FS: Westin light bar and 6" off road lights
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by mattgecko, Nov 30, 2012.
  1. Nov 30, 2012 at 8:42 PM
    mattgecko
    mattgecko [OP] The LED Lighting Guy. MattGeckoLEDs.com
    South San Jose, CA
    2011 DCSB O.R. 4wd TRD Super Charged
    ................................................................ SOLD ........................................................
    I rarely used the off road lights so the whole setup is sitting in my garage.
    (1)Westin light bar - the wiring is ran inside the bar.
    (3) 6" pro-comp 100w off road lights
    (3) proc-omp covers (painted MGM)
    (3) 6" KC stone guard (black)
    $150 cash, local pick up Nor-Cal
  2. Dec 1, 2012 at 10:14 AM
    Wrx2Taco
    Wrx2Taco Active Member
    Northern Cal/da Burgh
    06 Prerunner
    Where more specifically are you in Nor cal, please and thanks
  3. Dec 1, 2012 at 11:21 AM
    mattgecko
    South San Jose, CA
    San Jose and Hollister.
  4. Dec 1, 2012 at 2:27 PM
    baja tacoma 06
    baja tacoma 06 Well-Known Member
    Jorge
    Mexicali, Baja / Calexico, CA
    2018 TRD Off-Road DCSB Inferno
    A few.....
    Will you ship to 92231? if so how much?
  5. Dec 1, 2012 at 2:59 PM
    mattgecko
    South San Jose, CA
    Do to the size it would cost to much to ship. If its still available in April, I be passing through Calexico on my way to San Felipe.
    When I wired it up I took each light apart, connected the wires inside the lights and then drilled the bar, installed rubber grommets and fished the wires though the bar. There is enough 12 gauge wire to run up to the battery. Its a very clean job.
  6. Dec 1, 2012 at 3:26 PM
    rubenc87
    rubenc87 Cobra
    Texas
    2025 Tacoma TRD PRO
    Do you have pics of where you drilled the light bar?
  7. Dec 1, 2012 at 3:56 PM
    mattgecko
    South San Jose, CA
    This was before I installed the lights. It wa a b*tch fishing the wires through the bar.
  8. Dec 1, 2012 at 3:57 PM
    rubenc87
    rubenc87 Cobra
    Texas
    2025 Tacoma TRD PRO
    That looks very clean. Nice job.
  9. Dec 1, 2012 at 5:38 PM
    baja tacoma 06
    Jorge
    A few.....
    Probably too good a deal for u to still have it in April....we can only hope then. Bar looks clean, nice job.
  10. Jan 9, 2013 at 12:48 PM
    Ron Turturici
    Ron Turturici New Member
    Ron
    Santa Cruz, CA.
    standard fare
    Is this still available? Would drive over NOW if so.
  11. Jan 9, 2013 at 2:20 PM
    NormLC
    NormLC Member
    San Francisco
    13 TRD OFF ROAD
    Are these still available and if so will it go on a 2013.
  12. Jan 9, 2013 at 2:34 PM
    mattgecko
    South San Jose, CA
    2005-2011 only
  13. Jan 9, 2013 at 2:42 PM
    NormLC
    NormLC Member
    San Francisco
    13 TRD OFF ROAD
    Ok thanks.
  14. Jan 9, 2013 at 3:28 PM
    rubenc87
    rubenc87 Cobra
    Texas
    2025 Tacoma TRD PRO
    The lower grill is narrow compared to the '05-'11. It is mounted through there.
  15. Jan 9, 2013 at 3:41 PM
    rubenc87
    rubenc87 Cobra
    Texas
    2025 Tacoma TRD PRO
    Money talks
  16. Jan 9, 2013 at 6:14 PM
    mattgecko
    South San Jose, CA
    It sure does ..... bar and lights are SOLD.
  17. Jan 9, 2013 at 8:51 PM
    rubenc87
    rubenc87 Cobra
    Texas
    2025 Tacoma TRD PRO
    Congrats
  18. Jan 10, 2013 at 12:45 PM
    Ron Turturici
    Ron
    Santa Cruz, CA.
    standard fare
    Hey Matt, I just wanted to officially thank you once again. Going to install today after my girls go down for a nap!
  19. Jan 10, 2013 at 2:40 PM
    rubenc87
    rubenc87 Cobra
    Texas
    2025 Tacoma TRD PRO
    Try to get a before and after pics.
  20. Jul 13, 2014 at 5:19 AM
    TRDh4vok
    TRDh4vok Well-Known Member
    Gil
    Palm Beach County
    '09 TRD PreRunner Sport
    -4" MaxTrac Spindle lift -5100 RCD Bilstein's -1/2" Strut Spacer driver's side (Taco Lean fix) -1/4" Strut Spacer passenger side (Taco Lean fix) -4" Tapered Blocks -Extended length U bolts -Front Skid Plate -Exhaust Tip -Tube Steps - Silver -Bed Extender -LEER Tonneau Cover -Rampage Roof Cab Lights -Rampage Tailgate Light Bar Six Function SUPERBRITE with Reverse Lights, Running Lights, Brake lights, Emergency Hazard and L & R turn signals -exLED Toyota Tacoma Custom interior LED Light Kit -PIAA Xtreme White Plus head lights and fog lights -NITTO Terra Grapplers 285-70-17 -30" Avec CR-Series Led Light Bar in bumper grill -Two 6.5" Led light bar's attached to the A pillars -Hood hinge bracket mounts from Famous Fabrications -Exhaust muffler Aero Turbine AT2525XL -OEM Roof Racks -OTTRAW Rocker switch -Stant locking gas cap -Large T emblem and mid mount bracket from Diaz Fabrications
