FS: Tailgate OEM White 2005-2012
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by oildriller, Feb 4, 2014.
  1. Feb 4, 2014 at 10:55 AM
    oildriller
    oildriller [OP] Active Member
    Dean
    Shreveport, Louisiana
    Tacoma, TRD/Off-Road, 4X4
    Bilstein 5100 Series Struts & Shocks (Struts set 2.25", Stock Coil-overs). 1" Rear Leaf Spring Blocks. Throttle Body Spacer. K&N, High Flow-Air Filter. Toyota, OEM, TRD, Cat Back Exhaust (tail pipe cut off, behind muffler, installed 3"OD X 5"L X 45 deg, turn down, dumped prior to axle). Toyota, OEM, Running Boards. Bora, 1" hub-centric wheel spacers. Mud flaps & emblems removed. Satoshi grille (by Brian Roadruck).
    PRICE REDUCED!!!!
    Tacoma, OEM, Tailgate. 2005-2012. White. Handle painted White (identical match). NO Camera. NO Dents. NO Chipped and/or, Scratched paint. NO Rust. Includes: Right & Left Hinges, (2) Cables, Top Protector, Inner Panel. Used - removed from 2010 Tacoma.
    $390.00 (Shreveport, Louisiana)
  2. Feb 12, 2014 at 7:38 AM
    oildriller
    Dean
    PRICE REDUCED!!!!!!!!
