FS: Truck bed switch mount (2020+) $26
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by switch, Oct 24, 2022.
  1. Oct 24, 2022 at 7:56 PM
    switch
    switch [OP] Well-Known Member
    Norther California
    2022 Tacoma Access Cab
    Use this switch panel mount to add 4 switches to the bed of your Toyota Tacoma. This mount uses the existing access cut out of your truck bed. There are two cut outs (one on each side) so you can install up to 8 switches in your truck bed. I installed these switches in my truck to power the same lights that I could turn on from inside the cab. These mounts create a dust proof and moisture resistant (but not water proof) location for connecting a 4 gang switch (sold separately) made by FXC: Rocker Switch Aluminum Panel 4 Gang Toggle Switches
    These mounts to not require drilling because they fit very snug, but I drilled holes anyway because I wanted a "finished look"
    I designed these mounts using FreeCAD software and they are printed from PETG plastic using a Prusa MK3S 3D printer.
    Here is the finished installation on the driver's side:
    This is the mount with the FXC Rocker Switch Aluminum Panel 4 Gang Toggle Switches
    Here is the mount:
    The mount uses the existing access cut out in your truck bed:
    Before:
    After:
    There is enough space in the mount for all of the wires so the switches and wires are in a dust proof and water resistant enclosure.
    This mount uses FXC Rocker Switch Aluminum Panel 4 Gang Toggle Switches
    vivid02, Phoosa, Mclovin80 and 3 others like this.
  2. Oct 24, 2022 at 8:37 PM
    TwinTaco31719
    TwinTaco31719 Well-Known Member
    Eric
    Glenbrook, NV
    2023 Lunar Rock LB Sport
    Now that’s a good use of the bed light area!
  3. Oct 24, 2022 at 8:53 PM
    Mr. Excitement
    Mr. Excitement Well-Known Member
    J
    Custom floormats, fuzzy dice
    Wow that’s sweet! Great job man. Can’t wait to see them for sale.
  4. Oct 24, 2022 at 9:10 PM
    GrizzledBastard
    GrizzledBastard OH NO! I've built a Faux Pro!
    Tim
    Central Coast, CA
    '21 TRD OR 4x4 DCLB Super White
    Not enough bandwidth on the internet to list.
    This be the "marketplace". Is this system "for sale"?
  5. Oct 24, 2022 at 9:16 PM
    Tacos4Runnin
    Tacos4Runnin Well-Known Member
    Okanagan…eh
    2021 TRD-Sport AG/MT
    Be awesome to re-locate the bed 400 watt plug switch to this area of the truck. Never liked it being inside cab of the truck
  6. Oct 24, 2022 at 10:29 PM
    switch
    Norther California
  7. Oct 24, 2022 at 10:35 PM
    switch
    Norther California
    Yeah, I thought about using those cut outs for this purpose. That factory stuff is under powered and not always on.
    I have an ARE truck cap with wrap around shelves so I ran 10AWG wire to the bed and put outlets on the shelves
    Located the USB and 12V adaptors on shelves in the bed
    Tacos4Runnin[QUOTED] likes this.
  8. Oct 30, 2022 at 8:01 PM
    switch
    Norther California
    For sale on Etsy and direct on TacomaWorld (message me).
  9. Oct 31, 2022 at 9:12 AM
    robson1015
    robson1015 Well-Known Member
    Bob
    New Concord, Ohio
    2009 base tacoma- regular cab- 5 speed
    Not water proof - what good is that ?
  10. Oct 31, 2022 at 2:50 PM
    switch
    Norther California
    The switches are not water proof. I have a shell on my bed. So I'm not worried about water on the switches. Where I am worried about water is on the electrical contacts behind the switches. My mount allows the switches to extend into the area between the bed and the body which can be a very wet area. But my mount completely encloses the electrical contacts to the switches & all of the wires exit a small hole at the bottom of the mount with a grommet.
    So water is not going to splash onto the switch contacts. I'd basically have to submerge the mount for water to get in there.
    So yeah, not water proof. Water resistant.
    [EDIT]
    I found this (waterproof) switch block which looks to be the same size as the one I used.
    The spade connectors are still exposed so I think it would still make sense to enclose the back side of the switch panel where it would be exposed to the elements between the truck bed and body...
  11. Nov 5, 2022 at 5:22 PM
    c_walters
    c_walters Well-Known Member
    Mooresville, Nc
    2019 TRD Sport 6MT MGM
    now there’s a site I haven’t heard in years (ttora)! Nice looking panel OP!
  12. Nov 5, 2022 at 8:44 PM
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    OP, you may wish to put “2020+” in the title since that’s when the bed light cutouts started. One of the things I do wish I had on my truck.
    musicisevil likes this.
  13. Nov 5, 2022 at 8:53 PM
    caribe makaira
    Caribbean, Puerto Rico
    A template, some balls and choice cutting tool would cover all "years"...
    switch[OP] likes this.
  14. Nov 5, 2022 at 9:00 PM
    switch
    Norther California
    can't figure out how to change the title...
  15. Nov 5, 2022 at 9:01 PM
    switch
    Norther California
    Also, what the hell are these cut outs for?
  16. Nov 5, 2022 at 9:09 PM
    daveeasa
    David
    PNW
    switch[QUOTED][OP] likes this.
  17. Nov 5, 2022 at 9:14 PM
    daveeasa
    David
    PNW
  18. Dec 7, 2022 at 5:36 PM
    switch
    Norther California
    I used up all four switches on both sides of my bed pretty quickly. So I started thinking about adding more switches & also wanted dimmer capabilities. Waterproof switches would be a great too...
    So this is what I have in prototype stage using touch sensitive stepping dimmer switches instead of rocker switches.
    I should have on Etsy at some point but message me if you are interested. If I can source an LED light that fits the 18mm hole, that could be a nice option when you don't need 8 switches. Let me know what you think..
    msgs350 and daveeasa like this.
  19. Dec 7, 2022 at 7:12 PM
    daveeasa
    David
    PNW
    Beautiful!
  20. Jan 7, 2023 at 9:43 AM
    switch
    Norther California
