FS: The ProDucer livescope pole system
Discussion in 'Buy / Sell / Trade - Other' started by 02hilux, Jul 19, 2024.
  1. Jul 19, 2024 at 11:04 AM
    02hilux
    02hilux [OP] What do you mean there’s no road, I’m here
    Planet: EARTH
    Livescope transducer pole system made by The ProDucer for the Minn Kota Ultrex trolling motor. Fiberglass pole is 60” and can be trimmed to fit a 45” or 52” trolling shaft. Trimming is not necessary if you like to positioned the adjustment handle higher. I use this on a 52” trolling shaft even though it’s designed for a 60”.
    The mounting plate for the trolling motor head has main 2 placements (left or right side of the trolling motor) and each placement has 3 adjustments (to position the pole). The hole in the fiberglass pole at the bottom by the transducer is for the transducer wire to be fed through. The pole system mounts to the existing trolling motor pre-tapped holes. Will include a separator support with quick release clamp at both end that strap the fiberglass pole to the trolling motor shaft to prevent movement when stowed.
    Pole: 60”
    Handle: 28”-45” with ~3” adjustment increments.
    More information:
    https://shut-up-and-fish.com/the-pr...ing-motor-transducer-pole-system-not-f-quest/
    $220 shipped
    93720
  2. Jul 20, 2025 at 7:18 AM
    02hilux
    Planet: EARTH
