FS: TRD CAI
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by Hilborn, Sep 21, 2012.
  1. Sep 21, 2012 at 2:41 PM
    Hilborn
    Hilborn [OP] Adventure First. Safety Second.
    Michael
    Utah
    2009 Tacoma DCLB TRD Sport 4x4
    ADD W1 Oil Catch Can. AFE Magnum FORCE Stage-2 Si Cold Air Intake System. AlphaRex Black Pro-Series Headlights w/ LASFit Bulbs. Anderson Engineering Solutions Manifold Spacer. ARK Splash Guards. AVS Door Sill Protectors. BAMF Bolt-On Rock Sliders. BAMF CMC Plates. BedRug. Brute Force HC Rear Bumper. C4 Engine Skid. C4 Transmission Skid. C4 Transfer Case Skid. C4 Fuel Tank Skid. C4 Rear Diff Skid. Cooper Discoverer ST Maxx LT285/70R-17. Dirt King Ball Joint Upper Control Arms. Dirt King Lower Control Arms. Dirt King Spindle Gussets. Doug Thorley Y-Pipe. DRT Fabrication Shackle Hanger Kit. Eaton Detroit Trutrac Rear Differential. ECGS Bushing. Expedition Essentials Bedside ARB Air Compressor Mount. Garmin Overlander GPS. Genesis Gen 3 Dual Battery System w/ G Screen. HCF Delete. Husky Floor Liners. Hypertech In-Line Speedometer Calibrator (@1.038). IGGY Switch Panel. Ironman4x4 Foam Cell Pro Struts and Shocks. KPOffroad Alignment Cam Upgrade Kit. Leer 100XQ. Magnaflow Overland Series Cat-Back Exhaust w/ 10416 Muffler. Method Vex Titanium 17x8.5. Yukon 4.56 Gears. Odyssey Performance Group 34 Batteries (2). OME 886x Coil Springs. OME Carrier Bearing Spacers. OME CS047R Dakar Leaf Springs w/ D29XL. Overland Torque Tune. Pakrax Tailgate Panel. Pinch Weld Mod. Pop n' Lock. Power Stop Z36 Truck and Tow Brake Pads. rcbs204 Illumited 4x4 Switch. Rear Differential Breather Relocation. Rexing V1 Dash Cam. Scanguage 2 w/ TFT. Stahlbus Oil Drain Plug. Stoptech Cryo-Treated Rotors. Sway Bar Delete. Total Chaos Bed Stiffeners. Toyota 70mm Throttle Body. ToyTec Axle Degree Shims. URD 170° Thermostat.* URD 65 to 70mm Throttle Body Adapter. URD Exhaust Cam Gears. USA Spec IPod Interface. Voltage Booster Pro. Wheeler's Brake Lines. Wheeler's Front SuperBumps with 3/8" Spacers. Wheeler's U-Bolt Flip Kit w/ SuperBumps.
    First Gen TRD CAI for the 2005-2011 4.0L V6 - $275 (Shipping NOT Included) SOLD
  2. Sep 21, 2012 at 3:33 PM
    Scott78
    Scott78 Well-Known Member
    Scott
    Flagstaff, AZ
    '19 OR DCLB
    Is it 1st or 2nd? Add says first but it's posted in 2nd.
  3. Sep 21, 2012 at 3:37 PM
    Aw9d
    Aw9d That one guy
    :facepalm:
    It's the 1st generation of intakes that TRD made. Then they made a 2nd generation.
    First gen on left, second gen on right.
  4. Sep 21, 2012 at 3:39 PM
    easyeatlanta
    easyeatlanta Artificial Intelligence beats natural stupidity
    Eric
    Memphis
    14 DC Trd Off Road
    yeah its the first gen cai for the second gen truck
  5. Sep 21, 2012 at 4:42 PM
    Scott78
    Scott
    Flagstaff, AZ
    '19 OR DCLB
    AHHHHH well that makes sense and me look dumb.
    I'm one day into the second gen trucks. Just bought it last night. I had an '03 previously, so I've got to relearn.
  6. Sep 21, 2012 at 4:50 PM
    jmarquez808
    jmarquez808 Large Member
    Jess
    Hawaii
    07 4x2 reg cab / 12 4x4 double cab
    **Afe cold air intake w/pro dry filter, Yellow tint fogs, Daytime running lights, led dome light, led license plate lights, Led tail lights, 3 inch carbon antenna, spec d projector headlights, carbon fiber look interior trim pieces, Djm control arms, Djm notch, 4x4 leaf springs, beefed taco 2 inch blocks with offset pin, Rear Qa1 Shocks, Sittin sic stock height coils, x runner bilstein front shocks, weathertech digital fit floor mats, debadged.
    sexy time!
  7. Sep 21, 2012 at 5:10 PM
    Dave M
    Dave M Well-Known Member
    Dave
    Seattle WA
    12 S/C AC TRD Off-Road 4x4
    Supercharger Sunroof Leather Seats TRD Exhaust TRD Short throw Shifter
    PM sent
  8. Sep 21, 2012 at 7:27 PM
    ziggynagy
    ziggynagy All Glory To The Hypnotoad
    Stoughton, MA
    '11 Sport AC 4x4 V6 Auto Tow
    Westin step bars, led dome & map lights, tailgate hoseclamp, BluLogic, MetalMiller emblem, 35 tinted front windows, extra OEM d-rings, WeatherTech front/rear
    I learned something new today.
  9. Sep 22, 2012 at 2:17 PM
    Mr Souc
    Mr Souc Well-Known Member
    Joel
    Topsham Maine
    2011 Tacoma TRD Off Road
    - TacoME Satoshi - Hella Supertones - TRD front skid plate - TRD CAI - TRD cat-back exhaust - TRD short throw shifter - TRD 6 speed ball knob - Baja Soft 8 16" wheels - 285/75/16 BFG T/A KO2s - Pioneer AVH-P2400BT - OEM roof rack - Thule Aero roof rack - TSB Add-A-Leaf - 1" Level spacer up front - 5100s front & rear - Eibach 620lb coils - Toytec 2" add-a-leaf - Plasti-Dip bumper, badges, & roof
    I'll call 2nd dibs after Dave M plz :)
  10. Sep 22, 2012 at 2:46 PM
    hilux30
    hilux30 Well-Known Member
    PEI
    '15 4Dr SB 6MT
    OTT tune 3 degree cam gear OME/Dobinson
    That's the one to have, according to URD the 2nd gen CAI is bad design too much air turbulence at the MAF sensor, why you selling this?
  11. Sep 22, 2012 at 2:48 PM
    Aw9d
    Aw9d That one guy
    I've had both and both were fine for me. I didn't throw codes until Toyota threw the MAF gasket away.. replaced it and no issues.. Got a 1st gen because I wanted to make a customer see through top for it.
  12. Sep 23, 2012 at 4:29 AM
    Mr Souc
    Joel
    Topsham Maine
    Scratch my dibs plz - found something that blows my skirt up a little more. Thanks though!
