FS Thule xsporter 422xt Feeler
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by zscott, Aug 12, 2013.
  1. Aug 12, 2013 at 10:34 AM
    zscott
    zscott [OP] Well-Known Member Vendor
    Zach
    Utah
    13 DCSB Off-Road 4x4
    SOLD
  2. Aug 12, 2013 at 11:14 AM
    btwice22
    btwice22 Well-Known Member
    Bryan
    Cincinnati, OH
    2013 Tacoma TRD Dbl cab
    Window tint. LED's inside and out. Sylvannia Ultra Headlight bulbs Nokya 2500k fogs Digital Weathertechs Thule Xsporter
    So I was looking for one of these for my canoe. Would I be able to raise them high enough to clear a canoe over the cab since you cut them down?
  3. Aug 12, 2013 at 9:33 PM
    zscott
    Zach
    Utah
    I have been running two 8' kayaks on it and they clear the roof on the second to highest setting. I put them with the cockpit up though so the curve of the boat helps with more clearance. The highest setting would give you plenty of clearance but because they have been cut, it isn't as sturdy on the highest setting.
  4. Aug 12, 2013 at 9:36 PM
    zscott
    Zach
    Utah
    If you had foam blocks or some type of saddle to add a few inches for the canoe then the second to highest setting would be perfect. And it is rock solid at that setting.
  5. Aug 13, 2013 at 5:43 AM
    btwice22
    Bryan
    Cincinnati, OH
    Thanks for the input. I'm going to hold off for an uncut Xsporter. GLWS.
  6. Aug 13, 2013 at 4:43 PM
    zscott
    Zach
    Utah
    Anybody interested is welcome to make an offer. I am pretty sure I am going to get a shell so somebody needs to take this off my hands.
  7. Aug 13, 2013 at 5:30 PM
    18seeds
    18seeds Well-Known Member
    How about a pic in the raised position
  8. Aug 14, 2013 at 8:36 AM
    zscott
    Zach
    Utah
    Here are some pictures in the highest setting. You can see that it easily clears even the factory roof rack.
  9. Aug 14, 2013 at 8:39 AM
    zscott
    Zach
    Utah
    Here it is on the second to highest setting. Throw on some foam blocks or saddles for bigger boats and it will clear just fine. My boats clear fine due to the curve on the bottom if the boat and the shorter length.
  10. Aug 14, 2013 at 8:50 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    If you don't have the factory roof racks then would the 2nd setting would clear the roof with boats facing hull up?
    Just asking for someone who may not have the oem racks and interested in this setup. Also interested in knowing myself since I have the Thule rack and no oem rack. I have not cut mine so there is no issue having them on highest setting and don't really use them in lowest setting but it would be nice to have longboards down low to be behind cab and stick out over tailgate vs up in the wind. Kayaks are 12' so they will always need to be up high. Sorry for long post and semi-threadjack.
    edit - nvrmind, just saw your new pic of 2nd setting. looks a little low even with pads but maybe OK with saddles tho...........GLWS
  11. Aug 14, 2013 at 5:17 PM
    zscott
    Zach
    Utah
    Price updated in original post. Somebody must need this.
  12. Aug 15, 2013 at 5:11 PM
    zscott
    Zach
    Utah
    Put the boats on today on the second to highest mark. Took some pictures and the boats still clear the roof by about 3-4 inches. Turned them over and even upside down they still clear the roof by about an inch. I am thinking that any type of boat should clear the roof fine.
  13. Aug 15, 2013 at 5:12 PM
    zscott
    Zach
    Utah
    Pictures
  14. Aug 15, 2013 at 5:14 PM
    zscott
    Zach
    Utah
    Sorry for all the posts for some reason I can't attach more than one image at a time.
  15. Aug 20, 2013 at 5:56 AM
    Taco Delight
    Taco Delight Well-Known Member
    MA
    2016 Tacoma Limited 4x4 Super White w/ Hickory Lthr (Sold)
    (Sold) Tint, OME 887, 5100's, Nitto G2 265/70R18
    Interested. Pm'd you. Thanks.
  16. Sep 23, 2013 at 1:40 PM
    unstoppable
    unstoppable New Member
    Ian
    Denver, CO
    '13 V6 4X4 Double Cab
    Did you have to cut into the bed in order to put the uprights all the way down? Want to get this rack but afraid there's too much interference from the wheel wells.
    Thanks
