FS: TRD Supercharger, URD 7th Injector kit, an URD 2.2" Pulley
Discussion in '1st Gen Tacoma Parts Marketplace (1995-2004)' started by QuadsBC, Jun 29, 2017.
  1. Jun 29, 2017 at 10:19 AM
    QuadsBC
    QuadsBC [OP] DON'T BUY FROM ME
    limited 4runner
    I am selling a used TRD supercharger with about 8k miles on it. Part # PTR01-35962-01 newer TRD part # PTR29-89020 .
    This is a used but in excellent condition TRD supercharger produces a maximum horsepower gain of 75hp at 5200 RPM and a maximum torque gain of 77lb.ft. at 5200 RPM. Peak horsepower gain is 64hp (187hp to 251hp) and peak torque increase is 50lb.ft. (225lb.ft. to 275lb.ft.). You must run premium 91 octane fuel!!!
    This part fits the following vehicles:
    Toyota: 4Runner 1996 - 2002
    Toyota: Tacoma 1997 - 2004
    Toyota: Tundra 2000 - 2004 3.4l
    Wont work with engines with EGR Valves if used with URD 7th injector kit.
    I purchased the Trd Supercharger from a man who removed it from his leased Tacoma before he returned it. I have not used it, I was in the process of building a complete kit when I sold my 01 tacoma for a newer one which this will not work on. It is missing one part for installation the throttle body gasket made specifically for the supercharger. TRD part # PTR29-60030 it can be found on trdparts4u.com for $8.40 plus shipping.
    Also included is a brand NEW in the box URD 7th injector kit, Which includes a piggyback computer, Walboro fuel pump, extra injector, tuning software, all necessary parts to install. It comes pre programmed to supplement the factory fuel system to make the 3.4 TRD supercharger not only run more efficient and reliable, but gains 30 to 40 HP. Thats a total of 280-290 HP. with better reliability. It however will not work on the 5vz-fe 3.4 engines which have EGR valves. The 7th injector is designed to mount in the port the EGR would have been routed to on the supercharger, making it unusable on those vehicles with EGR's.
    Also included is a URD 2.2in Supercharger pulley.
    Asking for $2900 shipped.
    Thanks
  2. Jun 29, 2017 at 1:49 PM
    Clay_916
    Clay_916 Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    $3,000 for a brand new second gen SC and a brand new 7th injector + 2.2"! Won't find a better deal than this people.
    Dalandser and 12TRDTacoma like this.
  3. Jun 29, 2017 at 1:50 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Agreed. This is a steal for a full setup!
  4. Jun 30, 2017 at 6:57 AM
    BoilerUp
    BoilerUp Well-Known Member
    2004 V6 Double Cab TRD PreRunner
    So the 7th injector won't work with the 3.4 engine?
  5. Jun 30, 2017 at 9:55 AM
    Oside7even6ixty
    Oside7even6ixty Well-Known Member
    Willing to separate the 7th injector kit/2.2 pulley?
  6. Jun 30, 2017 at 12:52 PM
    tacotime1
    tacotime1 Well-Known Member
    Not what he said
    will not work on the 5vz-fe 3.4 engines whichhave EGRvalves.
    MikeyD308 likes this.
  7. Jun 30, 2017 at 4:16 PM
    TRD4WD
    TRD4WD Supreme Leader
    Micah
    Gonzales, LA
    2004 Double Cab TRD
    Isn't the that the Engine that came in all V6 tacomas?
  8. Jun 30, 2017 at 4:20 PM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    not all V6 Tacomas.
  9. Jun 30, 2017 at 5:42 PM
    BoilerUp
    That's what I was thinking too, but did some additional research and found out that older Tacos (98-99? ) have the EGR valves.
  10. Jun 30, 2017 at 5:50 PM
    eon_blue
    Azusa, CA
    Correct. Most if not all of the later year 3.4l trucks came without EGR. Early model years were more likely to have it. I just got the 7th injector kit installed on my 04 v6 a few weeks ago.
    EGR equipped Tacomas with the supercharger are recommended to run URDs larger injector kit to solve lean issues since they can't run the 7th injector.
  11. Jun 30, 2017 at 5:53 PM
    Oside7even6ixty
    I have a 96, no egr
  12. Jun 30, 2017 at 11:35 PM
    Milota95
    Milota95 Mall Crawling Specialist
    Qrampage
    B.F.E
    97 SX Single Cab V6 ~ 95.5 SX Single Cab 4c ~ 81 Pickup
    Driven Safely
  13. Jul 1, 2017 at 9:27 PM
    bigwill837
    bigwill837 Well-Known Member
    Will
    Austin, TX
    1996 HZJ75 Land Cruiser Pickup
    Can you just delete EGR and run the 7th injector kit?
  14. Jul 1, 2017 at 9:53 PM
    ekul310
    ekul310 Well-Known Member
    Luke
    Pennsylvania
    2002 Lunar Mist Regular Cab 4x4
    Stock stock stock
    This is VERY tempting. Not sure whether to go this route or just regear. Currently running 32x11.5 but looking to bump up to 33s when these wear out
  15. Jul 1, 2017 at 10:08 PM
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    Lol. This is the only application it works on.
  16. Jul 1, 2017 at 10:09 PM
    TashcomerTexas
    Boost > regear
    Thank me later.
    eon_blue likes this.
  17. Jul 1, 2017 at 10:11 PM
    eon_blue
    Azusa, CA
    ^^^ this
  18. Jul 2, 2017 at 9:21 AM
    Jayjayb96
    Jayjayb96 Well-Known Member
    Jay
    SF Bay area, Ca
    02 4runner
    Sc'd. Arb rear locker, compressor, toytec coilovers w/eibach 600 lb springs, ome 890s, lc oem shocks, toytec panhard bar drop, ss extended brake lines, spidertrax 1.25" spacers, 275 70 bfg ko2 on scs sr8s, deckplate, isr, andymod 2.0
    @QuadsBC if you decide you can sell
    The 7th and 2.2 pulley seperately lmk! Interested pending price.
  19. Jul 2, 2017 at 9:31 AM
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    I don't see why not. I deleted the EGR on my 3rz when I turbocharged it. I just needed a 10k ohm resistor to keep the check engine light off. I would guess the process is similar on a 5vz
  20. Jul 2, 2017 at 10:41 AM
    ekul310
    Luke
    Pennsylvania
    Stock stock stock
    Looks like I need to sell the jeep to fund the s/c... if anyone here is interested in a GREAT winterbeater..
    eon_blue[QUOTED] likes this.
