessory MUST be wired through a fused relay.
  2. Sep 22, 2016 at 3:45 AM
    Toynado
    SF Bay Area
  3. Sep 26, 2016 at 6:24 AM
    Drtgrl
    Drtgrl Minus member
    Alana
    Foothills
    2015 MGM Tacoma DCLB
    BAMF sliders with kick up. BAMF all skids. Icons w/ CDC up front. Icon UCA's. All pro expos with 12” kings in rear. Wheelers superbumps. 285 stt pros on black 16" fj wheels. 1" Bora wheel spacers. Relentless tailgate reinforcement. Ditch lights front and rear. Aironboard switches. Aux. bussman box.Center console vault. Esp locking storage. Tuffy bed box. Rear seat molle system. Color matched grill.Rear diff breather mod. ABS switch. PrInSu cab rack. Gusseted spindles.
    What color are they?
  4. Sep 26, 2016 at 7:29 AM
    Toynado
    SF Bay Area
    Blue/blue - two LEDs. One lights up with your dash if you want & other lights up when pressed.
  5. Sep 26, 2016 at 7:30 AM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    push to turn on something :rofl:
    Toynado[OP] likes this.
  6. Oct 3, 2016 at 4:07 PM
    Toynado
    SF Bay Area
  7. Oct 9, 2016 at 9:23 PM
    Toynado
    SF Bay Area
  8. Oct 17, 2016 at 8:50 AM
    Toynado
    SF Bay Area
  9. Dec 1, 2016 at 7:05 AM
    Toynado
    SF Bay Area
    still have them
  10. Dec 3, 2016 at 2:50 PM
    11x
    11x Well-Known Member
    jeff
    14 sr5 mgm 4x4
    I will take the skunk ape switch. Pm me your payment info.
  11. Dec 3, 2016 at 5:29 PM
    Toynado
    SF Bay Area
    PM sent
  12. Dec 3, 2016 at 5:38 PM
    11x
    jeff
    14 sr5 mgm 4x4
    Payment sent
  13. Jan 6, 2017 at 1:37 PM
    Toynado
    SF Bay Area
    Still got these two switches
  14. Feb 22, 2017 at 6:02 AM
    Toynado
    SF Bay Area
    Anyone?
  15. Mar 8, 2017 at 8:09 AM
    11x
    jeff
    14 sr5 mgm 4x4
    You should send me the other 2. I will pay shipping. ;). Good honest seller here guys. Don't be scared.
  16. Mar 8, 2017 at 10:48 AM
    Toynado
    SF Bay Area
    You need the other two? Want to do buy one get one free?
  17. Mar 10, 2017 at 6:26 AM
    11x
    jeff
    14 sr5 mgm 4x4
    Lol. For I needed them I would. I have 1 spare already but thanks
  18. Mar 10, 2017 at 6:40 AM
    Toynado
    SF Bay Area
    No problem...
    Anyone else, but one get one free offer extends to all
  19. Apr 1, 2017 at 3:37 PM
    Toynado
    SF Bay Area
  20. Jul 9, 2019 at 4:50 PM
    VirusCage
    VirusCage Overwhelmed with fun
    Bruce
    Allison Park, PA
    2017 TRD Sport DCSB 6MT 2015 Highlander XLE
    Hood deflector, window vent visors, stainless steps, kb voodoo bedrack, bed cubby cap seals, meso ext fuse cover, meso lower switch panel, 4xhella horns, power tray aux panel, 2wd lo mod, rear FU lights, bed led lights, BPF SKID and Hook, rear view mirror usb power ports, front and rear dash cam, front and rear cam anytime mod, cherry air freshener! Anytime 400watt, inside 110v outlet, BPF Skid plate, BPF shackle mount,
    2 years later...you still have these?
    crackils likes this.
