fuckin oil
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacoan, Aug 12, 2011.
  1. Sep 8, 2011 at 6:02 PM
    tombiosis
    tombiosis Well-Known Member
    T
    Ottawa Canada
    2016 TRD offroad access
    2016 Tacoma Access Cab, Super White, TRD Off Road package,//OEM Running Boards//TriFold2.0 Tonneau Cover//FJ Cruiser TRD SE Black TrailTeams replca wheels!
    that's what I'm running in my 05
  2. Sep 8, 2011 at 6:05 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
  3. Sep 8, 2011 at 6:16 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Free dealership oil change huh? Hey, at least they put oil back in.
  4. Sep 8, 2011 at 6:31 PM
    2TRunner
    2TRunner Snoop Dad
    My House Usually
    I think the 2011 Accords are requiring a 0-20 oil while still using the same 2.4L engines they've stuck in everything that is not a civic or a V6.
    I know nothing if the 2011 Tacomas are only saying 0-20, but I wouldn't be surprised.
    It's all about fuel economy.
  5. Sep 8, 2011 at 6:58 PM
    inesshell
    inesshell blah blah blah
    All stock Superwhite 10' AC
  6. Sep 8, 2011 at 7:06 PM
    Fink
    Fink Motorboatin' SOB
    Orlando, FL
    2013 Regular Cab 4x4
    WeatherTechs, 265/75-16 DuraTracs, ATX Mojave Teflon Wheels, ARE V-Series Shell
    Nothing will happen, and if it does, just bring in the receipt and tell them to call you when it's fixed.
    On a side note, they come with Mobil 1 5W-30 conventional in them...so I don't see any reason to change that. I'll be running the same in mine, and changing it every 3-4,000mi.
    Fink
  7. Sep 8, 2011 at 11:04 PM
    808hiker
    808hiker Taco addict
    Justin
    Big Island, Hawaii
    I only run 5w-30 synthetic in mine. The manual and oil cap says 5w-30 and I personally wouldn't trust the word of anyone at the stealership over the manual. They also said that it comes from the factory filled with semi-synthetic...but they probably didn't know what they were talking about as usual.
  8. Sep 8, 2011 at 11:11 PM
    saugus
    saugus Well-Known Member
    If not already said...
  9. Sep 8, 2011 at 11:14 PM
    CGtaco
    CGtaco Well-Known Member
    Phillip
    07 Tacoma TRD 4x4
    Fog light Mod Total Chaos UCA's Front Icons Rear Icon / res
    I changed mine every 5 to 6k full synthetic. But now I live in Kodiak Ak and change it before and after winter due to low miles driving. Is this a BAD Idea???
  10. Sep 8, 2011 at 11:21 PM
    Kingfrog
    Kingfrog Well-Known Member
    08 TRD Rugged Trail Edition
    Undercover,Pop n Lock, Hardwired GPS, Garage door opener , Scanguage II, wireless back up camera, X994 Basslink, ...Prefer stock and non invasive functional mods
    I use dealer changed dino...I don't plan on keeping the truck past 75K miles.
  11. Sep 8, 2011 at 11:25 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    5w-30 and 5w-20 are the same thickness of oil but at temperature 5w-20 is a bit thinner than 5w-30 but not enough to cause harm
    so at cold temps the oil flows as 5W oil and operating temp the oil flows the same as the higher number does at 210F
    its alot of babble of viscosity laws with oil
    youll be fine
  12. Sep 9, 2011 at 1:19 AM
    2TRunner
    2TRunner Snoop Dad
    My House Usually
    Shit, they would, if they could.
    You could properly inflate your tires with air for better MPGs!!!!!!
    I love this 0-20 shit, help gas mileage blah blah blah, then pay out the ass for an oil change. 0-20 is a synthetic oil only I believe.
  13. Sep 9, 2011 at 5:11 AM
    Tacologist
    Tacologist Well-Known Member
    Bob
    Tenessee
    05 Double Cab Shortbed
    Rear leaf suspension. Home done tailgate re-inforcement.
  14. Sep 9, 2011 at 7:41 PM
    johnny 5
    johnny 5 Well-Known Member
    wisconsin
    Black 07 TRD Off road 4x4
    7-6'' sno-way plow w/DP
    For what its worth ow30 is the best choice of oil. A ow30 oil is still too thick to properly lubricate at a cold startup 5w30 and 10w30 are even worse off the high temperature protection of the 0w30 is the same or better then 10w30 and the ow30 is the best choice for a startup protection it is the best choice current oil technology offers. Yes ow30 is still too thick to lubricate at start up 10w30 is even worse off. So get the startup protection and high temp benefits of a 0w30 synthetic!!!
  15. Sep 9, 2011 at 7:45 PM
    #35
    UndefinedTaco
    UndefinedTaco I'll eat all your food.
    Justin
    Tracy, CA
    Toyota
    It's an 89 Toyota Pickup. I got some stuff done to it.. FJ axles going under it soon.
    I put redline 2 stroke oil, fluorescent Krylon spray paint, oven cleaner, gloss clear Krylon, Simple Green and some Goo Off in one of my Honda XR50s crankcase...it still runs till this day. I've never changed it out.
    XR50 = 22RE
    Just saying.
    Lol @ OP freaking out at 5w-20 put in his truck :eek:
  16. Sep 9, 2011 at 7:50 PM
    #36
    Yoytoda
    Roland
    completely stock
    you better be kidding or you should be the one to lol@
  17. Sep 9, 2011 at 11:22 PM
    #37
    UndefinedTaco
    Justin
    Tracy, CA
    Toyota
    Nope, I put it on PURPOSE though.
    I have three XR50's and tons of extra parts laying around.
    If the motor grenades, I wouldn't care. There dime a dozen..get them $100 all day on Planetminis.
    It still runs till this day.
  18. Sep 10, 2011 at 5:52 AM
    #38
    saugus
    Forgot the part about WHY???:eek:
  19. Sep 10, 2011 at 7:07 AM
    #39
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    funny calling the lady an idiot..why were you messin with the fill plug?
  20. Sep 10, 2011 at 7:36 AM
    #40
    Yoytoda
    Roland
    completely stock
    i saw that too and how the f do you manage to strip the plug?
