Fuel Additives
Discussion in '1st Gen. Tacomas (1995-2004)' started by gary56, Sep 26, 2012.
  1. Sep 26, 2012 at 1:07 PM
    gary56
    gary56 [OP] Active Member
    Garrett
    Bend, OR
    04 Xtracab Limited
    K&N Air Filter
    I bought a fuel additive that is supposed to help clean out the tank and engine. Before i used it I was going to check and see what other people thought about these additives. Should I use it or not ?
    Thanks for the help.
  2. Sep 26, 2012 at 1:14 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    I use Marvel mystery oil in my tank once in a while. I can't say if it really does anything though. However, I have a low mileage truck so I'm not trying to clean anything really.
  3. Sep 26, 2012 at 1:18 PM
    Yamaha Dave
    Yamaha Dave Well-Known Member
    I use Lucas products in everything from my truck to sportbike, to weed eater and lawn mower. I can't speak for other brands, but the Lucas fuel additives work almost instantly. I can take for instance my Yamaha R1 (sportbike for those not familiar) and start it after it's been sitting all winter and it will run rough from the gunk and fuel clogging the injectors. I put in some of the Lucas additive afterwards, and the bike comes to life roaring within minutes. It works 100% and is good maintenance overall.
  4. Sep 26, 2012 at 1:32 PM
    chris66
    chris66 ( ͡°( ͡° ͜ʖ( ͡° ͜ʖ ͡°)ʖ ͡°) ͡°)
    dust
    CO
    2004 Prerunner
    bfg at ko2, method double standard
    i can recommend lucas products too^^^
    bought some additive when i had my 66 chevelle to help clean out the carb a little and i noticed it instantly. havent really tried anything on my truck. but when i got it it was getting shit mileage until after i got it serviced and a new specter haf filter
    still only get 17-18mpg at best :turtleride:
  5. Sep 26, 2012 at 1:38 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    If you use E10 in your truck be careful of the additives you use, a lot are alcohol based. I use Star Tron which is safe to use with E10.
  6. Sep 26, 2012 at 2:37 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I use Startron in all of my small engines (sport bike, lawn mower, snow blower, etc) and it really helps keep them running well. The ethanol was playing hell on the small engines and making them impossible to start. Startron keep the ethanol from separating over time. It also takes a very small dose to do the trick so it's inexpensive to use plus, there's absolutely 0 harm in overdosing.
  7. Sep 26, 2012 at 2:45 PM
    nwb3160
    nwb3160 Well-Known Member
    Nick
    Cartersville, Ga
    2008 Tacoma TRD Sport
    5100s OME 885 2009 tail lights 6000K HID Pioneer 4400 DVD Viper Alarm/Remote Start Avid Offroad Bar/Side Steps Wet Okole Seat Covers Husky Floor Mats Toyo Open Country MT 265/70R17 BANKS Monster Exhaust Ultraguage
    seafoam has worked wonders for me
  8. Sep 26, 2012 at 2:51 PM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    I use Seafoam to clean and a stabilizer if I plan on having the fuel in the tank for more than a week.
  9. Sep 26, 2012 at 3:56 PM
    gary56
    Garrett
    Bend, OR
    04 Xtracab Limited
    K&N Air Filter
    Thanks for the tips. learning lots !
  10. Sep 26, 2012 at 3:59 PM
    colo plainsman
    colo plainsman Active Member
    Colorado
    01 double cab SR5 TRD 4wd
  11. Sep 26, 2012 at 5:24 PM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    OK, you guys got me thinking, but not about my Tacoma.
    I have a '77 Celica I am slowly restoring with a carbureted 20R motor. It's not finished or in a state to drive other than up and down the street when neighbors aren't looking, but I do start it up and run it at least once a month. It's a brand new rebuilt motor, MSD electronic ignition and Weber 32/26 carb with no emissions equipment and started up the first time.
    Several months ago it got to where it wouldn't idle. It still starts and runs, but won't idle. It almost does, but stumbles a lot. I was thinking intake leak and have been trying to find it using the brake cleaner/carb cleaner spray trick, but can't find anything definitive. A mechanic buddy said that with today's 10% ethanol fuels, the fuel gets unstable quickly. I have just been adding additional fuel to the tank from the mower gas can off and on over the last couple of years, so it just dawned on me that it could be an idle jet! Duh.
    So my question: Which of these fuel additives would do the best job of clearing out the idle jets and stabilizing the fuel? Or do I need to drain the tank and start over?
    I'd rather start with a cheap bottle of additive and see if that works. It doesn't make much sense that an intake leak would happen all of the sudden on such a simple system, although I do like the looks of the LCE intake for the 20R so I could get rid of the Weber adapter.
  12. Sep 26, 2012 at 5:26 PM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    I do the Lucas fuel additive every time I do a oil change but I don't think it does anything.
  13. Sep 26, 2012 at 5:51 PM
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
  14. Sep 26, 2012 at 5:58 PM
    jtgroce
    jtgroce Got R Did
    In the Foothills, NC
    '12 Taco MGM TRD Off Road
    K&N Air Filter Husky Floor Liners Weathertech Vent Visors LED Map/Dome Light Mod Chrome Door Handles AVS Bugshield Bed Mat Fog Light Anytime Mod DTRL LED's Flowmaster Super 40
    This^^............ I use it every oil change. Although others have stated it doesn't do anything for them, I do notice a +0.5mpg gain on the first fuel up after using it, but usually nothing after that.
  15. Sep 26, 2012 at 7:03 PM
    Alderleet
    Alderleet Ace of Spades
    Nick
    Salty Hell
    '00 Acc Cab TRD 4x4
    I've gotten ABSOLUTE DOG SHIT fuel economy using this.
    I've tested in both a 2000 Tacoma (3.4l V6) and 2007 Impreza (2.5I boxer 4)
    Both vehicles, on 3 separate occasions have gotten worse gas mileage. The subaru averages 400miles per tank, my Taco gets 300.
    The subaru ended out at 340miles, my taco ended at 250miles.
    Not sure why, but the fuel economy dropped, with no change in driving habits. Once we refueled, the fuel economy went back up.
    Seafoam on the other hand hasnt had adverse effects, so im sticking with it.
  16. Sep 26, 2012 at 7:13 PM
    DitchDoc
    DitchDoc Well-Known Member
    Logan
    Western North Carolina
    03 V6 QC TRD Limited 4x4
    2003 DC 4x4 TRD Cap K&N FIPK
    Seafoam for me. Which reminds me, I need to go pick some up :D
  17. Sep 26, 2012 at 7:30 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Gas in the gas tank, oil in the crankcase, coolant in the radiator.
    Anything else is snake oil and only empties your pocket.
    Think about it... that little 8oz bottle "treats up to 22 gallons"
    That bottle is going to be adequate to treat 20 gallons, but it's not going to be too much for a 10 gallon Corolla, or a 4 gallon motorcycle?
  18. Sep 26, 2012 at 8:13 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    Are we to guess what fuel additive you bought?
  19. Sep 26, 2012 at 8:47 PM
    gary56
    Garrett
    Bend, OR
    04 Xtracab Limited
    K&N Air Filter
    Gold Eagle Fuel System Cleaner. After this discussion its not going in the tank !
  20. Sep 26, 2012 at 8:58 PM
    worthywads
    Good call.
