FS: VIAIR Portable Air Compressor model 450P-A
Discussion in 'Buy / Sell / Trade' started by zx5go, Jan 6, 2011.
  1. Jan 6, 2011 at 11:13 AM
    zx5go
    zx5go [OP] Well-Known Member
    Southwest Missouri
    2011 Super White TRD Sport
    --------------------SOLD--------------------
    Description: Portable air compressor by VIAIR model 450P-A. This is the 100% duty cycle rated model. I've used this to air up two sets (8 tires) of tires and that is it. Used but in like new condition with all the items it came with originally.
    Price: $225 shipped or $200 picked up
  2. Jan 6, 2011 at 11:26 AM
    Hunter500ky
    Hunter500ky Well-Known Member
    E-Town Ky
    06 Tacoma 4x4 SR5
    Weathertech Mats, Toolbox, 6k HID fogs, Hardwire Escort 8500 x50,
    Nice Im diggin that.
    GLWS I might have to get one of those one days
  3. May 12, 2011 at 2:02 PM
    zx5go
    Southwest Missouri
    Any interest?
  4. Jan 16, 2012 at 5:42 AM
    zx5go
    Southwest Missouri
    Still for sale.
  5. Jan 16, 2012 at 7:34 AM
    anethema
    anethema Well-Known Member
    J
    Dawson Creek,BC
    08 TRD OR Access cab 4x4
    ARB Bumper,OEM Roof rack modded for access cab, Allpro Rock Sliders,Icon Adjustable coilovers,More Tie Downs in bed, Firestone Airbags in rear,Block heater
    Why selling?
    And would that fit in the engine bay?
  6. Jan 16, 2012 at 7:36 AM
    zx5go
    Southwest Missouri
    I no longer off-road enough to need it.
    It would fit in the engine bay but due to heating I wouldn't place it there.
  7. Jan 16, 2012 at 7:56 AM
    rob1
    rob1 Well-Known Member
    Robert
    South Texas
    Indigo Blue DblCab 4X4 Long Bed TRD Sport SR5
    Tail gate mod, locking gas cap, locking spare tire, rear spring tsb,Weathertech Digital fit's
    Wow you still have this I thought this thing would have been long gone. Intrested but saving up for family trip to Hawaii this March. Anyways thought I'd help you out in selling it. Below is some info I looked up.:) It's from a website ...4x4groupbuy.com
    Viair 450P-Automatic Portable Air Compressor (P/N: 45043)
    Onboard Air / CO2 / Compressors » Compressors » Viair 450P-Automatic Portable Air Compressor (P/N: 45043) [​IMG]
    Click here to enlarge
    [/URL]0
    Item Number: 45043
    [ Add to Wishlist ] [ View Wishlist ]
    $309.95
    Stock Status: In Stock!
    Award Points: 310 points valued at $1.55
    Quantity:
    Products Description
    [SIZE=+1]450P-Automatic[/SIZE]
    Portable Air Compressor [SIZE=-2](P/N: 45043)[/SIZE]
    12-Volt
    Permanent Magnetic Motor
    Duty Cycle: 100% @ 100 PSI
    Max. Working Pressure: 150 PSI
    Amp Draw: 19 Amps
    Min. Ambient Temp: -40 °F
    Max. Ambient Temp: 158 °F
    Dimensions: 12.50" L x 6.00" W x 7.25�?� H
    Net Weight: 12.73 lbs.
    450P-Automatic is VIAIR's first 100% duty cycle portable compressor. This compressor can run for hours at a time without needing to be rested when run to pressures under 100 PSI. The 450-P Automatic comes with another first as well - automatic shutoff function, when air is not being pumped into a tire and the units air line contains 150 PSI. The 450P-Automatic comes with a close-ended gas station-style air gun for added convenience.
    450P-A Performance Data
    PSI CFM A bar LPM A
    0 1.66 11 0.0 47.0 11
    10 1.55 12 1.0 42.0 13
    20 1.41 13 2.0 38.5 14
    30 1.34 15 3.0 36.5 16
    40 1.31 16 4.0 34.0 17
    50 1.27 16 5.0 30.5 18
    60 1.18 17 6.0 28.0 18
    70 1.09 18 7.0 26.5 19
    80 1.04 18 8.0 25.0 19
    90 0.97 18 9.0 23.0 18
    100 0.94 19 10.0 21.0 18
    110 0.90 19
    120 0.86 19
    130 0.81 18
    140 0.76 18
    150 0.72 18 *Supply Voltage: 13.8 Volts
    [SIZE=-1]450P-A Standard Features:[/SIZE]
    [SIZE=-1]Oil-less Design[/SIZE]
    [SIZE=-1]High Performance PTFE Piston Ring[/SIZE]
    [SIZE=-1]Stainless Steel Valves[/SIZE]
    [SIZE=-1]Moisture & Dust Resistant[/SIZE]
    [SIZE=-1]Gearless Direct Drive Motor[/SIZE]
    [SIZE=-1]Anodized Aluminum Alloy Cylinder Automatic Reset Thermal Overload Protector[/SIZE]
    [SIZE=-1]Dual-Stage Metal Air Filter[/SIZE]
    [SIZE=-1]Aluminum Sand Tray with Vibration Isolators[/SIZE]
    [SIZE=-1]Deluxe Dual Compartment Carry Bag[/SIZE]
    [SIZE=-1]3-pc. Inflation Tips Kit[/SIZE]
    [SIZE=-1]25 ft. Quick Connect Extension Hose with Heat Shield[/SIZE]
    [SIZE=-1]Gas Station-Style Tire Gun with 200 PSI Gauge[/SIZE]
    [SIZE=-1]Dual Battery Clamps with 40-amp Inline Fuse Holder[/SIZE]
    450P-A Tire Inflation Rates
    Begin/End PSI 31" X 10.5"
    0 To 30 PSI 4 Min. 05Sec.
    15 To 30 PSI 2 Min. 10Sec.
    Begin/End PSI 33" X 12.5"
    0 To 30 PSI 5 Min. 30 Sec.
    15 To 30 PSI 2 Min. 50 Sec.
    Begin/End PSI 35" X 12.5"
    0 To 30 PSI 6 Min. 55 Sec.
    15 To 30 PSI 3 Min. 30 Sec.
  8. Jan 16, 2012 at 9:37 AM
    anethema
    J
    Dawson Creek,BC
  9. Jan 18, 2012 at 8:27 AM
    anethema
    J
    Dawson Creek,BC
    Offer still stands (it was not a lowball for those others reading :p)
  10. May 8, 2012 at 9:06 AM
    zx5go
    Southwest Missouri
    SOLD
