Fuel additive?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Gfenza89, Jan 17, 2024.
  1. Jan 18, 2024 at 4:12 PM
    Williston
    Williston Well-Known Member
    2014 Tacoma DC 4x4 V6 040 [SL] SR5 4x4 [ED] Entune Audio Plus [TO] V6 Tow Package
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Gentex Auto-Dim mirror w/Compass and Outside Temperature Display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter)
    Techron. Some port fuel-injected Volvo's in the 90's had a cold-start problem caused by carbon-deposits on the back of the valves absorbing too much of the the initial fuel charge/spray. One bottle would remove the carbon, clear the injector nozzles and correct the issue.
    Gfenza89[OP] likes this.
  2. Jan 18, 2024 at 4:13 PM
    Csoth7
    Csoth7 Active Member
    2020 TRD PRO
    Using Techron every 2-3 k.. Cant say i noticed much...
  3. Jan 18, 2024 at 4:17 PM
    Gfenza89
    Gfenza89 [OP] Well-Known Member
    2024 Tacoma SR5 4x4 DCSB
    Thanks for the comments guys always interesting discussion
  4. Jan 18, 2024 at 4:23 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Has anyone figured out a way to tell if these additives actually do anything?
    Like other than just "I can feel a difference"?
  5. Jan 18, 2024 at 4:32 PM
    TacoTuesday1
    SD CA
    or you just buy gas that has detergents
    yeah I figured out it was $10 to gain nothing, and did not magically restore the deteriorated basket filters from high miles inside of my fuel injectors, nor did the can perform ultrasonic cleaning, testing, and flow matching
  6. Jan 18, 2024 at 4:33 PM
    Ronk44
    Ronk44 Well-Known Member
    Rockerville, SD
    2017 MGM Sport
    Leveled with Bilstein 5100 shocks, Falken Rubitrek AT 265/75 tires, Redline hood struts, R4T tailgate lock, Matt Gecko LED strips in bed and under hood, WeatherTech hood guard, OEM bed mat, Husky floor mats, Carhart seat covers, Grille replacement with Toyota letters, Sony AX6000 head unit, OTT lite/mild tune, and an occasional splash of fuel additive.
    To me fuel additives are same as an addiction of also using oil additives such as Motorkote. I dump stuff in both holes. I also change my air filters on April fools day each year. I’m that guy. I have no proof, but I feel better!
  7. Jan 18, 2024 at 4:39 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Yep... got about 10 cases in the garage right now. Been using it in my 07 since new. Not sure if related but i've never experienced the "taco tick" i've read so much about here... truck runs like a sewing machine.
    ExpeditionKen82 likes this.
  8. Jan 18, 2024 at 6:49 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Its the engine cleaning itself. Read up.
    TacoSR523 and Blak Shinobi like this.
  9. Jan 18, 2024 at 6:52 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Nope. In all the years I've been here it's just feelings. Oil feels better, my granddad says to do this, etc. Nobody has proof of anything except cold air intake.
    A guy dyno'd several times, with stock, an aftermarket and no air cleaner at all. Guess which won. Stock. People spend money to feel better, not because it actually works.
  10. Jan 18, 2024 at 8:08 PM
    Rraiderr
    Rraiderr Well-Known Member
    Great White North
    2017 Tacoma TRD off road
    Working now a list
    Amsoil Pi.
    TartanEagle likes this.
  11. Jan 18, 2024 at 8:22 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    If the intake valves are covered with carbon do you really want to knock any chunks loose? A chunk of carbon can easily get stuck between the valve face and seat and hold the valve open. The only way to safely clean carbon deposits off the valves is to pull the intake and do it manually with a media blaster. 15 years ago when VW/Audi engines started showing up everywhere with coked up valves we did it by hand with a pick and cleaning solvents. Nobody outside the dealers had a media blasting setup, we had to get it done with what we had.
    I've seen Seafoam ruin brand new fuel pumps
    I've seen fuel tank additives melt the insulation between the windings in fuel injectors and short them out
    Best way to keep valves clean is to get out on the highway frequently and don't baby the engine
    AmateurTaco1313 likes this.
  12. Jan 18, 2024 at 11:31 PM
    Blak Shinobi
    Blak Shinobi Well-Known Member
    taco
    2020 MGM Sport DCSB 4x4
    n/a
    sure we can go with that if you want :thumbsup:
  13. Jan 18, 2024 at 11:45 PM
    TacoTuesday1
    SD CA
    given that it's DI injectors that end up having issues quickly, not port, probably no.
    If you're worried about port injectors, find a spare set and have it rebuilt to swap in. Probably no sooner than 100k mi.
  14. Jan 19, 2024 at 6:04 AM
    Gatafly
    Gatafly Well-Known Member
    Shawn
    2020 TRD OR AT V6 MGM
    Not worried about any of it actually.
  15. Jan 19, 2024 at 6:07 AM
    #35
    Gatafly
    Shawn
    Yeah, I did find some things and it is what I said. A previous video supposedly explaining things has been taken down probably because those responding said he didn't seem to really know how or what. If you have a link to something else that is different feel free to post up, I am all open to it.
  16. Jan 19, 2024 at 6:49 AM
    #36
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Or maybe better phrased "old habits are hard to break". I remember when the Bosch fuel injection system started to become commonplace, and the injectors were highly prone to carbon buildup.
    My E30 BMW was the worst, needing an annual soak cleaning where they would suck this BG444 fuel injector cleaner into the intake manifold and let it soak for a few hours. And in between the annual cleaning, you ran a few bottles of Techron to keep the carbon buildup from getting out of hand. I guess maybe it's not as critical with modern fuel injection systems, but I still do it anyway.
    eurowner likes this.
  17. Jan 19, 2024 at 7:12 AM
    #37
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    If you need fuel cleaner, something is wrong. If you “really” need the fuel system cleaned. The stuff you pour in the tank isn’t going to cut it.
    skidooboy and b_r_o like this.
  18. Jan 19, 2024 at 11:02 AM
    #38
    TacoTuesday1
    SD CA
    additive might even boost octane or something making the truck slightly feel better only while it’s in the tank and possibly slightly better MPG.
    but the high cost of an additive and that result is probably not enough to cover or justify the cost.
    all the high mile Toyotas out there probably don’t care if the drivers putting additive.
  19. Jan 19, 2024 at 11:20 AM
    #39
    TartanEagle
    TartanEagle Well-Known Member
    '17 ACLB 4x4 MT
    I do a full bottle of Amsoil UCL every 5th fill up.
    And 2 or 4 ounces of Amsoil P.I. every 4k or 5k miles.
  20. Jan 19, 2024 at 2:53 PM
    #40
    BMH
    BMH Well-Known Member
    Bruce
    Pend Oreille County, WA.
    2020 4x4 SR AC 2.7 liter - Bare Bones Base Model
    Italian tune-up.... It really is a thing.. LOL :thumbsup:
    joba27n[QUOTED] likes this.
