fuel additives
Discussion in '3rd Gen. Tacomas (2016-2023)' started by s.e.charles, Jul 4, 2021.
  1. Jul 5, 2021 at 10:42 AM
    #41
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    What did you find wrong. Just curious.
  2. Jul 5, 2021 at 10:46 AM
    #42
    H6G
    H6G Well-Known Member
    Far from home...
    ‘18 Blk. Pro/ ‘17 GT350
    '22 Pro suspension/ Custom Deaver springs/ ECGS and...
    Subaru has its own recommended cleaner…
  3. Jul 5, 2021 at 10:53 AM
    #43
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Was told at auto parts its the same stuff as sea foam, but they don't carry it. I've use bg back in the day...good stuff.
  4. Jul 5, 2021 at 10:55 AM
    #44
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Long ago in a time forgotten. Whole lot more about leaky valve guides/seals. Gasoline will be evaporated by the time you exit the vehicle. I'm old enough to have blasted valves with walnut shells while still on the head those days are long gone.
  5. Jul 5, 2021 at 11:21 AM
    #45
    eurowner
    eurowner Duke Sky
    Scoty
    :der::facepalm:
    zoo truck[QUOTED] likes this.
  6. Jul 5, 2021 at 11:29 AM
    #46
    Pro-Taco
    Pro-Taco Well-Known Member
    Lou
    Commiefornia
    2019 OR DCSB 4X4 Prem/Tech Cement
    All TRD Pro parts
    Government mandates to have certain amount of detergent in all gasolines. If you're using top tier gas then you should not be needing any other detergent to keep your fuel system clean in your Tacoma. Said that, most GDI engines (not Tacoma) suffer from carbon deposits since gasoline does not come in contact with valves. For that instance I use CRC valve cleanerhttps://www.autozone.com/fuel-and-engine-cleaners-additives/intake-valve-cleaner/crc-gdi-intake-valve-cleaner-11oz/461563_0_0?cmpid=LIA:US:EN:AD:NL:1000000:GEN:71700000069889792&gclid=Cj0KCQjw24qHBhCnARIsAPbdtlLjOk9Bog415JtIBNssUfXZ_RqWD0FmUwPNcKTETbUE6NCH6o47dmcaAlKPEALw_wcB&gclsrc=aw.ds, the only over the counter chemical strong enough to keep carbon in check.
    Now if you want to realign your gas and make it burn more efficiently and feel a bit more pep, I use Liqui Moly Speed Tec: https://www.amazon.com/Liqui-Moly-2...t=&hvlocphy=9031906&hvtargid=pla-568593964285 in my sports cars.
  7. Jul 5, 2021 at 2:58 PM
    #47
    mrengineerical
    mrengineerical Well-Known Member
    Baltimore, MD
    2019 Tacoma TRD Sport DCSB
    I've heard good things about Techron, but I've always been a seafoam user. Seafoam doubles as a carb/injector/valve cleaner as well as a fuel stabilizer. I use it in my motorcycle over winter, in the lawn mower, and in all my vehicles. Motorcycle has never had any issues with the carb gumming up come spring every year. Keeps the engines running like new.
    Even ChrisFix has proof it works in a car engine as well as a lawn mower engine. Apparently Berrymans B-12 cleans better than Seafoam, however it has known to be too harsh on vehicle fuel systems.
    https://youtube.com/watch?v=u6UeJXkzDW8
    https://youtube.com/watch?v=WdT4DPFXIkM
  8. Jul 5, 2021 at 3:37 PM
    #48
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    What I find interesting is this: Scotty will rip a manufacturer left and right, the dude has been around longer than a lot of us
    have been living. I trust what he has to say.
    Furthermore: If he were spouting B.S. don't you think Ford/ Chevy/ Dodge/ ( whoever ) would have his azz up to his neck
    in lawsuits?.... right.... they know if they haul him into a court of law he will prove every word and they will look mucho-bad.
  9. Jul 5, 2021 at 3:43 PM
    #49
    dagobert
    dagobert Well-Known Member
    Not a trickle charger...you'll cook your battery.
    Battery Tender like this:
    NOCO - GEN On-Board Battery Chargers
    Works awesome, have one hardwired in my FJ. I have driven it maybe 200 mi in the last year.....battery is still fresh as a daisy.
  10. Jul 5, 2021 at 8:55 PM
    #50
    Kev250R
    Kev250R Well-Known Member
    Kevin
    Orange, So.Cal.
    2020 Tacoma TRD Off-Road 6MT
    Floor mats, junk in center console
    FYI Battery Tender's (the brand) will turn themselves off when the battery is fully charged to save 'cooking' a battery. I've yet to try using one to cook Bacon; I'll be sure and report-back!
    I have Battery Tender's hard-wired onto all of my ATV's, MC's and my Travel Trailer. I generally get 5 to 12 years out of my battery's. There are other brands, Battery Tender is the one I've had the best results with.
    zoo truck likes this.
  11. Jul 6, 2021 at 5:21 AM
    #51
    zoo truck
    None
    I've got a battery tender on my boat, bought my last battery in 2015...still going strong.
  12. Jul 6, 2021 at 5:37 AM
    #52
    Itchyfeet
    Itchyfeet Well-Known Member
    I had a 1989 325is for a couple of years and sold it with 270k on the odometer. I never had any intake valve deposits. I had to replace the head at 250k if I recall because a coolant passage cracked into an oil galley. The intake valves were clean. I did run Redline Fuel injector cleaner once a year.
    The MPGs in that car were horrific, I rarely got more than 15 MPG and I think new they were rated like 19/20 MPG. It was a great car.
  13. Jul 6, 2021 at 5:51 AM
    #53
    mattm55
    mattm55 Well-Known Member
    Mid-Hudson Valley, NY
    2017 BBPearl Tacoma TRD Sport Access/AT w/SnoWay
    Ahh, Scotty. I was wondering why Dennis Hopper was making videos on using Seafoam?
    Key-Rei likes this.
