FS:Tacoma front and rear 3rds - Cheap
Discussion in '1st Gen Tacoma Parts Marketplace (1995-2004)' started by raidernation, Jun 5, 2011.
  1. Jun 5, 2011 at 11:26 AM
    raidernation
    raidernation [OP] Member
    I have had these in the garage for some time now and they need to go. They came out of a 98 Taco. Truck had manual hubs. Both in fine working order when I pulled them to put 4.10's in. Not the ideal gear ratio sought, but they would make great trail spares or just another set of diffs to start a new gear install with. Front has an ADD sleeve on it currently.
    (1) 8.4" Non-TRD rear 3rd with 3.58's & a used GOOD condition set 4.56's to go with it. - $100
    (1) 7.5" front 3rd with 3.58's - $100
    $150 for both.
    Located near Bakersfield CA. I would prefer local pickup.
  2. Jun 9, 2011 at 3:10 PM
    raidernation
  3. Jun 10, 2011 at 8:31 AM
    sweetwilliebrownj
    sweetwilliebrownj Member
    Will
    Brandon, ms
    05 xrunner urd supercharged
    Urd mkii supercharger, t56 swap in the works
    I need that 8.4 third member and gears for my t-56 swap. I need em badly.
  4. Jun 10, 2011 at 1:04 PM
    raidernation
    PM replied
  5. Jun 11, 2011 at 12:34 PM
    raidernation
    Rear 3rd and gears are sold. Front 3rd still for sale.
  6. Jun 12, 2011 at 9:25 AM
    raidernation
    $50 for the front.
  7. Jun 14, 2011 at 1:09 AM
    jesus
    jesus Well-Known Member
    jesus
    bakersfield
    K&N ram intake & doug exs.
    so I've been thinking of doing a convertion on my pre-runner is this the front I would need ???? s so I maybe able to take it off your hands
  8. Jun 14, 2011 at 11:42 AM
    raidernation
    Yup, this is the front diff you will need. I actually did a conversion on my 1st Tacoma that was a prerunner. Not much use on this front diff since it came off of my other Tacoma that had manual hubs.
  9. Jun 14, 2011 at 2:20 PM
    jesus
    jesus
    bakersfield
    I sent ya a pm and forgot to try to find out how much it be going for ....
  10. Jun 14, 2011 at 3:08 PM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    Hey Im currently doing my 4x4 swap and need A front diff,
    I'm thinking ill do manual hubs, you said this is what it originally had?
    I believe this front is the one I need.
    And I have 4.10's in currently
  11. Jun 14, 2011 at 9:48 PM
    raidernation
    Yup, this is a 1st gen front diff. It doesn't have 4.10's though. It has 3.58's and yes it came out of a truck with manual hubs. Check out TTORA for your swap questions. Several have been done over there with some good write ups.
  12. Jun 14, 2011 at 10:28 PM
    raidernation
    Almost forgot to mention Zuk. If you buy my differential you can take it to this guy www.gearinstalls.com (he's in phoenix) and have him do a new gear install and locker up front if you like. He's builds great differentials and his work speeks for itself. HIs prices are easy on the wallet. Lots of guys on Pirate 4x4 use him to install gears for big rockcrawler projects.
  13. Jun 14, 2011 at 11:20 PM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    Hmm ok then sounds good. my only question is can I go back to manual hubs? swapping with ADD I think is supposed to be more difficult, me and brian pulled apart a 4x4 tranny to pull out the output shaft and we'll be swapping that in soon but this should be what I need and then I could find
    some gears for it.
  14. Jun 15, 2011 at 12:12 AM
    raidernation
    Yes u can convert to manual hubs later. Manual hubs are highly desired and fewer trucks came with them so it will be much easier to find add hubs/spindles. ADD isn't hard to make work. Your truck should already have the vaccum pigtails under your fuse box. If so, all u need is some vaccum line, a 3 way rocker switch, the vaccum canister and the vaccum selenoid. When I did my conversion on my original taco, this is how I did it.
    If u dont want to go thay route and u can find manual hubs/spindles/cv's, then all u have to do to make your ADD diff full time engaged is by putting a small amount of vaccum on the engage side of the vaccum lines and them crimp/ seal the line and it will stay engaged allowing u to use manual hubs in stock manner
  15. Jun 16, 2011 at 10:23 AM
    raidernation
  16. Jun 16, 2011 at 4:17 PM
    jesus
    jesus
    bakersfield
    Just making sure I didn't delete my sub to this...
  17. Sep 2, 2012 at 7:47 PM
    raidernation
    Bump. I still have this front diff.
