FS: URD Throttle Body Adapter, 65 to 76mm for 1GR-FE 4.0L V6 (05+ Tacoma, 07-09 FJ, 03-09 4Runner)
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by lucky, Mar 3, 2019.
  1. Mar 3, 2019 at 12:18 PM
    lucky
    lucky [OP] Well-Known Member
    NB, TX
    07 PreRunnerX4
    Like new, never used, never installed. Been sitting on my shelf for years. Currently out of stock at URD.
    $50 PP, friends&fam, shipped US only.
    From URD...
    This CNC billet machined adapter plate will allow you to install a larger throttle valve on your single VVTi 1GR-FE 4.0L V6 engine.
    It fits the 1GR-FE engines with the single VVTi (05+ Tacoma, 07-09 FJ, 03-09 4Runner) and allows you to move from the stock 65mm throttle and upgrade it to the 76mm throttle valve found on the later dual VVTi engines found in the 2005+ 2UZ-FE 4.7L V8 and 2007+ 3UR-FE 5.7L V8. Throttle valve from a 2006 Sequoia does not fit.
    This adapter is used to install the much larger (76mm) throttle valve from the larger Toyota engines to your 4.0L V6.
    It is a simple bolt on installation, but will take a little while for the stock ECU to learn to properly control the idle. This will be much easier to do on automatic transmission trucks than the manual transmission trucks.
  2. Mar 3, 2019 at 12:22 PM
    3rYODA
    3rYODA Don’t sell to me, I don’t pay.
    Santa Clarita, CA
    2015 white 4x4 TRD
    Fox 2.5’s up front, icon 2.0 rear shocks, stock leafs, !Meso map and dome lights make all the difference in the world!
    What dose this actually do when upgrading to the 76mm ? Better throttle response? Better mpg? More power?
  3. Mar 3, 2019 at 12:25 PM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    PM Sent. Been waiting for a while on URD.
  4. Mar 4, 2019 at 7:32 AM
    lucky
    NB, TX
    07 PreRunnerX4
    SOLD
  5. Apr 18, 2021 at 10:23 AM
    trd pr0
    trd pr0 Well-Known Member
    Geary
    san francisco
    Tacoma trd offroad cement
    AR15 knobs for the radio, ovtune, bigmouth dump tube by ovtune, manual, ripp supercharger coils, trd drop in air filter, rock sliders , trd skid, fuel tank skid ,rear shock skids, hids, meso customs
    Did you ever get an answer of what benefits or negative on the upgrades
