FS: Waterproof Under Bed Rail LED lights
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by mattgecko, Dec 12, 2012.
  1. Sep 24, 2016 at 6:16 PM
    #1421
    Frito
    Frito Well-Known Member
    Excellent quality product, fast shipping turnaround, easy to read and follow instructions. A good hit all the way around. Thanks Matt !
    I love how the hood lights throw !
    mattgecko[OP] likes this.
  2. Sep 25, 2016 at 5:35 PM
    #1422
    captainbuttfloss
    captainbuttfloss #16!
    Melbourne, FL
    2015 Tacoma Prerunner
  3. Sep 26, 2016 at 1:18 PM
    #1423
    trekker
    trekker I like tacos
    Brandon
    Pocatello, ID
    '14 DCSB TRD OR MGM
    floor mats and a beer switch
    Another happy customer here. The warm white lights look great under my Softopper. I had a slight hickup during install when the remote wouldn't work as I hooked the lights up to power. They just kept flashing. I pulled the fuse for a few seconds to cut the power and once I replaced the fuse the remote worked perfectly. I had searched on here to see if anyone else may have had that happen before I pulled the fuse and couldn't find anything... so hopefully this helps if someone encounters that minor glitch in the future. Thanks for a great kit Matt!
    On another note... what are y'all doing with your remotes? I put a small piece of velcro on mine and stuck it to the underside of the console lid so I don't lose it.
    Quakes15 and mattgecko[OP] like this.
  4. Sep 26, 2016 at 3:27 PM
    #1424
    mattgecko
    mattgecko [OP] The LED Lighting Guy. MattGeckoLEDs.com
    South San Jose, CA
    2011 DCSB O.R. 4wd TRD Super Charged
    Thanks everyone for sharing install pics!
    The remote, upon first start up always flashes. What makes it confusing is the switch has a separate power source, turn the remote off and check the switch as it may also be in the on position.
  5. Sep 26, 2016 at 8:11 PM
    #1425
    1madmnky
    1madmnky Well-Known Member
    Tony
    Kansas via Fullerton 714
    2010 Tacoma 4X4 DCLB
    Hella Supertones
    Quality product! Thanks Matt!
  6. Sep 27, 2016 at 5:35 AM
    #1426
    Caprizzy
    Caprizzy Well-Known Member
    David
    Lake Stevens,WA
    2013 Silver Streak Mica, DCLB TRD Sport 4x4
    GO HAWKS!!
  7. Sep 27, 2016 at 11:49 AM
    #1427
    Caprizzy
    David
    Lake Stevens,WA
    GO HAWKS!!
    Also do the lights come on for all the doors when opened individually?
  8. Sep 27, 2016 at 2:44 PM
    #1428
    captainbuttfloss
    Melbourne, FL
    constant power from the battery, tapped into the dome light ground in the driver's side fuse area.
    Yes they do
  9. Sep 27, 2016 at 3:50 PM
    #1429
    Caprizzy
    David
    Lake Stevens,WA
    GO HAWKS!!
    did you install a switch as well, just curious why the constant powers?
  10. Sep 27, 2016 at 3:51 PM
    #1430
    captainbuttfloss
    Melbourne, FL
    No switch, I just searched and wired like other people had posted on here that wanted something to light with the dome light.
  11. Sep 27, 2016 at 3:55 PM
    #1431
    Caprizzy
    David
    Lake Stevens,WA
    GO HAWKS!!
    So did you run both power wires together and then your ground?
  12. Sep 28, 2016 at 4:59 AM
    #1432
    Caprizzy
    David
    Lake Stevens,WA
    GO HAWKS!!
    I was wondering if you had any further wiring instructions to do this mod or point me in the direction of some threads you used? I am wanting to do the same sort of thing. Thanks
  13. Sep 28, 2016 at 9:24 AM
    #1433
    mattgecko
    South San Jose, CA
    I'll PM you info.
  14. Sep 28, 2016 at 12:11 PM
    #1434
    Caprizzy
    David
    Lake Stevens,WA
    GO HAWKS!!
    did you just use a fuse tap?
  15. Sep 28, 2016 at 1:33 PM
    #1435
    mattgecko
    South San Jose, CA
    No, the interior lights use the ground wire as a trigger and not the power wire.
  16. Oct 1, 2016 at 1:39 PM
    #1436
    jsucraig
    jsucraig Well-Known Member
    Craig
    Lynchburg, Virginia
    2013 Tacoma TRD Off-Road Double Cab
    Mudflaps removed, MESO LED Interior lights, 886 Fog Lamps for Reverse Halogens, Redline Tuning Hood Struts, Garmin Dashcam 20, 17X8 Chrome Helo HE791 MAXX Wheels, Cooper Discoverer AT3 265/70R17, JBL Speakers, JL Sub, and Alpine & Memphis Amps, mattgecko LED Bed Light & Under Hood Kit, Truxedo Low Pro QT Tonneau Cover, OEM Bed Mat
    Finally made time to get my bed lights done. I'll post pictures tonight.
    duece5811 and Dark505 like this.
  17. Oct 1, 2016 at 11:56 PM
    #1437
    FLEXmastaFLEX
    FLEXmastaFLEX New Member
    Could you send me the instructions? I'd like to read over them before purchasing.
  18. Oct 2, 2016 at 7:57 AM
    #1438
    mattgecko
    South San Jose, CA
    Thanks for sharing your pics! Nice car lift.
    PM sent.
  19. Oct 2, 2016 at 9:06 AM
    #1439
    jsucraig
    Craig
    Lynchburg, Virginia
    Thanks more lift pics:
    Benzdriver81 and robssol like this.
  20. Oct 2, 2016 at 9:56 AM
    #1440
    mattgecko
    South San Jose, CA
    Nice way to turn a two car garage into a three car. :thumbsup:
